[PATCH] gitignore: ignore top-level ini files
Chris Johns
chrisj at rtems.org
Tue Sep 15 00:51:15 UTC 2020
On 15/9/20 9:52 am, Gedare Bloom wrote:
> hah, yes. In rtems.git with the new build system it seems the workflow
> is to create a .ini file in your top-level source directory to control
> the build. We should not include those ini files in version control I
> think?
The INI files do not need to be in the top directory, any valid path should do.
I will let Sebastian decide.
> I meant to start a discussion, then I went for a bicycle ride and forgot.
A ride is more important.
> -Gedare
> On Mon, Sep 14, 2020 at 3:47 PM Chris Johns <chrisj at rtems.org> wrote:
>> Hi Gedare,
>> Which repo is this for? I suspect rtems.git but I thought it best to ask.
>> Chris
>> On 15/9/20 3:43 am, Gedare Bloom wrote:
>>> .gitignore | 1 +
>>> 1 file changed, 1 insertion(+)
>>> diff --git a/.gitignore b/.gitignore
>>> index d7ca74b338..8b28b186e1 100644
>>> --- a/.gitignore
>>> +++ b/.gitignore
>>> @@ -4,6 +4,7 @@ autom4te.cache
>>> config.h.in
>>> configure
>>> doc
>>> +/*.ini
>>> .lock*
>>> Makefile.in
>>> *.pyc
