New build system ready for testing
Mon Sep 14 07:07:42 UTC 2020
Hello,
I checked in the new build system today. Now is a good time to test your
favourite BSP if it still works. You find the user oriented
documentation of build system here:
https://docs.rtems.org/branches/master/user/bld/index.html
The documentation for RTEMS maintainers is here:
https://docs.rtems.org/branches/master/eng/build-system.html
How to check the new build system for a particular BSP?
1. Build the BSP with all tests enabled.
2. Run the tests and compare the results with the old build system.
Ideally use the RTEMS Tester to run the tests and report them to the
RTEMS Project.
3. Check if all BSP options are available (./waf bsp_defaults). Check
the type and values of the BSP options.
4. Check the linker command file.
5. Check the compiler machine flags.
6. Install the BSP and build your third-party libraries and applications
with it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
