x86 c++ exception handling
Karel Gardas karel.gardas at centrum.cz
Sat Sep 12 20:14:48 UTC 2020
On 9/12/20 10:00 PM, Joel Sherrill wrote:
> Thanks. But in case you missed my comment on the ticket.
Can't find any related ticket in rtems trac. Which one is it?
> The multi-lib is
> built with -mtune not -march so defaults to i386 code. The file
> gcc/config/i386/t-rtems needs to be changed I think. When gcc changed from
> -mcpu, we apparently picked the wrong replacement argument. At least that's
> what I think explains this.
Ah, and would you like first test it as a patch in RSB or would you go
directly to gcc?
Thanks,
Karel
