x86 c++ exception handling
Karel Gardas
karel.gardas at centrum.cz
Sat Sep 12 19:57:56 UTC 2020
Updated patch without debugging leftover.
On 9/12/20 9:41 PM, Karel Gardas wrote:
> On 9/12/20 5:33 AM, Joel Sherrill wrote:
>> I suspect if you want a common floor it is a Pentium II. That's where SMP
>> appeared.
>> We can't sanity check the cpu model if we don't know the rules. And if we
>> know the rules, we should just drop those low models. And error if someone
>> runs on an older model.
> Well, I think we may also change a perspective this way: RSB supports
> pc.set which builds pc686 by default. So this is SMP safe BSP. I guess
> that's what majority of user will use as it is very convenient.
> Once someone would like to build variant of pc386 BSP by hand, we may
> add clear error/warning about SMP being unsupported on the particular
> old BSP.
> Attached patch implements this (clear error). It basically allows
> --enable-smp only for pc686 and pcp4 BSPs.
> Comments welcome!
> Thanks,
> Karel
> devel mailing list
> devel at rtems.org
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200912/5aa7e72d/attachment-0001.bin>
