[PATCH] CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
Sun Sep 13 23:05:02 UTC 2020
On 13/9/20 6:31 pm, Sebastian Huber wrote:
> On 12/09/2020 01:31, Chris Johns wrote:
>> On 12/9/20 12:10 am, Joel Sherrill wrote:
>>> Did we decide if there had to be an explicit configure
>>> option to even use this API? Chris and I discussed this
>>> as an idea to force a user to make a very conscious
>>> decision to allow it.
>> Sebastian did not like the idea and accepted that so not at the moment. The
>> solution is better config management and we will monitor how this goes.
> My point is that an API enable and the now implemented
> maximum_thread_local_storage_size both lead to run-time errors of the new
> directive. However, the maximum_thread_local_storage_size ensures that you don't
> have an unexpected task storage configuration, for example a too small thread
> stack size which could be difficult to debug.
>>> There does need to be documentation on the allocation
>>> strategies, when to use, limitations, and particularly the
>>> use of rtems-exeinfo to get the TLS size. This is one case
>>> for sure where an RTEMS Tool needs explicit mention in
>>> both the API and configure option sections.
>> I agree. This one needs a little more than the others.
> I updated the ticket description:
> https://devel.rtems.org/ticket/3959
I have added some updates for you to review.
>>> I have had flashbacks to how often we got used to get questions
>>> about why adding a sleep(1) in the middle of hello world locked
>>> up. Then we added an option to say "does not need clock
>>> driver" and the user questions stopped.  I would rather be a
>>> bit aggressive on setup and avoid this for tasks with statically
>>> allocated resources.
>> I am concerned we have really difficult to debug issues that appear to be bugs
>> but are weakness in the configuration.
> I think it is now quite safe. If something is wrongly configured, then you get
> an error status (RTEMS_INVALID_SIZE). You don't get problems like a suddenly too
> small thread stack with a potential overflow.
Yes I think we have suitable balance.
