[PATCH v4 1/5] CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
Joel Sherrill
joel at rtems.org
Mon Sep 14 13:57:06 UTC 2020
On Sun, Sep 13, 2020 at 3:19 AM Sebastian Huber <
> On 12/09/2020 02:33, Chris Johns wrote:
> > On 12/9/20 1:34 am, Sebastian Huber wrote:
> >> +const size_t _Thread_Maximum_TLS_size =
> >> + CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE;
> > Should rtems-exeinfo report this?
> Yes, this would be helpful. Then you can see if you get a fatal error
> during the system start. You see also how much space is wasted or
> available for dynamic linking.
In the other thread, I noted that rtems-exeinfo could actually check the
real TLS size and the configuration parameter for consistency before
the executable was downloaded.
There was also a longer discussion of error checking philosophy
in RTEMS and how we never discuss it as a unified concept.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200914/c5ab8534/attachment.html>
