[PATCH] cpukit/libmisc/capture: Fix unaligned pointer value warning
Aschref Ben-Thabet aschref.ben-thabet at embedded-brains.de
Tue Sep 15 09:04:22 UTC 2020
From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
Change the function ctrace_task_name_add() to take the variable name as
a value instead a pointer.
It avoids the warning and solve the issue.
 cpukit/libmisc/capture/capture_support.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/cpukit/libmisc/capture/capture_support.c b/cpukit/libmisc/capture/capture_support.c
index 4af8822c79..0877a70160 100644
--- a/cpukit/libmisc/capture/capture_support.c
+++ b/cpukit/libmisc/capture/capture_support.c
@@ -81,7 +81,7 @@ static ctrace_tasks tasks;
  * Add a name.
 static void
-ctrace_task_name_add (rtems_id id, const rtems_name* name)
+ctrace_task_name_add (rtems_id id, const rtems_name name)
   if (tasks.tasks == NULL)
@@ -97,7 +97,7 @@ ctrace_task_name_add (rtems_id id, const rtems_name* name)
         if (tasks.tasks[t].id == id)
-          tasks.tasks[t].name = *name;
+          tasks.tasks[t].name = name;
           break;
@@ -111,7 +111,7 @@ ctrace_task_name_add (rtems_id id, const rtems_name* name)
         if (tasks.tasks != NULL)
-          tasks.tasks[tasks.count].name = *name;
+          tasks.tasks[tasks.count].name = name;
           tasks.tasks[tasks.count].id = id;
           ++tasks.count;
@@ -349,7 +349,7 @@ rtems_capture_print_trace_records (int total, bool csv)
         cpu->recs = rtems_capture_record_extract (cpu->recs,
                                                   &task_rec,
                                                   sizeof (task_rec));
-        ctrace_task_name_add (rec_out->task_id, &task_rec.name);
+        ctrace_task_name_add(rec_out->task_id, task_rec.name);
         rtems_capture_print_record_task (cpu_out, rec_out, &task_rec);
       else
2.26.2
