[PATCH] cpukit/libmisc/shell/shell.c: Fix restrict warning
Aschref Ben-Thabet
aschref.ben-thabet at embedded-brains.de
Tue Sep 15 09:06:36 UTC 2020
From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
Replace the unsafe function strcpy() with memmove() to avoid the string
restrict warning.
Since memmove() function is used to copy a specified number of bytes
from one memory to another or to overlap on same memory.
cpukit/libmisc/shell/shell.c | 10 +++++-----
1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 13ae411f9c..36eac3d14f 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -393,7 +393,7 @@ static int rtems_shell_line_editor(
int end;
int bs;
- strcpy (&line[col], &line[col + 1]);
+ memmove(line + col, line + col + 1, strlen(line + col + 1) + 1);
if (output) {
fprintf(out,"\r%s%s ", prompt, line);
end = (int) strlen (line);
@@ -432,7 +432,7 @@ static int rtems_shell_line_editor(
case 4: /* Control-D */
if (strlen(line)) {
if (col < strlen(line)) {
- strcpy (line + col, line + col + 1);
if (output) {
int bs;
fprintf(out,"%s \b", line + col);
@@ -508,7 +508,7 @@ static int rtems_shell_line_editor(
int bs;
col--;
+ memmove(line + col, line + col + 1, strlen(line + col + 1));
if (output) {
fprintf(out,"\b%s \b", line + col);
for (bs = 0; bs < ((int) strlen (line) - col); bs++)
@@ -620,9 +620,9 @@ static int rtems_shell_line_editor(
case 21: /* Control-U */
if (col > 0)
- int clen = strlen (line);
+ size_t clen = strlen (line);
- strcpy (line, line + col);
+ memmove(line, line + col, strlen(line + col) + 1);
if (output) {
fprintf(out,"\r%s%*c", prompt, clen, ' ');
fprintf(out,"\r%s%s", prompt, line);
2.26.2
