[PATCH 6-freebsd-12 1/4] waf: Reformat to PEP8 using yapf
chrisj at rtems.org
chrisj at rtems.org
Tue Sep 15 02:33:06 UTC 2020
builder.py | 458 ++++++++++++++++++++++++++++++++------------------
waf_libbsd.py | 239 +++++++++++++-------------
wscript | 155 ++++++++++-------
3 files changed, 508 insertions(+), 344 deletions(-)
diff --git a/builder.py b/builder.py
index f5fe2afc..09c51d1b 100755
--- a/builder.py
+++ b/builder.py
@@ -1,7 +1,10 @@
+# SPDX-License-Identifier: BSD-2-Clause
+'''Manage the libbsd build configuration data.
+# Copyright (c) 2015, 2020 Chris Johns <chrisj at rtems.org>. All rights reserved.
-# Copyright (c) 2015-2016 Chris Johns <chrisj at rtems.org>. All rights reserved.
-# Copyright (c) 2009, 2017 embedded brains GmbH. All rights reserved.
+# Copyright (c) 2009, 2017 embedded brains GmbH. All rights reserved.
# embedded brains GmbH
# Dornierstr. 4
@@ -9,30 +12,26 @@
# Germany
# <info at embedded-brains.de>
-# Copyright (c) 2012 OAR Corporation. All rights reserved.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions
-# are met:
-# 1. Redistributions of source code must retain the above copyright
-# notice, this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright
-# notice, this list of conditions and the following disclaimer in the
-# documentation and/or other materials provided with the distribution.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-# "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-# LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
-# A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
-# OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
-# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
-# LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
-# DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
-# THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
-# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
-# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-# FreeBSD: http://svn.freebsd.org/base/releng/8.2/sys (revision 222485)
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
from __future__ import print_function
@@ -60,13 +59,14 @@ filesTotal = 0
filesTotalLines = 0
filesTotalInserts = 0
filesTotalDeletes = 0
-diffDetails = { }
+diffDetails = {}
verboseInfo = 1
verboseDetail = 2
verboseMoreDetail = 3
verboseDebug = 4
def _cflagsIncludes(cflags, includes):
if type(cflags) is not list:
if cflags is not None:
@@ -81,10 +81,12 @@ def _cflagsIncludes(cflags, includes):
_includes = includes
return _cflags, _includes
-def verbose(level = verboseInfo):
+def verbose(level=verboseInfo):
return verboseLevel >= level
-def changedFileSummary(statsReport = False):
+def changedFileSummary(statsReport=False):
global filesTotal, filesTotalLines, filesTotalInserts, filesTotalDeletes
@@ -107,18 +109,25 @@ def changedFileSummary(statsReport = False):
# Sort by opacity.
- ordered_diffs = sorted(diffDetails.items(), key = lambda diff: diff[1].opacity, reverse = True)
+ ordered_diffs = sorted(diffDetails.items(),
+ key=lambda diff: diff[1].opacity,
+ reverse=True)
for f in ordered_diffs:
print(' %s' % (diffDetails[f[0]].status()))
def readFile(name):
try:
- contents = codecs.open(name, mode = 'r', encoding = 'utf-8', errors = 'ignore').read()
+ contents = codecs.open(name,
+ mode='r',
+ encoding='utf-8',
+ errors='ignore').read()
except UnicodeDecodeError as ude:
print('error: reading: %s: %s' % (name, ude))
sys.exit(1)
return contents
def writeFile(name, contents):
path = os.path.dirname(name)
if not os.path.exists(path):
@@ -128,11 +137,13 @@ def writeFile(name, contents):
print('error: cannot create directory: %s: %s' % (path, oe))
sys.exit(1)
try:
- codecs.open(name, mode = 'w', encoding = 'utf-8', errors = 'ignore').write(contents)
+ codecs.open(name, mode='w', encoding='utf-8',
+ errors='ignore').write(contents)
print('error: write: %s: %s' % (name, ude))
sys.exit(1)
# A builder error.
@@ -140,11 +151,14 @@ class error(Exception):
"""Base class for exceptions."""
def __init__(self, msg):
self.msg = 'error: %s' % (msg)
def set_output(self, msg):
self.msg = msg
def __str__(self):
return self.msg
# Diff Record
@@ -158,7 +172,8 @@ class diffRecord:
self.inserts = inserts
self.deletes = deletes
self.changes = inserts + deletes
- self.opacity = (float(self.changes) / (self.lines + self.changes)) * 100.0
+ self.opacity = (float(self.changes) /
+ (self.lines + self.changes)) * 100.0
def __repr__(self):
return self.src
@@ -167,36 +182,50 @@ class diffRecord:
return 'opacity:%5.1f%% edits:%4d (+):%-4d (-):%-4d %s' % \
(self.opacity, self.changes, self.inserts, self.deletes, self.src)
# This stuff needs to move to libbsd.py.
# Move target dependent files under a machine directory
def mapCPUDependentPath(path):
- return path.replace("include/", "include/machine/")
+ return path.replace("include/", "include/machine/")
def fixIncludes(data):
- data = re.sub('#include <sys/resource.h>', '#include <rtems/bsd/sys/resource.h>', data)
- data = re.sub('#include <sys/unistd.h>', '#include <rtems/bsd/sys/unistd.h>', data)
+ data = re.sub('#include <sys/resource.h>',
+ '#include <rtems/bsd/sys/resource.h>', data)
+ data = re.sub('#include <sys/unistd.h>',
+ '#include <rtems/bsd/sys/unistd.h>', data)
return data
# revert fixing the include paths inside a C or .h file
def revertFixIncludes(data):
- data = re.sub('#include <rtems/bsd/', '#include <', data)
- data = re.sub('#include <util.h>', '#include <rtems/bsd/util.h>', data)
- data = re.sub('#include <bsd.h>', '#include <rtems/bsd/bsd.h>', data)
- data = re.sub('#include <zerocopy.h>', '#include <rtems/bsd/zerocopy.h>', data)
- data = re.sub('#include <modules.h>', '#include <rtems/bsd/modules.h>', data)
+ data = re.sub('#include <rtems/bsd/', '#include <', data)
+ data = re.sub('#include <util.h>', '#include <rtems/bsd/util.h>', data)
+ data = re.sub('#include <bsd.h>', '#include <rtems/bsd/bsd.h>', data)
+ data = re.sub('#include <zerocopy.h>', '#include <rtems/bsd/zerocopy.h>',
+ data)
+ data = re.sub('#include <modules.h>', '#include <rtems/bsd/modules.h>',
+ data)
return data
# fix include paths inside a C or .h file
def fixLocalIncludes(data):
- data = re.sub('#include "opt_([^"]*)"', '#include <rtems/bsd/local/opt_\\1>', data)
- data = re.sub('#include "([^"]*)_if.h"', '#include <rtems/bsd/local/\\1_if.h>', data)
- data = re.sub('#include "miidevs([^"]*)"', '#include <rtems/bsd/local/miidevs\\1>', data)
- data = re.sub('#include "usbdevs([^"]*)"', '#include <rtems/bsd/local/usbdevs\\1>', data)
+ data = re.sub('#include "opt_([^"]*)"',
+ '#include <rtems/bsd/local/opt_\\1>', data)
+ data = re.sub('#include "([^"]*)_if.h"',
+ '#include <rtems/bsd/local/\\1_if.h>', data)
+ data = re.sub('#include "miidevs([^"]*)"',
+ '#include <rtems/bsd/local/miidevs\\1>', data)
+ data = re.sub('#include "usbdevs([^"]*)"',
+ '#include <rtems/bsd/local/usbdevs\\1>', data)
return data
def revertFixLocalIncludes(data):
data = re.sub('#include <rtems/bsd/local/([^>]*)>', '#include "\\1"', data)
@@ -208,42 +237,48 @@ def assertHeaderFile(path):
print("*** Move it to a C source file list")
sys.exit(2)
def assertSourceFile(path):
if path[-2:] != '.c' and path[-2:] != '.S' and path[-3:] != '.cc':
print("*** " + path + " does not end in .c, .cc or .S")
print("*** Move it to a header file list")
sys.exit(2)
def assertHeaderOrSourceFile(path):
if path[-2] != '.' or (path[-1] != 'h' and path[-1] != 'c'):
print("*** " + path + " does not end in .h or .c")
print("*** Move it to another list")
sys.exit(2)
def diffSource(dstLines, srcLines, src, dst):
# Diff, note there is no line termination on each string. Expand the
# generator to list because the generator is not reusable.
- diff = list(difflib.unified_diff(dstLines,
- srcLines,
- fromfile = src,
- tofile = dst,
- n = 5,
- lineterm = ''))
+ diff = list(
+ difflib.unified_diff(dstLines,
+ srcLines,
+ fromfile=src,
+ tofile=dst,
+ n=5,
+ lineterm=''))
inserts = 0
deletes = 0
if len(diff) > 0:
if src in diffDetails and \
diffDetails[src].dst != dst and diffDetails[src].diff != diff:
- raise error('repeated diff of file different: src:%s dst:%s' % (src, dst))
+ raise error('repeated diff of file different: src:%s dst:%s' %
+ (src, dst))
for l in diff:
if l[0] == '-':
deletes += 1
elif l[0] == '+':
inserts += 1
- diffDetails[src] = diffRecord(src, dst, srcLines, diff, inserts, deletes)
+ diffDetails[src] = diffRecord(src, dst, srcLines, diff, inserts,
+ deletes)
# Count the total files, lines and the level of changes.
@@ -255,6 +290,7 @@ def diffSource(dstLines, srcLines, src, dst):
return diff
# Converters provide a way to alter the various types of code. The conversion
# process filters a file as it is copies from the source path to the
@@ -262,8 +298,12 @@ def diffSource(dstLines, srcLines, src, dst):
# source.
class Converter(object):
- def convert(self, src, dst, hasSource = True, sourceFilter = None, srcContents = None):
+ def convert(self,
+ src,
+ dst,
+ hasSource=True,
+ sourceFilter=None,
+ srcContents=None):
global filesProcessed, filesProcessedCount
@@ -334,10 +374,12 @@ class Converter(object):
for l in diff:
print(l)
class NoConverter(Converter):
- def convert(self, src, dst, hasSource = True, sourceFilter = None):
+ def convert(self, src, dst, hasSource=True, sourceFilter=None):
return '/* EMPTY */\n'
class FromFreeBSDToRTEMSHeaderConverter(Converter):
def sourceFilter(self, data):
data = fixLocalIncludes(data)
@@ -346,7 +388,8 @@ class FromFreeBSDToRTEMSHeaderConverter(Converter):
def convert(self, src, dst):
sconverter = super(FromFreeBSDToRTEMSHeaderConverter, self)
- sconverter.convert(src, dst, sourceFilter = self.sourceFilter)
+ sconverter.convert(src, dst, sourceFilter=self.sourceFilter)
class FromFreeBSDToRTEMSUserSpaceHeaderConverter(Converter):
@@ -355,7 +398,8 @@ class FromFreeBSDToRTEMSUserSpaceHeaderConverter(Converter):
sconverter = super(FromFreeBSDToRTEMSUserSpaceHeaderConverter, self)
class FromFreeBSDToRTEMSSourceConverter(Converter):
@@ -366,7 +410,8 @@ class FromFreeBSDToRTEMSSourceConverter(Converter):
sconverter = super(FromFreeBSDToRTEMSSourceConverter, self)
class FromFreeBSDToRTEMSUserSpaceSourceConverter(Converter):
@@ -376,7 +421,8 @@ class FromFreeBSDToRTEMSUserSpaceSourceConverter(Converter):
sconverter = super(FromFreeBSDToRTEMSUserSpaceSourceConverter, self)
class FromRTEMSToFreeBSDHeaderConverter(Converter):
@@ -386,19 +432,29 @@ class FromRTEMSToFreeBSDHeaderConverter(Converter):
sconverter = super(FromRTEMSToFreeBSDHeaderConverter, self)
- sconverter.convert(src, dst, hasSource = False, sourceFilter = self.sourceFilter)
+ dst,
+ hasSource=False,
+ sourceFilter=self.sourceFilter)
class FromRTEMSToFreeBSDSourceConverter(Converter):
- data = re.sub('#include <machine/rtems-bsd-kernel-space.h>\n\n', '', data)
- data = re.sub('#include <machine/rtems-bsd-user-space.h>\n\n', '', data)
+ data = re.sub('#include <machine/rtems-bsd-kernel-space.h>\n\n', '',
+ data)
+ data = re.sub('#include <machine/rtems-bsd-user-space.h>\n\n', '',
+ data)
data = revertFixLocalIncludes(data)
data = revertFixIncludes(data)
return data
sconverter = super(FromRTEMSToFreeBSDSourceConverter, self)
+ dst,
+ hasSource=False,
# Compose a path based for the various parts of the source tree.
@@ -410,6 +466,7 @@ class PathComposer(object):
def composeLibBSDPath(self, path, prefix):
return os.path.join(prefix, path)
class FreeBSDPathComposer(PathComposer):
def composeOriginPath(self, path):
return os.path.join(FreeBSD_DIR, path)
@@ -417,6 +474,7 @@ class FreeBSDPathComposer(PathComposer):
return os.path.join(prefix, 'freebsd', path)
class RTEMSPathComposer(PathComposer):
return path
@@ -424,6 +482,7 @@ class RTEMSPathComposer(PathComposer):
return os.path.join(prefix, 'rtemsbsd', path)
class LinuxPathComposer(PathComposer):
return path
@@ -431,36 +490,45 @@ class LinuxPathComposer(PathComposer):
return os.path.join(prefix, 'linux', path)
class CPUDependentFreeBSDPathComposer(FreeBSDPathComposer):
- path = super(CPUDependentFreeBSDPathComposer, self).composeLibBSDPath(path, prefix)
+ path = super(CPUDependentFreeBSDPathComposer,
+ self).composeLibBSDPath(path, prefix)
path = mapCPUDependentPath(path)
return path
class CPUDependentRTEMSPathComposer(RTEMSPathComposer):
- path = super(CPUDependentRTEMSPathComposer, self).composeLibBSDPath(path, prefix)
+ path = super(CPUDependentRTEMSPathComposer,
return path
class CPUDependentLinuxPathComposer(LinuxPathComposer):
- path = super(CPUDependentLinuxPathComposer, self).composeLibBSDPath(path, prefix)
+ path = super(CPUDependentLinuxPathComposer,
return path
class TargetSourceCPUDependentPathComposer(CPUDependentFreeBSDPathComposer):
def __init__(self, targetCPU, sourceCPU):
self.targetCPU = targetCPU
self.sourceCPU = sourceCPU
- path = super(TargetSourceCPUDependentPathComposer, self).composeLibBSDPath(path, prefix)
+ path = super(TargetSourceCPUDependentPathComposer,
path = path.replace(self.sourceCPU, self.targetCPU)
return path
class BuildSystemFragmentComposer(object):
- def __init__(self, includes = None):
+ def __init__(self, includes=None):
if type(includes) is not list:
self.includes = [includes]
else:
@@ -469,9 +537,9 @@ class BuildSystemFragmentComposer(object):
def compose(self, path):
return ''
-class SourceFileFragmentComposer(BuildSystemFragmentComposer):
- def __init__(self, cflags = "default", includes = None):
+class SourceFileFragmentComposer(BuildSystemFragmentComposer):
+ def __init__(self, cflags="default", includes=None):
self.cflags, self.includes = _cflagsIncludes(cflags, includes)
@@ -479,15 +547,17 @@ class SourceFileFragmentComposer(BuildSystemFragmentComposer):
flags = self.cflags
else:
flags = self.cflags + self.includes
- return ['sources', flags, ('default', None)], [path], self.cflags, self.includes
+ return ['sources', flags,
+ ('default', None)], [path], self.cflags, self.includes
-class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
- def __init__(self, headers, cflags = "default", includes = None):
+class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
+ def __init__(self, headers, cflags="default", includes=None):
if headers is not list:
headers = [headers]
self.headers = headers
- super(SourceFileIfHeaderComposer, self).__init__(cflags = cflags, includes = includes)
+ super(SourceFileIfHeaderComposer, self).__init__(cflags=cflags,
+ includes=includes)
r = SourceFileFragmentComposer.compose(self, path)
@@ -500,9 +570,15 @@ class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
r[0][2] = (define_keys.strip(), self.headers)
return r
-class TestFragementComposer(BuildSystemFragmentComposer):
- def __init__(self, testName, fileFragments, configTest = None, runTest = True, netTest = False, extraLibs = []):
+class TestFragementComposer(BuildSystemFragmentComposer):
+ testName,
+ fileFragments,
+ configTest=None,
+ runTest=True,
+ netTest=False,
+ extraLibs=[]):
self.testName = testName
self.fileFragments = fileFragments
self.configTest = configTest
@@ -511,21 +587,32 @@ class TestFragementComposer(BuildSystemFragmentComposer):
self.extraLibs = extraLibs
- return ['tests', self.testName, ('default', None)], { 'configTest': self.configTest,
- 'files': self.fileFragments,
- 'run': self.runTest,
- 'net': self.netTest,
- 'libs': self.extraLibs}
+ return ['tests', self.testName, ('default', None)], {
+ 'configTest': self.configTest,
+ 'files': self.fileFragments,
+ 'run': self.runTest,
+ 'net': self.netTest,
+ 'libs': self.extraLibs
-class TestIfHeaderComposer(TestFragementComposer):
- def __init__(self, testName, headers, fileFragments, runTest = True, netTest = False, extraLibs = []):
+class TestIfHeaderComposer(TestFragementComposer):
+ testName,
+ headers,
+ fileFragments,
+ runTest=True,
+ netTest=False,
+ extraLibs=[]):
headers = [headers]
- super(TestIfHeaderComposer, self).__init__(testName, fileFragments, 'header',
- runTest = runTest, netTest = netTest,
- extraLibs = extraLibs)
+ super(TestIfHeaderComposer, self).__init__(testName,
+ fileFragments,
+ 'header',
+ runTest=runTest,
+ netTest=netTest,
+ extraLibs=extraLibs)
r = TestFragementComposer.compose(self, path)
@@ -538,15 +625,24 @@ class TestIfHeaderComposer(TestFragementComposer):
return r
-class TestIfLibraryComposer(TestFragementComposer):
- def __init__(self, testName, libraries, fileFragments, runTest = True, netTest = False, extraLibs = []):
+class TestIfLibraryComposer(TestFragementComposer):
+ testName,
+ libraries,
+ fileFragments,
+ runTest=True,
+ netTest=False,
+ extraLibs=[]):
if libraries is not list:
libraries = [libraries]
self.libraries = libraries
- super(TestIfLibraryComposer, self).__init__(testName, fileFragments, 'library',
+ super(TestIfLibraryComposer, self).__init__(testName,
+ fileFragments,
+ 'library',
+ runTest=runTest,
+ netTest=netTest,
@@ -559,65 +655,71 @@ class TestIfLibraryComposer(TestFragementComposer):
r[0][2] = (define_keys.strip(), self.libraries)
return r
-class KVMSymbolsFragmentComposer(BuildSystemFragmentComposer):
+class KVMSymbolsFragmentComposer(BuildSystemFragmentComposer):
- return ['KVMSymbols', 'files', ('default', None)], [path], self.includes
+ return ['KVMSymbols', 'files',
+ ('default', None)], [path], self.includes
-class RPCGENFragmentComposer(BuildSystemFragmentComposer):
+class RPCGENFragmentComposer(BuildSystemFragmentComposer):
return ['RPCGen', 'files', ('default', None)], [path]
-class RouteKeywordsFragmentComposer(BuildSystemFragmentComposer):
+class RouteKeywordsFragmentComposer(BuildSystemFragmentComposer):
return ['RouteKeywords', 'files', ('default', None)], [path]
-class LexFragmentComposer(BuildSystemFragmentComposer):
- def __init__(self, sym, dep, cflags = None, includes = None, build = True):
+class LexFragmentComposer(BuildSystemFragmentComposer):
+ def __init__(self, sym, dep, cflags=None, includes=None, build=True):
self.sym = sym
self.dep = dep
self.build = build
- d = { 'file': path,
- 'sym': self.sym,
- 'dep': self.dep,
- 'build': self.build }
+ d = {
+ 'file': path,
+ 'sym': self.sym,
+ 'dep': self.dep,
+ 'build': self.build
if None not in self.cflags:
d['cflags'] = self.cflags
if None not in self.includes:
d['includes'] = self.includes
return ['lex', path, ('default', None)], d
-class YaccFragmentComposer(BuildSystemFragmentComposer):
- def __init__(self, sym, header, cflags = None, includes = None, build = True):
+class YaccFragmentComposer(BuildSystemFragmentComposer):
+ def __init__(self, sym, header, cflags=None, includes=None, build=True):
self.sym = sym
self.header = header
self.build = build
- 'sym': self.sym,
- 'header': self.header,
+ d = {
+ 'file': path,
+ 'sym': self.sym,
+ 'header': self.header,
return ['yacc', path, ('default', None)], d
# File - a file in the source we move backwards and forwards.
class File(object):
- def __init__(self, path, pathComposer,
- forwardConverter, reverseConverter, buildSystemComposer):
+ def __init__(self, path, pathComposer, forwardConverter, reverseConverter,
+ buildSystemComposer):
if verbose(verboseMoreDetail):
print("FILE: %-50s F:%-45s R:%-45s" % \
(path,
@@ -626,7 +728,8 @@ class File(object):
self.path = path
self.pathComposer = pathComposer
self.originPath = self.pathComposer.composeOriginPath(self.path)
- self.libbsdPath = self.pathComposer.composeLibBSDPath(self.path, LIBBSD_DIR)
+ self.libbsdPath = self.pathComposer.composeLibBSDPath(
+ self.path, LIBBSD_DIR)
self.forwardConverter = forwardConverter
self.reverseConverter = reverseConverter
self.buildSystemComposer = buildSystemComposer
@@ -634,7 +737,8 @@ class File(object):
def processSource(self, forward):
if forward:
if verbose(verboseDetail):
- print("process source: %s => %s" % (self.originPath, self.libbsdPath))
+ print("process source: %s => %s" %
+ (self.originPath, self.libbsdPath))
self.forwardConverter.convert(self.originPath, self.libbsdPath)
else:
@@ -643,13 +747,15 @@ class File(object):
self.reverseConverter.convert(self.libbsdPath, self.originPath)
def getFragment(self):
- return self.buildSystemComposer.compose(self.pathComposer.composeLibBSDPath(self.path, ''))
+ return self.buildSystemComposer.compose(
+ self.pathComposer.composeLibBSDPath(self.path, ''))
# Module - logical group of related files we can perform actions on
class Module(object):
- def __init__(self, manager, name, enabled = True):
+ def __init__(self, manager, name, enabled=True):
self.manager = manager
self.name = name
self.conditionalOn = "none"
@@ -670,7 +776,9 @@ class Module(object):
for f in files:
f.processSource(direction)
- def addFiles(self, newFiles, buildSystemComposer = BuildSystemFragmentComposer()):
+ def addFiles(self,
+ newFiles,
+ buildSystemComposer=BuildSystemFragmentComposer()):
files = []
for newFile in newFiles:
assertFile(newFile)
@@ -680,82 +788,92 @@ class Module(object):
def addFile(self, f):
self.files += [f]
- pathComposer, forwardConverter, reverseConverter,
- assertFile, buildSystemComposer = BuildSystemFragmentComposer()):
+ newFiles,
+ pathComposer,
+ forwardConverter,
+ reverseConverter,
+ assertFile,
files = []
assertFile(newFile)
- files += [File(newFile, pathComposer, forwardConverter,
- reverseConverter, buildSystemComposer)]
+ files += [
+ File(newFile, pathComposer, forwardConverter, reverseConverter,
return files
def addKernelSpaceHeaderFiles(self, files):
- self.files += self.addFiles(files,
- FreeBSDPathComposer(), FromFreeBSDToRTEMSHeaderConverter(),
- FromRTEMSToFreeBSDHeaderConverter(), assertHeaderOrSourceFile)
+ self.files += self.addFiles(files, FreeBSDPathComposer(),
+ FromFreeBSDToRTEMSHeaderConverter(),
+ FromRTEMSToFreeBSDHeaderConverter(),
+ assertHeaderOrSourceFile)
def addUserSpaceHeaderFiles(self, files):
- FreeBSDPathComposer(), FromFreeBSDToRTEMSUserSpaceHeaderConverter(),
- FromRTEMSToFreeBSDHeaderConverter(), assertHeaderFile)
+ files, FreeBSDPathComposer(),
+ FromFreeBSDToRTEMSUserSpaceHeaderConverter(),
+ FromRTEMSToFreeBSDHeaderConverter(), assertHeaderFile)
def addRTEMSHeaderFiles(self, files):
- self.files += self.addFiles(files, RTEMSPathComposer(),
- NoConverter(), NoConverter(), assertHeaderFile)
+ self.files += self.addFiles(files, RTEMSPathComposer(), NoConverter(),
+ NoConverter(), assertHeaderFile)
def addLinuxHeaderFiles(self, files):
- PathComposer(), NoConverter(),
+ self.files += self.addFiles(files, PathComposer(), NoConverter(),
def addCPUDependentFreeBSDHeaderFiles(self, files):
- CPUDependentFreeBSDPathComposer(), FromFreeBSDToRTEMSHeaderConverter(),
+ self.files += self.addFiles(files, CPUDependentFreeBSDPathComposer(),
+ assertHeaderFile)
def addCPUDependentLinuxHeaderFiles(self, files):
- CPUDependentLinuxPathComposer(), NoConverter(),
- NoConverter(), assertHeaderFile)
+ self.files += self.addFiles(files, CPUDependentLinuxPathComposer(),
+ NoConverter(), NoConverter(),
+ assertHeaderFile)
- def addTargetSourceCPUDependentHeaderFiles(self, targetCPUs, sourceCPU, files):
+ def addTargetSourceCPUDependentHeaderFiles(self, targetCPUs, sourceCPU,
+ files):
for cpu in targetCPUs:
- TargetSourceCPUDependentPathComposer(cpu, sourceCPU),
- FromFreeBSDToRTEMSHeaderConverter(),
+ files, TargetSourceCPUDependentPathComposer(cpu, sourceCPU),
+ FromFreeBSDToRTEMSHeaderConverter(), NoConverter(),
+ assertHeaderFile)
def addSourceFiles(self, files, sourceFileFragmentComposer):
- PathComposer(), NoConverter(), NoConverter(), assertSourceFile,
+ NoConverter(), assertSourceFile,
def addKernelSpaceSourceFiles(self, files, sourceFileFragmentComposer):
- FreeBSDPathComposer(), FromFreeBSDToRTEMSSourceConverter(),
- FromRTEMSToFreeBSDSourceConverter(), assertSourceFile,
+ FromFreeBSDToRTEMSSourceConverter(),
+ FromRTEMSToFreeBSDSourceConverter(),
+ assertSourceFile,
def addUserSpaceSourceFiles(self, files, sourceFileFragmentComposer):
- FromFreeBSDToRTEMSUserSpaceSourceConverter(),
- sourceFileFragmentComposer)
+ FromFreeBSDToRTEMSUserSpaceSourceConverter(),
+ FromRTEMSToFreeBSDSourceConverter(), assertSourceFile,
+ sourceFileFragmentComposer)
def addRTEMSSourceFiles(self, files, sourceFileFragmentComposer):
- RTEMSPathComposer(), NoConverter(), NoConverter(),
- assertSourceFile, sourceFileFragmentComposer)
def addLinuxSourceFiles(self, files, sourceFileFragmentComposer):
- def addCPUDependentFreeBSDSourceFiles(self, cpus, files, sourceFileFragmentComposer):
+ def addCPUDependentFreeBSDSourceFiles(self, cpus, files,
+ sourceFileFragmentComposer):
for cpu in cpus:
self.initCPUDependencies(cpu)
self.cpuDependentSourceFiles[cpu] += \
@@ -764,7 +882,8 @@ class Module(object):
- def addCPUDependentRTEMSSourceFiles(self, cpus, files, sourceFileFragmentComposer):
+ def addCPUDependentRTEMSSourceFiles(self, cpus, files,
for cpu in cpus:
@@ -773,7 +892,8 @@ class Module(object):
- def addCPUDependentLinuxSourceFiles(self, cpus, files, sourceFileFragmentComposer):
+ def addCPUDependentLinuxSourceFiles(self, cpus, files,
for cpu in cpus:
@@ -783,13 +903,15 @@ class Module(object):
def addTest(self, testFragementComposer):
- self.files += [File(testFragementComposer.testName,
- testFragementComposer)]
+ self.files += [
+ File(testFragementComposer.testName, PathComposer(), NoConverter(),
+ NoConverter(), testFragementComposer)
def addDependency(self, dep):
self.dependencies += [dep]
# Manager - a collection of modules.
@@ -850,9 +972,12 @@ class ModuleManager(object):
def setGenerators(self):
self.generator['convert'] = Converter
self.generator['no-convert'] = NoConverter
- self.generator['from-FreeBSD-to-RTEMS-UserSpaceSourceConverter'] = FromFreeBSDToRTEMSUserSpaceSourceConverter
- self.generator['from-RTEMS-To-FreeBSD-SourceConverter'] = FromRTEMSToFreeBSDSourceConverter
- self.generator['buildSystemFragmentComposer'] = BuildSystemFragmentComposer
+ self.generator[
+ 'from-FreeBSD-to-RTEMS-UserSpaceSourceConverter'] = FromFreeBSDToRTEMSUserSpaceSourceConverter
+ self.generator[
+ 'from-RTEMS-To-FreeBSD-SourceConverter'] = FromRTEMSToFreeBSDSourceConverter
+ self.generator[
+ 'buildSystemFragmentComposer'] = BuildSystemFragmentComposer
self.generator['file'] = File
@@ -860,7 +985,8 @@ class ModuleManager(object):
self.generator['freebsd-path'] = FreeBSDPathComposer
self.generator['rtems-path'] = RTEMSPathComposer
self.generator['cpu-path'] = CPUDependentFreeBSDPathComposer
- self.generator['target-src-cpu--path'] = TargetSourceCPUDependentPathComposer
+ self.generator[
+ 'target-src-cpu--path'] = TargetSourceCPUDependentPathComposer
self.generator['source'] = SourceFileFragmentComposer
self.generator['test'] = TestFragementComposer
diff --git a/waf_libbsd.py b/waf_libbsd.py
index 310a6924..bdd1cf4a 100644
--- a/waf_libbsd.py
+++ b/waf_libbsd.py
@@ -1,7 +1,10 @@
+'''LibBSD build configuration to waf integration module.
-# Copyright (c) 2015-2018 Chris Johns <chrisj at rtems.org>. All rights reserved.
-# Copyright (c) 2009-2015 embedded brains GmbH. All rights reserved.
+# Copyright (c) 2009, 2015 embedded brains GmbH. All rights reserved.
# Dornierstr. 4
@@ -9,30 +12,31 @@
# Germany
+# Copyright (c) 2012 OAR Corporation. All rights reserved.
-# are met:
+# are met:
# Python 3 does no longer know the basestring class. Catch that.
try:
basestring
@@ -55,12 +59,12 @@ if windows:
else:
host_shell = ''
# The waf builder for libbsd.
class Builder(builder.ModuleManager):
- def __init__(self, trace = False):
+ def __init__(self, trace=False):
super(Builder, self).__init__()
self.trace = trace
self.data = {}
@@ -82,7 +86,6 @@ class Builder(builder.ModuleManager):
return sources
def generate(self, rtems_version):
def _dataInsert(data, cpu, frag):
# The default handler returns an empty string. Skip it.
@@ -104,14 +107,14 @@ class Builder(builder.ModuleManager):
d[p] = {}
d = d[p]
if cpu not in d:
- d[cpu] = { }
+ d[cpu] = {}
config = frag[0][2][0]
if config != 'default':
if 'configure' not in data:
- data['configure'] = { }
+ data['configure'] = {}
configTest = frag[1]['configTest']
if configTest not in data['configure']:
- data['configure'][configTest] = { }
+ data['configure'][configTest] = {}
data['configure'][configTest][config] = frag[0][2][1]
if type(frag[1]) is list:
if config not in d[cpu]:
@@ -156,20 +159,19 @@ class Builder(builder.ModuleManager):
for cfg in self.data['configure'][configTest]:
if configTest == 'header':
for h in self.data['configure'][configTest][cfg]:
- conf.check(header_name = h,
- features = "c",
- includes = conf.env.IFLAGS,
- mandatory = False)
+ conf.check(header_name=h,
+ features="c",
+ includes=conf.env.IFLAGS,
+ mandatory=False)
elif configTest == 'library':
for l in self.data['configure'][configTest][cfg]:
- conf.check_cc(lib = l,
- fragment = rtems.test_application(),
- execute = False,
+ conf.check_cc(lib=l,
+ fragment=rtems.test_application(),
+ execute=False,
+ mandatory=False)
else:
bld.fatal('invalid config test: %s' % (configTest))
def build(self, bld):
# Localize the config.
@@ -240,16 +242,17 @@ class Builder(builder.ModuleManager):
# Network test configuration
if not os.path.exists(bld.env.NET_CONFIG):
- bld.fatal('network configuraiton \'%s\' not found' % (bld.env.NET_CONFIG))
- tags = [ 'NET_CFG_INTERFACE_0',
- 'NET_CFG_SELF_IP',
- 'NET_CFG_NETMASK',
- 'NET_CFG_PEER_IP',
- 'NET_CFG_GATEWAY_IP' ]
+ bld.fatal('network configuraiton \'%s\' not found' %
+ (bld.env.NET_CONFIG))
+ tags = [
+ 'NET_CFG_INTERFACE_0', 'NET_CFG_SELF_IP', 'NET_CFG_NETMASK',
+ 'NET_CFG_PEER_IP', 'NET_CFG_GATEWAY_IP'
try:
net_cfg_lines = open(bld.env.NET_CONFIG).readlines()
except:
- bld.fatal('network configuraiton \'%s\' read failed' % (bld.env.NET_CONFIG))
+ bld.fatal('network configuraiton \'%s\' read failed' %
lc = 0
sed = 'sed '
for l in net_cfg_lines:
@@ -264,10 +267,10 @@ class Builder(builder.ModuleManager):
for t in tags:
if lhs == t:
sed += "-e 's/@%s@/%s/' " % (t, rhs)
- bld(target = "testsuite/include/rtems/bsd/test/network-config.h",
- source = "testsuite/include/rtems/bsd/test/network-config.h.in",
- rule = sed + " < ${SRC} > ${TGT}",
- update_outputs = True)
+ bld(target="testsuite/include/rtems/bsd/test/network-config.h",
+ source="testsuite/include/rtems/bsd/test/network-config.h.in",
+ rule=sed + " < ${SRC} > ${TGT}",
+ update_outputs=True)
# Add a copy rule for all headers where the install path and the source
@@ -275,7 +278,8 @@ class Builder(builder.ModuleManager):
if 'header-paths' in config:
header_build_copy_paths = [
- hp for hp in config['header-paths'] if hp[2] != '' and not hp[0].endswith(hp[2])
+ hp for hp in config['header-paths']
+ if hp[2] != '' and not hp[0].endswith(hp[2])
for headers in header_build_copy_paths:
target = os.path.join(buildinclude, headers[2])
@@ -283,10 +287,10 @@ class Builder(builder.ModuleManager):
for header in start_dir.ant_glob(headers[1]):
relsourcepath = header.path_from(start_dir)
targetheader = os.path.join(target, relsourcepath)
- bld(features = 'subst',
- target = targetheader,
- source = header,
- is_copy = True)
+ bld(features='subst',
+ target=targetheader,
+ source=header,
+ is_copy=True)
# Generate a header that contains information about enabled modules
@@ -305,12 +309,13 @@ class Builder(builder.ModuleManager):
output += '#define RTEMS_BSD_MODULE_{} 1\n'.format(modname)
output += '#endif /* RTEMS_BSD_MODULES_H */\n'
self.outputs[0].write(output)
modules_h_file_with_path = os.path.join(buildinclude,
module_header_path,
module_header_name)
- bld(rule = rtems_libbsd_modules_h_gen,
- target = modules_h_file_with_path,
- before = ['c', 'cxx'])
+ bld(rule=rtems_libbsd_modules_h_gen,
+ target=modules_h_file_with_path,
+ before=['c', 'cxx'])
# Add the specific rule based builders
@@ -325,15 +330,15 @@ class Builder(builder.ModuleManager):
kvmsymbols_includes = kvmsymbols['files']['includes']
else:
kvmsymbols_includes = []
- bld(target = kvmsymbols['files']['all']['default'][0],
- source = 'rtemsbsd/rtems/generate_kvm_symbols',
- rule = host_shell + './${SRC} > ${TGT}',
- bld.objects(target = 'kvmsymbols',
- features = 'c',
- cflags = cflags,
- includes = kvmsymbols_includes + includes,
- source = kvmsymbols['files']['all']['default'][0])
+ bld(target=kvmsymbols['files']['all']['default'][0],
+ source='rtemsbsd/rtems/generate_kvm_symbols',
+ rule=host_shell + './${SRC} > ${TGT}',
+ bld.objects(target='kvmsymbols',
+ features='c',
+ cflags=cflags,
+ includes=kvmsymbols_includes + includes,
+ source=kvmsymbols['files']['all']['default'][0])
libbsd_use += ["kvmsymbols"]
bld.add_group()
@@ -345,9 +350,9 @@ class Builder(builder.ModuleManager):
if bld.env.AUTO_REGEN:
rpcgen = self.data['RPCGen']
rpcname = rpcgen['files']['all']['default'][0][:-2]
- bld(target = rpcname + '.h',
- source = rpcname + '.x',
- rule = host_shell + '${RPCGEN} -h -o ${TGT} ${SRC}')
+ bld(target=rpcname + '.h',
+ source=rpcname + '.x',
+ rule=host_shell + '${RPCGEN} -h -o ${TGT} ${SRC}')
# Route keywords
@@ -360,9 +365,7 @@ class Builder(builder.ModuleManager):
"awk 'BEGIN { r = 0 } { if (NF == 1) " + \
"printf \"#define\\tK_%%s\\t%%d\\n\\t{\\\"%%s\\\", K_%%s},\\n\", " + \
"toupper($1), ++r, $1, toupper($1)}' > ${TGT}"
- bld(target = rkwname + '.h',
- source = rkwname,
- rule = rkw_rule)
+ bld(target=rkwname + '.h', source=rkwname, rule=rkw_rule)
# Lex
@@ -382,16 +385,16 @@ class Builder(builder.ModuleManager):
lex_rule = host_shell + '${LEX} -P ' + lex['sym'] + ' -t ${SRC} | ' + \
'sed -e \'/YY_BUF_SIZE/s/16384/1024/\' > ${TGT}'
- bld(target = lex['file'][:-2]+ '.c',
- source = lex['file'],
- rule = lex_rule)
+ bld(target=lex['file'][:-2] + '.c',
+ source=lex['file'],
+ rule=lex_rule)
if lex['build']:
- bld.objects(target = 'lex_%s' % (lex['sym']),
- features = 'c',
- cflags = cflags,
- includes = lexIncludes + includes,
- defines = defines + lexDefines,
- source = lex['file'][:-2] + '.c')
+ bld.objects(target='lex_%s' % (lex['sym']),
+ features='c',
+ cflags=cflags,
+ includes=lexIncludes + includes,
+ defines=defines + lexDefines,
+ source=lex['file'][:-2] + '.c')
libbsd_use += ['lex_%s' % (lex['sym'])]
@@ -406,7 +409,8 @@ class Builder(builder.ModuleManager):
yaccSym = yacc['sym']
else:
yaccSym = os.path.basename(yaccFile)[:-2]
- yaccHeader = '%s/%s' % (os.path.dirname(yaccFile), yacc['header'])
+ yaccHeader = '%s/%s' % (os.path.dirname(yaccFile),
+ yacc['header'])
if 'cflags' in yacc:
yaccDefines = [d[2:] for d in yacc['cflags']]
else:
@@ -417,19 +421,20 @@ class Builder(builder.ModuleManager):
yaccIncludes = []
yacc_rule = host_shell + '${YACC} -b ' + yaccSym + \
' -d -p ' + yaccSym + ' ${SRC} && ' + \
- 'sed -e \'/YY_BUF_SIZE/s/16384/1024/\' < ' + yaccSym + '.tab.c > ${TGT} && ' + \
+ 'sed -e \'/YY_BUF_SIZE/s/16384/1024/\' < ' + \
'rm -f ' + yaccSym + '.tab.c && mv ' + yaccSym + '.tab.h ' + yaccHeader
- bld(target = yaccFile[:-2] + '.c',
- source = yaccFile,
- rule = yacc_rule)
+ bld(target=yaccFile[:-2] + '.c',
+ source=yaccFile,
+ rule=yacc_rule)
if yacc['build']:
- bld.objects(target = 'yacc_%s' % (yaccSym),
- features = 'c',
- cflags = cflags,
- includes = yaccIncludes + includes,
- defines = defines + yaccDefines,
- source = yaccFile[:-2] + '.c')
+ bld.objects(target='yacc_%s' % (yaccSym),
+ features='c',
+ cflags=cflags,
+ includes=yaccIncludes + includes,
+ defines=defines + yaccDefines,
+ source=yaccFile[:-2] + '.c')
libbsd_use += ['yacc_%s' % (yaccSym)]
@@ -452,12 +457,12 @@ class Builder(builder.ModuleManager):
for arch in archs:
if bld.get_env()['RTEMS_ARCH'] == arch:
bld_sources += Builder._sourceList(bld, build[arch])
- bld.objects(target = target,
- features = 'c',
- cflags = cflags + sorted(build.get('cflags', [])),
- includes = sorted(build.get('includes', [])) + includes,
- defines = defines,
- source = bld_sources)
+ bld.objects(target=target,
+ features='c',
+ cflags=cflags + sorted(build.get('cflags', [])),
+ includes=sorted(build.get('includes', [])) + includes,
+ defines=defines,
+ source=bld_sources)
libbsd_use += [target]
@@ -471,14 +476,14 @@ class Builder(builder.ModuleManager):
for arch in archs:
- bld.stlib(target = 'bsd',
- features = 'c cxx',
- cflags = cflags,
- cxxflags = cxxflags,
- includes = includes,
- source = bld_sources,
- use = libbsd_use)
+ bld.stlib(target='bsd',
+ features='c cxx',
+ cflags=cflags,
+ cxxflags=cxxflags,
+ includes=includes,
+ defines=defines,
+ source=bld_sources,
+ use=libbsd_use)
# Installs.
@@ -504,13 +509,13 @@ class Builder(builder.ModuleManager):
if start_dir != None:
bld.install_files("${PREFIX}/" + ipath,
start_dir.ant_glob(headers[1]),
- cwd = start_dir,
- relative_trick = True)
+ cwd=start_dir,
+ relative_trick=True)
bld.install_files(os.path.join("${PREFIX}", arch_inc_path,
module_header_path),
- cwd = bld.path)
+ cwd=bld.path)
# Tests
@@ -534,11 +539,11 @@ class Builder(builder.ModuleManager):
for f in test[cfg]['files']]
libs = test[cfg]['libs'] + libs
if build_test:
- bld.program(target = '%s.exe' % (testName),
- features = 'cprogram',
- cflags = cflags,
- source = test_sources,
- use = ['bsd'],
- lib = libs,
- install_path = None)
+ bld.program(target='%s.exe' % (testName),
+ features='cprogram',
+ cflags=cflags,
+ source=test_sources,
+ use=['bsd'],
+ lib=libs,
+ install_path=None)
diff --git a/wscript b/wscript
index faeb6b16..e9541327 100644
--- a/wscript
+++ b/wscript
@@ -1,28 +1,32 @@
-# RTEMS Project (https://www.rtems.org/)
+'''RTEMS LibBSD is a transparent source build of the FreeBSD kernel
+source for RTEMS.
+To use see README.waf shipped with this file.
-# are met:
+# are met:
# RTEMS LibBSD is a transparent source build of the FreeBSD kernel source for RTEMS.
@@ -57,6 +61,7 @@ builders = {}
BUILDSET_DIR = "buildset"
BUILDSET_DEFAULT = "buildset/default.ini"
def load_ini(conf, f):
ini = configparser.ConfigParser()
ini.read(f)
@@ -73,8 +78,9 @@ def load_ini(conf, f):
elif os.path.isfile(os.path.join(BUILDSET_DIR, extends)):
extendfile = os.path.join(BUILDSET_DIR, extends)
else:
- conf.fatal("'{}': Invalid file given for general/extends:'{}'"
- .format(f, extends))
+ conf.fatal(
+ "'{}': Invalid file given for general/extends:'{}'".format(
+ f, extends))
base = load_ini(conf, extendfile)
for s in ini.sections():
if not base.has_section(s):
@@ -85,6 +91,7 @@ def load_ini(conf, f):
ini = base
return ini
def load_config(conf, f):
ini = load_ini(conf, f)
config = {}
@@ -100,6 +107,7 @@ def load_config(conf, f):
config['modules-enabled'].append(mod)
return config
def update_builders(ctx, buildset_opt):
global builders
builders = {}
@@ -111,7 +119,7 @@ def update_builders(ctx, buildset_opt):
if os.path.isdir(bs):
for f in os.listdir(bs):
if f[-4:] == ".ini":
- buildsets += [os.path.join(bs,f)]
+ buildsets += [os.path.join(bs, f)]
else:
for f in bs.split(','):
buildsets += [f]
@@ -123,7 +131,8 @@ def update_builders(ctx, buildset_opt):
bsname = bsconfig['name']
builder.updateConfiguration(bsconfig)
builder.generate(rtems_version)
- builders[bsname]=builder
+ builders[bsname] = builder
def bsp_init(ctx, env, contexts):
# This function generates the builders and adds build-xxx, clean-xxx and
@@ -143,6 +152,7 @@ def bsp_init(ctx, env, contexts):
for y in contexts:
newcmd = y.cmd + '-' + builder
newvariant = y.variant + '-' + builder
class context(y):
cmd = str(newcmd)
variant = str(newvariant)
@@ -158,49 +168,66 @@ def bsp_init(ctx, env, contexts):
commands += [str(cmd)]
waflib.Options.commands = commands
def init(ctx):
- rtems.init(ctx, version = rtems_version, long_commands = True,
- bsp_init = bsp_init)
+ rtems.init(ctx,
+ version=rtems_version,
+ long_commands=True,
+ bsp_init=bsp_init)
def options(opt):
rtems.options(opt)
opt.add_option("--enable-auto-regen",
- action = "store_true",
- default = False,
- dest = "auto_regen",
- help = "Enable auto-regeneration of LEX, RPC and YACC files.")
+ action="store_true",
+ default=False,
+ dest="auto_regen",
+ help="Enable auto-regeneration of LEX, RPC and YACC files.")
opt.add_option("--enable-warnings",
- default = False,
- dest = "warnings",
- help = "Enable all warnings. The default is quiet builds.")
+ default=False,
+ dest="warnings",
+ help="Enable all warnings. The default is quiet builds.")
opt.add_option("--net-test-config",
- default = "config.inc",
- dest = "net_config",
- help = "Network test configuration.")
+ default="config.inc",
+ dest="net_config",
+ help="Network test configuration.")
opt.add_option("--freebsd-options",
- action = "store",
- default = "",
- dest = "freebsd_options",
- help = "Set FreeBSD options (developer option).")
- opt.add_option("--optimization",
- action = "store",
- default = "2",
- dest = "optimization",
- help = "Set optimization level to OPTIMIZATION (-On compiler flag). Default is 2 (-O2).")
- opt.add_option("--buildset",
- action = "append",
- default = [],
- dest = "buildset",
- help = "Select build sets to build. If set to a directory, all .ini file in this directory will be used.")
+ action="store",
+ default="",
+ dest="freebsd_options",
+ help="Set FreeBSD options (developer option).")
+ opt.add_option(
+ "--optimization",
+ action="store",
+ default="2",
+ dest="optimization",
+ help=
+ "Set optimization level to OPTIMIZATION (-On compiler flag). Default is 2 (-O2)."
+ opt.add_option(
+ "--buildset",
+ action="append",
+ default=[],
+ dest="buildset",
+ help=
+ "Select build sets to build. If set to a directory," \
+ " all .ini file in this directory will be used."
def bsp_configure(conf, arch_bsp):
- conf.check(header_name = "dlfcn.h", features = "c")
- conf.check(header_name = "rtems/pci.h", features = "c", mandatory = False)
+ conf.check(header_name="dlfcn.h", features="c")
+ conf.check(header_name="rtems/pci.h", features="c", mandatory=False)
if not rtems.check_posix(conf):
- conf.fatal("RTEMS kernel POSIX support is disabled; configure RTEMS with --enable-posix")
+ conf.fatal(
+ "RTEMS kernel POSIX support is disabled; configure RTEMS with --enable-posix"
if rtems.check_networking(conf):
- conf.fatal("RTEMS kernel contains the old network support; configure RTEMS with --disable-networking")
+ conf.fatal(
+ "RTEMS kernel contains the old network support;" \
+ " configure RTEMS with --disable-networking"
env = conf.env.derive()
for builder in builders:
ab = conf.env.RTEMS_ARCH_BSP
@@ -210,15 +237,16 @@ def bsp_configure(conf, arch_bsp):
builders[builder].bsp_configure(conf, arch_bsp)
conf.setenv(ab)
def configure(conf):
if conf.options.auto_regen:
- conf.find_program("lex", mandatory = True)
- conf.find_program("rpcgen", mandatory = True)
- conf.find_program("yacc", mandatory = True)
+ conf.find_program("lex", mandatory=True)
+ conf.find_program("rpcgen", mandatory=True)
+ conf.find_program("yacc", mandatory=True)
conf.env.AUTO_REGEN = conf.options.auto_regen
conf.env.WARNINGS = conf.options.warnings
conf.env.NET_CONFIG = conf.options.net_config
- conf.env.FREEBSD_OPTIONS =conf.options.freebsd_options
+ conf.env.FREEBSD_OPTIONS = conf.options.freebsd_options
conf.env.OPTIMIZATION = conf.options.optimization
conf.env.BUILDSET = conf.options.buildset
if len(conf.env.BUILDSET) == 0:
@@ -226,6 +254,11 @@ def configure(conf):
update_builders(conf, conf.env.BUILDSET)
rtems.configure(conf, bsp_configure)
+def test(bld):
+ rtems.test_uninstall(bld)
def build(bld):
rtems.build(bld)
builders[bld.libbsd_buildset_name].build(bld)
2.24.1
