[PATCH 6-freebsd-12 3/4] build: Separate the kernel and user land include paths
Tue Sep 15 14:48:25 UTC 2020
On Mon, Sep 14, 2020 at 9:33 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Provide support for separate user and kernel include paths in
>   libbsd.py.
> - Update all added files with a suitable context to build them
>   with. Supported contexts are `kernel` and `user`.
> - Kernel source use the kernel, CPU, and build header paths in
>   this order.
> - User source use the user, kernel, CPU and build header paths
>   in this order. The FreeBSD /usr/include tree has some kernel
>   header files installed as well as user land header files. This
>   complicates the separation as some kernel header files are not
>   visible to user land code while other are. This is handled by
>   appeanding the kernel header paths to the user header paths so
^^^ appending
Otherwise, I am just asking does Python code need to pass. pylint
and yapf are mentioned in this thread but
https://books.agiliq.com/projects/essential-python-tools/en/latest/linters.html
has a list of tools and claims that pycodelint matches pep8. I thought we
were trying to follow pep8.
It also mentions pyflake which sounds useful.
What is the recommended set of tools to pass and with what settings?
I know we aren't completely passing on all Python code but what's the
objective from a tool checking viewpoint.
>   user land code will include a user header with the same name as
>   a kernel header over the kernel header but will find a kernel
>   header if there is no matching user header file.
> Closes #4067
>  builder.py           | 339 +++++++++++++++------------
>  buildset/default.ini |   2 +
>  freebsd-to-rtems.py  |  12 +
>  libbsd.py            | 530 ++++++++++++++++++++++++-------------------
>  waf_libbsd.py        | 165 ++++++++------
>  wscript              |   4 +-
>  6 files changed, 614 insertions(+), 438 deletions(-)
> diff --git a/builder.py b/builder.py
> index 9dfe373f..46e19b6a 100755
> --- a/builder.py
> +++ b/builder.py
> @@ -1,6 +1,6 @@
>  # SPDX-License-Identifier: BSD-2-Clause
> -'''Manage the libbsd build configuration data.
> +"""Manage the libbsd build configuration data.
>  # Copyright (c) 2015, 2020 Chris Johns <chrisj at rtems.org>. All rights
> reserved.
> @@ -35,15 +35,12 @@
>  from __future__ import print_function
> -import shutil
> +import codecs
> +import copy
> +import difflib
>  import os
>  import re
>  import sys
> -import getopt
> -import filecmp
> -import difflib
> -import codecs
> -import copy
>  # Global controls.
> @@ -67,21 +64,6 @@ verboseMoreDetail = 3
>  verboseDebug = 4
> -def _cflagsIncludes(cflags, includes):
> -    if type(cflags) is not list:
> -        if cflags is not None:
> -            _cflags = cflags.split(' ')
> -        else:
> -            _cflags = [None]
> -    else:
> -        _cflags = cflags
> -    if type(includes) is not list:
> -        _includes = [includes]
> -    else:
> -        _includes = includes
> -    return _cflags, _includes
>  def verbose(level=verboseInfo):
>      return verboseLevel >= level
> @@ -527,7 +509,7 @@ class
> TargetSourceCPUDependentPathComposer(CPUDependentFreeBSDPathComposer):
>          return path
> -class BuildSystemFragmentComposer(object):
> +class BuildSystemComposer(object):
>      def __init__(self, includes=None):
>              self.includes = [includes]
> @@ -537,7 +519,7 @@ class BuildSystemFragmentComposer(object):
>      def __str__(self):
>          return ''
> -    def get_includes(self):
> +    def getIncludes(self):
>          if None in self.includes:
>              incs = []
>          else:
> @@ -545,52 +527,70 @@ class BuildSystemFragmentComposer(object):
>          return incs
>      def compose(self, path):
> -        return ''
> +        """A None result means there is nothing to build."""
> +        return None
> +    @staticmethod
> +    def filesAsDefines(files):
> +        define_keys = ''
> +        for f in files:
> +            f = f.upper()
> +            for c in '\/-.':
> +                f = f.replace(c, '_')
> +            define_keys += ' ' + f
> +        return define_keys.strip()
> +    @staticmethod
> +    def cflagsIncludes(cflags, includes):
> +        if type(cflags) is not list:
> +            if cflags is not None:
> +                _cflags = cflags.split(' ')
> +            else:
> +                _cflags = [None]
> +        else:
> +            _cflags = cflags
> +        if type(includes) is not list:
> +            _includes = [includes]
> +        else:
> +            _includes = includes
> +        return _cflags, _includes
> -class SourceFileFragmentComposer(BuildSystemFragmentComposer):
> +class SourceFileBuildComposer(BuildSystemComposer):
>      def __init__(self, cflags="default", includes=None):
> -        self.cflags, self.includes = _cflagsIncludes(cflags, includes)
> -    def _get_flags(self):
> -        return self.cflags + self.get_includes()
> +        self.cflags, self.includes = self.cflagsIncludes(cflags, includes)
>      def __str__(self):
> -        return 'SF: ' + ' '.join(self._get_flags())
> +        return 'SF: ' + ' '.join(self.getFlags())
> -        flags = self._get_flags()
> -        return ['sources', flags,
> -                ('default', None)], [path], self.cflags, self.includes
> +        flags = self.getFlags()
> +        return ['sources', flags, ('default', None)], \
> +            [path], self.cflags, self.includes
> +    def getFlags(self):
> +        return self.cflags + self.getIncludes()
> -class SourceFileIfHeaderComposer(SourceFileFragmentComposer):
> +class SourceFileIfHeaderComposer(SourceFileBuildComposer):
>      def __init__(self, headers, cflags="default", includes=None):
>          if headers is not list:
>              headers = [headers]
>          self.headers = headers
>          super(SourceFileIfHeaderComposer, self).__init__(cflags=cflags,
> includes=includes)
>      def __str__(self):
> -        incs = self.headers + self.get_includes
> -        if len(incs) > 0:
> -            return 'SFIH:' + ' '.join(incs)
> -        else:
> -            return ''
> +        return 'SFIH:' + ' '.join(self.getFlags()) + \
> +            ' ' + self.filesAsDefines(self.headers)
> -        r = SourceFileFragmentComposer.compose(self, path)
> -        define_keys = ''
> -        for h in self.headers:
> -            h = h.upper()
> -            for c in '\/-.':
> -                h = h.replace(c, '_')
> -            define_keys += ' ' + h
> -        r[0][2] = (define_keys.strip(), self.headers)
> +        r = SourceFileBuildComposer.compose(self, path)
> +        r[0][2] = (self.filesAsDefines(self.headers), self.headers)
>          return r
> -class TestFragementComposer(BuildSystemFragmentComposer):
> +class TestFragementComposer(BuildSystemComposer):
>      def __init__(self,
>                   testName,
>                   fileFragments,
> @@ -638,13 +638,7 @@ class TestIfHeaderComposer(TestFragementComposer):
>          r = TestFragementComposer.compose(self, path)
> -        define_keys = ''
> -            h = h.upper()
> -            for c in '\/-.':
>          return r
> @@ -668,37 +662,33 @@ class TestIfLibraryComposer(TestFragementComposer):
> -        define_keys = ''
> -        for l in self.libraries:
> -            l = l.upper()
> -            for c in '\/-.':
> -                l = l.replace(c, '_')
> -            define_keys += ' ' + l
> -        r[0][2] = (define_keys.strip(), self.libraries)
> +        r[0][2] = (self.filesAsDefines(self.libraries), self.libraries)
>          return r
> -class KVMSymbolsFragmentComposer(BuildSystemFragmentComposer):
> +class KVMSymbolsBuildComposer(BuildSystemComposer):
> -        return ['KVMSymbols', 'files',
> -                ('default', None)], [path], self.includes
> +        return ['KVMSymbols', 'files', ('default', None)], \
> +            [path], self.includes
> -class RPCGENFragmentComposer(BuildSystemFragmentComposer):
> +class RPCGENBuildComposer(BuildSystemComposer):
> -        return ['RPCGen', 'files', ('default', None)], [path]
> +        return ['RPCGen', 'files', ('default', None)], \
> +            [path]
> -class RouteKeywordsFragmentComposer(BuildSystemFragmentComposer):
> +class RouteKeywordsBuildComposer(BuildSystemComposer):
> -        return ['RouteKeywords', 'files', ('default', None)], [path]
> +        return ['RouteKeywords', 'files', ('default', None)], \
> +            [path]
> -class LexFragmentComposer(BuildSystemFragmentComposer):
> +class LexBuildComposer(BuildSystemComposer):
>      def __init__(self, sym, dep, cflags=None, includes=None, build=True):
>          self.sym = sym
>          self.dep = dep
>          self.build = build
> @@ -715,11 +705,11 @@ class
>          return ['lex', path, ('default', None)], d
> -class YaccFragmentComposer(BuildSystemFragmentComposer):
> +class YaccBuildComposer(BuildSystemComposer):
>      def __init__(self, sym, header, cflags=None, includes=None,
> build=True):
>          self.sym = sym
>          self.header = header
>          self.build = build
> @@ -738,14 +728,14 @@ class
>  class File(object):
>      '''A file of source we move backwards and forwards and build.'''
> -    def __init__(self, path, pathComposer, forwardConverter,
> reverseConverter,
> -                 buildSystemComposer):
> +    def __init__(self, space, path, pathComposer, forwardConverter,
> +                 reverseConverter, buildSystemComposer):
>          if verbose(verboseMoreDetail):
> -            print("FILE: %-50s F:%-45s R:%-45s" % \
> -                  (path,
> +            print("FILE: %-6s %-50s F:%-45s R:%-45s" % \
> +                  (space, path,
>                     forwardConverter.__class__.__name__,
>                     reverseConverter.__class__.__name__))
> +        self.space = space
>          self.path = path
>          self.pathComposer = pathComposer
>          self.originPath = self.pathComposer.composeOriginPath(self.path)
> @@ -756,12 +746,22 @@ class File(object):
>          self.buildSystemComposer = buildSystemComposer
>      def __str__(self):
> -        out = self.path
> +        out = self.space[0].upper() + ' ' + self.path
>          bsc = str(self.buildSystemComposer)
>          if len(bsc) > 0:
>              out += ' (' + bsc + ')'
>          return out
> +    def __eq__(self, other):
> +        state = self.space == other.space
> +        state = state and (self.path == self.path)
> +        state = state and (self.pathComposer == self.pathComposer)
> +        state = state and (self.originPath == self.originPath)
> +        state = state and (self.forwardConverter == self.forwardConverter)
> +        state = state and (self.self.reverseConverter ==
> self.self.reverseConverter)
> +        state = state and (self.buildSystemComposer ==
> +        return state
>      def processSource(self, forward):
>          if forward:
>              if verbose(verboseDetail):
> @@ -771,17 +771,23 @@ class File(object):
>          else:
>                  print("process source: %s => %s converter:%s" % \
> -                      (self.libbsdPath, self.originPath,
> self.reverseConverter.__class__.__name__))
> +                      (self.libbsdPath, self.originPath,
> +                       self.reverseConverter.__class__.__name__))
>              self.reverseConverter.convert(self.libbsdPath,
> self.originPath)
>      def getFragment(self):
>          return self.buildSystemComposer.compose(
>              self.pathComposer.composeLibBSDPath(self.path, ''))
> +    def getPath(self):
> +        return self.path
> +    def getSpace(self):
> +        return self.space
>  class Module(object):
>      '''Logical group of related files we can perform actions on'''
>      def __init__(self, manager, name, enabled=True):
>          self.manager = manager
>          self.name = name
> @@ -791,23 +797,42 @@ class Module(object):
>          self.dependencies = []
>      def __str__(self):
> -        out = [self.name + ': ' + self.conditionalOn]
> +        out = [self.name + ': conditional-on=' + self.conditionalOn]
>          if len(self.dependencies) > 0:
>              out += [' Deps: ' + str(len(self.dependencies))]
>              out += ['  ' + type(d).__name__ for d in self.dependencies]
>          if len(self.files) > 0:
> -            out += [' Files: ' + str(len(self.files))]
> +            counts = {}
> +            for f in self.files:
> +                space = f.getSpace()
> +                if space not in counts:
> +                    counts[space] = 0
> +                counts[space] += 1
> +            count_str = ''
> +            for space in sorted(counts.keys()):
> +                count_str += '%s:%d ' % (space[0].upper(), counts[space])
> +            count_str = count_str[:-1]
> +            out += [' Files: %d (%s)' % (len(self.files), count_str)]
>              out += ['  ' + str(f) for f in self.files]
>          if len(self.cpuDependentSourceFiles) > 0:
>              out += [' CPU Dep: ' + str(len(self.cpuDependentSourceFiles))]
>              for cpu in self.cpuDependentSourceFiles:
> -                out += ['  ' + cpu + ':' + str(f) for f in
> self.cpuDependentSourceFiles[cpu]]
> +                out += ['  ' + cpu + ':']
> +                out += [
> +                    '   ' + str(f) for f in
>          return os.linesep.join(out)
>      def initCPUDependencies(self, cpu):
>          if cpu not in self.cpuDependentSourceFiles:
>              self.cpuDependentSourceFiles[cpu] = []
> +    def getName(self):
> +        return self.name
> +    def getFiles(self):
> +        return (f for f in self.files)
>      def processSource(self, direction):
>              print("process module: %s" % (self.name))
> @@ -818,52 +843,64 @@ class Module(object):
>                  f.processSource(direction)
>      def addFile(self, f):
> +        if not isinstance(f, File):
> +            raise TypeError('invalid type for addFiles: %s' % (type(f)))
>          self.files += [f]
>      def addFiles(self,
> +                 space,
>                   newFiles,
>                   pathComposer,
>                   forwardConverter,
>                   reverseConverter,
>                   assertFile,
> -                 buildSystemComposer=BuildSystemFragmentComposer()):
> +                 buildSystemComposer=BuildSystemComposer()):
>          files = []
>          for newFile in newFiles:
>              assertFile(newFile)
>              files += [
> -                File(newFile, pathComposer, forwardConverter,
> reverseConverter,
> +                File(space, newFile, pathComposer, forwardConverter,
>          return files
> +    def addPlainTextFile(self, files):
> +        self.files += self.addFiles('user', files,
> +                                    FreeBSDPathComposer(), Converter(),
> +                                    Converter(), assertNothing)
>      def addKernelSpaceHeaderFiles(self, files):
> -        self.files += self.addFiles(files, FreeBSDPathComposer(),
> +        self.files += self.addFiles('kernel', files,
>                                      FromFreeBSDToRTEMSHeaderConverter(),
>                                      FromRTEMSToFreeBSDHeaderConverter(),
>                                      assertHeaderOrSourceFile)
>      def addUserSpaceHeaderFiles(self, files):
> -            files, FreeBSDPathComposer(),
> +            'user', files, FreeBSDPathComposer(),
>              FromFreeBSDToRTEMSUserSpaceHeaderConverter(),
>              FromRTEMSToFreeBSDHeaderConverter(), assertHeaderFile)
>      def addRTEMSHeaderFiles(self, files):
> -        self.files += self.addFiles(files, RTEMSPathComposer(),
> NoConverter(),
> -                                    NoConverter(), assertHeaderFile)
> +        self.files += self.addFiles('user', files, RTEMSPathComposer(),
> +                                    NoConverter(), NoConverter(),
> +                                    assertHeaderFile)
>      def addLinuxHeaderFiles(self, files):
> -        self.files += self.addFiles(files, PathComposer(), NoConverter(),
> +        self.files += self.addFiles('kernel', files, PathComposer(),
> +                                    assertHeaderFile)
>      def addCPUDependentFreeBSDHeaderFiles(self, files):
> CPUDependentFreeBSDPathComposer(),
> +                                    CPUDependentFreeBSDPathComposer(),
>                                      assertHeaderFile)
>      def addCPUDependentLinuxHeaderFiles(self, files):
> CPUDependentLinuxPathComposer(),
> +                                    CPUDependentLinuxPathComposer(),
>                                      assertHeaderFile)
> @@ -871,73 +908,80 @@ class Module(object):
>                                                 files):
>          for cpu in targetCPUs:
> -                files, TargetSourceCPUDependentPathComposer(cpu,
> sourceCPU),
> +                'kernel', files,
> +                TargetSourceCPUDependentPathComposer(cpu, sourceCPU),
>                  FromFreeBSDToRTEMSHeaderConverter(), NoConverter(),
>                  assertHeaderFile)
> -    def addSourceFiles(self, files, sourceFileFragmentComposer):
> +    def addSourceFiles(self, files, sourceFileBuildComposer):
> +                                    files, PathComposer(), NoConverter(),
>                                      NoConverter(), assertSourceFile,
> -                                    sourceFileFragmentComposer)
> +                                    sourceFileBuildComposer)
> -    def addKernelSpaceSourceFiles(self, files,
> +    def addKernelSpaceSourceFiles(self, files, sourceFileBuildComposer):
>                                      FromFreeBSDToRTEMSSourceConverter(),
>                                      FromRTEMSToFreeBSDSourceConverter(),
> -                                    assertSourceFile,
> +                                    assertSourceFile,
> -    def addUserSpaceSourceFiles(self, files, sourceFileFragmentComposer):
> +    def addUserSpaceSourceFiles(self, files, sourceFileBuildComposer):
>              FromFreeBSDToRTEMSUserSpaceSourceConverter(),
>              FromRTEMSToFreeBSDSourceConverter(), assertSourceFile,
> -    def addRTEMSSourceFiles(self, files, sourceFileFragmentComposer):
> NoConverter(),
> -                                    NoConverter(), assertSourceFile,
> +    def addRTEMSKernelSourceFiles(self, files, sourceFileBuildComposer):
> +        self.files += self.addFiles('kernel', files, RTEMSPathComposer(),
> +                                    assertSourceFile,
> -    def addLinuxSourceFiles(self, files, sourceFileFragmentComposer):
> +    def addRTEMSUserSourceFiles(self, files, sourceFileBuildComposer):
> +                                    assertSourceFile,
> +    def addLinuxSourceFiles(self, files, sourceFileBuildComposer):
> +                                    assertSourceFile,
>      def addCPUDependentFreeBSDSourceFiles(self, cpus, files,
> -                                          sourceFileFragmentComposer):
> +                                          sourceFileBuildComposer):
>          for cpu in cpus:
>              self.initCPUDependencies(cpu)
>              self.cpuDependentSourceFiles[cpu] += \
> -                self.addFiles(files,
> -                              CPUDependentFreeBSDPathComposer(),
> -                              FromRTEMSToFreeBSDSourceConverter(),
> assertSourceFile,
> +                self.addFiles(
> +                    'kernel', files,
> +                    FromRTEMSToFreeBSDSourceConverter(), assertSourceFile,
>      def addCPUDependentRTEMSSourceFiles(self, cpus, files,
>          for cpu in cpus:
> +                self.addFiles('kernel', files,
>                                CPUDependentRTEMSPathComposer(),
> NoConverter(),
>      def addCPUDependentLinuxSourceFiles(self, cpus, files,
>          for cpu in cpus:
> NoConverter(),
>      def addTest(self, testFragementComposer):
>          self.files += [
> -            File(testFragementComposer.testName, PathComposer(),
> NoConverter(),
> -                 NoConverter(), testFragementComposer)
> +            File('user', testFragementComposer.testName, PathComposer(),
> +                 NoConverter(), NoConverter(), testFragementComposer)
>      def addDependency(self, dep):
> @@ -946,7 +990,6 @@ class Module(object):
>  class ModuleManager(object):
>      '''A manager for a collection of modules.'''
>      def __init__(self):
>          self.modules = {}
>          self.generator = {}
> @@ -987,7 +1030,7 @@ class ModuleManager(object):
>          self.configuration = copy.deepcopy(config)
>      def getConfiguration(self):
> -        return self.configuration
> +        return copy.deepcopy(self.configuration)
>      def updateConfiguration(self, config):
>          self.configuration.update(config)
> @@ -1004,17 +1047,33 @@ class ModuleManager(object):
>          if only_enabled == False:
>              modules_to_process = self.getAllModules()
>          for m in modules_to_process:
> +            if m not in self.modules:
> +                raise KeyError('enabled module not registered: %s' % (m))
>              self.modules[m].generate()
> +    def duplicateCheck(self):
> +        dups = []
> +        modules_to_check = sorted(self.getAllModules(), reverse=True)
> +        while len(modules_to_check) > 1:
> +            mod = modules_to_check.pop()
> +            for m in modules_to_check:
> (m))
> +                for fmod in self.modules[mod].getFiles():
> +                    for fm in self.modules[m].getFiles():
> +                        if fmod.getPath() == fm.getPath():
> +                            dups += [(m, mod, fm.getPath(),
> fm.getSpace())]
> +        return dups
>      def setGenerators(self):
>          self.generator['convert'] = Converter
>          self.generator['no-convert'] = NoConverter
>          self.generator[
> -            'from-FreeBSD-to-RTEMS-UserSpaceSourceConverter'] =
> +            'from-FreeBSD-to-RTEMS-UserSpaceSourceConverter'] = \
> +                FromFreeBSDToRTEMSUserSpaceSourceConverter
>          self.generator[
>              'from-RTEMS-To-FreeBSD-SourceConverter'] =
> -        self.generator[
> -            'buildSystemFragmentComposer'] = BuildSystemFragmentComposer
> +        self.generator['buildSystemComposer'] = BuildSystemComposer
>          self.generator['file'] = File
> @@ -1025,13 +1084,13 @@ class ModuleManager(object):
>          self.generator[
>              'target-src-cpu--path'] = TargetSourceCPUDependentPathComposer
> -        self.generator['source'] = SourceFileFragmentComposer
> +        self.generator['source'] = SourceFileBuildComposer
>          self.generator['test'] = TestFragementComposer
> -        self.generator['kvm-symbols'] = KVMSymbolsFragmentComposer
> -        self.generator['rpc-gen'] = RPCGENFragmentComposer
> -        self.generator['route-keywords'] = RouteKeywordsFragmentComposer
> -        self.generator['lex'] = LexFragmentComposer
> -        self.generator['yacc'] = YaccFragmentComposer
> +        self.generator['kvm-symbols'] = KVMSymbolsBuildComposer
> +        self.generator['rpc-gen'] = RPCGENBuildComposer
> +        self.generator['route-keywords'] = RouteKeywordsBuildComposer
> +        self.generator['lex'] = LexBuildComposer
> +        self.generator['yacc'] = YaccBuildComposer
>          self.generator['source-if-header'] = SourceFileIfHeaderComposer
>          self.generator['test-if-header'] = TestIfHeaderComposer
> diff --git a/buildset/default.ini b/buildset/default.ini
> index b17f2b59..9c0d1bf8 100644
> --- a/buildset/default.ini
> +++ b/buildset/default.ini
> @@ -50,11 +50,13 @@ net80211 = off
>  netinet = on
>  netinet6 = on
>  netipsec = off
> +nfsv2 = on
>  nvme = on
>  opencrypto = on
>  pci = on
>  pf = on
>  regulator = on
> +rpc_user = on
>  rtems = on
>  tests = on
>  tty = on
> diff --git a/freebsd-to-rtems.py b/freebsd-to-rtems.py
> index 5710b902..8f66e589 100755
> --- a/freebsd-to-rtems.py
> +++ b/freebsd-to-rtems.py
> @@ -152,6 +152,18 @@ try:
>      libbsd.load(build)
>      build.generateBuild(only_enabled=False)
> +    dups = build.duplicateCheck()
> +    if len(dups) > 0:
> +        print()
> +        print('Duplicates: %d' % (len(dups)))
> +        mods = list(set([dup[0] for dup in dups]))
> +        max_mod_len = max(len(dup[1]) for dup in dups)
> +        for mod in mods:
> +            print(' %s:' % (mod))
> +            for dup in [dup for dup in dups if dup[0] == mod]:
> +                print('  %-*s %s %s' % (max_mod_len, dup[1],
> dup[3][0].upper(), dup[2]))
> +        print()
>      if isConfig:
>          print()
>          print(build)
> diff --git a/libbsd.py b/libbsd.py
> index c251fba4..5b7e8a88 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -1,5 +1,5 @@
> -#  Copyright (c) 2015-2016, 2018 Chris Johns <chrisj at rtems.org>.
> +#  Copyright (c) 2015, 2020 Chris Johns <chrisj at rtems.org>.
>  #  All rights reserved.
>  #  Copyright (c) 2009, 2018 embedded brains GmbH.  All rights reserved.
> @@ -56,51 +56,56 @@ _defaults = {
>      # Includes
> -    'include-paths': ['rtemsbsd/include',
> -                      'freebsd/sys',
> -                      'freebsd/sys/contrib/ck/include',
> 'freebsd/sys/contrib/libsodium/src/libsodium/include',
> 'freebsd/sys/contrib/libsodium/src/libsodium/include/sodium',
> -                      'freebsd/sys/contrib/pf',
> -                      'freebsd/crypto',
> -                      'freebsd/crypto/openssl/include',
> -                      'freebsd/sys/net',
> -                      'freebsd/include',
> -                      'freebsd/lib',
> -                      'freebsd/lib/libbsdstat',
> -                      'freebsd/lib/libcapsicum',
> -                      'freebsd/lib/libcasper',
> -                      'freebsd/lib/libc/include',
> -                      'freebsd/lib/libc/isc/include',
> -                      'freebsd/lib/libc/resolv',
> -                      'freebsd/lib/libutil',
> -                      'freebsd/lib/libkvm',
> -                      'freebsd/lib/libmemstat',
> -                      'freebsd/contrib/expat/lib',
> -                      'freebsd/contrib/libpcap',
> -                      'freebsd/contrib/libxo',
> -                      'ipsec-tools/src/libipsec',
> -                      'linux/include',
> -                      'linux/drivers/net/ethernet/freescale/fman',
> -                      'rtemsbsd/sys',
> -                      'mDNSResponder/mDNSCore',
> -                      'mDNSResponder/mDNSShared',
> -                      'mDNSResponder/mDNSPosix',
> -                      'testsuite/include'],
> -    'cpu-include-paths': ['rtemsbsd/@CPU@/include',
> -                          'freebsd/sys/@CPU@/include'],
> +    'include-paths': {
> +        # The path where headers will be copied during the build.
> +        'build': ['build-include'],
> +        # Kernel header paths
> +        'kernel': ['rtemsbsd/include',
> +                   'freebsd/sys',
> +                   'freebsd/sys/contrib/ck/include',
> +                   'freebsd/sys/contrib/libsodium/src/libsodium/include',
> +                   'freebsd/sys/contrib/pf',
> +                   'freebsd/sys/net',
> +                   'ipsec-tools/src/libipsec',
> +                   'linux/include',
> +                   'linux/drivers/net/ethernet/freescale/fman',
> +                   'rtemsbsd/sys'],
> +        # User header paths
> +        'user': ['freebsd/crypto',
> +                 'freebsd/crypto/openssl/include',
> +                 'freebsd/include',
> +                 'freebsd/lib',
> +                 'freebsd/lib/libbsdstat',
> +                 'freebsd/lib/libcapsicum',
> +                 'freebsd/lib/libcasper',
> +                 'freebsd/lib/libc/include',
> +                 'freebsd/lib/libc/isc/include',
> +                 'freebsd/lib/libc/resolv',
> +                 'freebsd/lib/libutil',
> +                 'freebsd/lib/libkvm',
> +                 'freebsd/lib/libmemstat',
> +                 'freebsd/contrib/expat/lib',
> +                 'freebsd/contrib/libpcap',
> +                 'freebsd/contrib/libxo',
> +                 'mDNSResponder/mDNSCore',
> +                 'mDNSResponder/mDNSShared',
> +                 'mDNSResponder/mDNSPosix',
> +                 'testsuite/include'],
> +        # CPU specific path, assumed to be in the kernel context
> +        'cpu': ['rtemsbsd/@CPU@/include',
> +                'freebsd/sys/@CPU@/include'],
>      # Map paths based on RTEMS naming to FreeBSD naming.
> -    'path-mappings': [     # (source, targets)
> -    # i386
> -    ('freebsd/sys/i386/include', ['freebsd/sys/x86/include',
> 'freebsd/sys/i386/include']),
> +    'path-mappings': [
> +        # (source, [targets..])
> +        # i386
> +        ('freebsd/sys/i386/include', ['freebsd/sys/x86/include',
> -    # The path where headers will be copied during build.
> -    'build-include-path': ['build-include'],
>      # Install headers
> @@ -152,7 +157,7 @@ class rtems(builder.Module):
>      def generate(self):
>          mm = self.manager
> -        self.addRTEMSSourceFiles(
> +        self.addRTEMSKernelSourceFiles(
>                  'local/bus_if.c',
>                  'local/cryptodev_if.c',
> @@ -168,35 +173,11 @@ class rtems(builder.Module):
>                  'local/mmcbr_if.c',
>                  'local/if_dwc_if.c',
>                  'local/gpio_if.c',
> -                'rtems/ipsec_get_policylen.c',
> -                'rtems/rtems-bsd-arp-processor.c',
>                  'rtems/rtems-bsd-allocator-domain-size.c',
> -                'rtems/rtems-bsd-cxx.cc',
>                  'rtems/rtems-bsd-get-allocator-domain-size.c',
> -                'rtems/rtems-bsd-get-ethernet-addr.c',
>                  'rtems/rtems-bsd-get-mac-address.c',
>                  'rtems/rtems-bsd-get-task-priority.c',
>                  'rtems/rtems-bsd-get-task-stack-size.c',
> -                'rtems/rtems-bsd-ifconfig.c',
> -                'rtems/rtems-bsd-ifconfig-lo0.c',
> -                'rtems/rtems-bsd-init-dhcp.c',
> -                'rtems/rtems-bsd-rc-conf-net.c',
> -                'rtems/rtems-bsd-rc-conf-pf.c',
> -                'rtems/rtems-bsd-rc-conf.c',
> -                'rtems/rtems-bsd-set-if-input.c',
> -                'rtems/rtems-bsd-shell-arp.c',
> -                'rtems/rtems-bsd-shell-ifconfig.c',
> -                'rtems/rtems-bsd-shell-ifmcstat.c',
> -                'rtems/rtems-bsd-shell-netstat.c',
> -                'rtems/rtems-bsd-shell-nvmecontrol.c',
> -                'rtems/rtems-bsd-shell-pfctl.c',
> -                'rtems/rtems-bsd-shell-ping.c',
> -                'rtems/rtems-bsd-shell-route.c',
> -                'rtems/rtems-bsd-shell-stty.c',
> -                'rtems/rtems-bsd-shell-sysctl.c',
> -                'rtems/rtems-bsd-shell-tcpdump.c',
> -                'rtems/rtems-bsd-shell-vmstat.c',
> -                'rtems/rtems-bsd-shell-wlanstats.c',
>                  'rtems/rtems-bsd-syscall-api.c',
>                  'rtems/rtems-kernel-assert.c',
>                  'rtems/rtems-kernel-autoconf.c',
> @@ -235,16 +216,59 @@ class rtems(builder.Module):
>                  'rtems/rtems-legacy-rtrequest.c',
>                  'rtems/rtems-legacy-newproc.c',
>                  'rtems/rtems-legacy-mii.c',
> +                'sys/arm/lpc/if_lpe.c',
> +                'sys/arm/lpc/lpc_pwr.c',
> +                'sys/dev/atsam/if_atsam.c',
> +                'sys/dev/atsam/if_atsam_media.c',
> +                'sys/dev/dw_mmc/dw_mmc.c',
> +                'sys/dev/ffec/if_ffec_mcf548x.c',
> +                'sys/dev/ffec/if_ffec_mpc8xx.c',
> +                'sys/dev/input/touchscreen/tsc_lpc32xx.c',
> +                'sys/dev/smc/if_smc_nexus.c',
> +                'sys/dev/tsec/if_tsec_nexus.c',
> +                'sys/dev/usb/controller/ehci_mpc83xx.c',
> +                'sys/dev/usb/controller/ohci_lpc32xx.c',
> +                'sys/dev/usb/controller/ohci_lpc.c',
> +                'sys/dev/usb/controller/usb_otg_transceiver.c',
> +                'sys/dev/usb/controller/usb_otg_transceiver_dump.c',
> +                'sys/fs/devfs/devfs_devs.c',
> +                'sys/net/if_ppp.c',
> +                'sys/net/ppp_tty.c',
> +            mm.generator['source']()
> +        self.addRTEMSUserSourceFiles(
> +                'rtems/ipsec_get_policylen.c',
> +                'rtems/rtems-bsd-arp-processor.c',
> +                'rtems/rtems-bsd-cxx.cc',
> +                'rtems/rtems-bsd-get-ethernet-addr.c',
> +                'rtems/rtems-bsd-ifconfig.c',
> +                'rtems/rtems-bsd-ifconfig-lo0.c',
> +                'rtems/rtems-bsd-init-dhcp.c',
> +                'rtems/rtems-bsd-rc-conf-net.c',
> +                'rtems/rtems-bsd-rc-conf-pf.c',
> +                'rtems/rtems-bsd-rc-conf.c',
> +                'rtems/rtems-bsd-set-if-input.c',
> +                'rtems/rtems-bsd-shell-arp.c',
> +                'rtems/rtems-bsd-shell-ifconfig.c',
> +                'rtems/rtems-bsd-shell-ifmcstat.c',
> +                'rtems/rtems-bsd-shell-netstat.c',
> +                'rtems/rtems-bsd-shell-nvmecontrol.c',
> +                'rtems/rtems-bsd-shell-pfctl.c',
> +                'rtems/rtems-bsd-shell-ping.c',
> +                'rtems/rtems-bsd-shell-route.c',
> +                'rtems/rtems-bsd-shell-stty.c',
> +                'rtems/rtems-bsd-shell-sysctl.c',
> +                'rtems/rtems-bsd-shell-tcpdump.c',
> +                'rtems/rtems-bsd-shell-vmstat.c',
> +                'rtems/rtems-bsd-shell-wlanstats.c',
>                  'rtems/rtems-kvm.c',
>                  'rtems/rtems-program.c',
>                  'rtems/rtems-program-socket.c',
>                  'rtems/rtems-routes.c',
>                  'rtems/syslog.c',
>                  'ftpd/ftpd-service.c',
> -                'nfsclient/mount_prot_xdr.c',
> -                'nfsclient/nfs.c',
> -                'nfsclient/nfs_prot_xdr.c',
> -                'nfsclient/rpcio.c',
>                  'pppd/auth.c',
>                  'pppd/ccp.c',
>                  'pppd/chap.c',
> @@ -261,39 +285,24 @@ class rtems(builder.Module):
>                  'pppd/sys-rtems.c',
>                  'pppd/upap.c',
>                  'pppd/utils.c',
> -                'sys/arm/lpc/if_lpe.c',
> -                'sys/arm/lpc/lpc_pwr.c',
> -                'sys/dev/atsam/if_atsam.c',
> -                'sys/dev/atsam/if_atsam_media.c',
> -                'sys/dev/dw_mmc/dw_mmc.c',
> -                'sys/dev/ffec/if_ffec_mcf548x.c',
> -                'sys/dev/ffec/if_ffec_mpc8xx.c',
> -                'sys/dev/input/touchscreen/tsc_lpc32xx.c',
> -                'sys/dev/smc/if_smc_nexus.c',
> -                'sys/dev/tsec/if_tsec_nexus.c',
> -                'sys/dev/usb/controller/ehci_mpc83xx.c',
> -                'sys/dev/usb/controller/ohci_lpc32xx.c',
> -                'sys/dev/usb/controller/ohci_lpc.c',
> -                'sys/dev/usb/controller/usb_otg_transceiver.c',
> -                'sys/dev/usb/controller/usb_otg_transceiver_dump.c',
> -                'sys/fs/devfs/devfs_devs.c',
> -                'sys/net/if_ppp.c',
> -                'sys/net/ppp_tty.c',
>                  'telnetd/telnetd-service.c',
> self.addFile(mm.generator['file']('rtems/rtems-kernel-kvm-symbols.c',
> +        self.addFile(mm.generator['file']('kernel',
>                                            mm.generator['rtems-path'](),
>                                            mm.generator['no-convert'](),
>  mm.generator['kvm-symbols'](includes = 'rtemsbsd/rtems')))
> -        self.addFile(mm.generator['file']('lib/libc/net/nslexer.l',
> +        self.addFile(mm.generator['file']('user',
> +                                          'lib/libc/net/nslexer.l',
>                                            mm.generator['freebsd-path'](),
>                                            mm.generator['convert'](),
>                                            mm.generator['lex']('_nsyy',
> 'nsparser.c')))
> -        self.addFile(mm.generator['file']('lib/libc/net/nsparser.y',
> +                                          'lib/libc/net/nsparser.y',
> @@ -344,8 +353,6 @@ class base(builder.Module):
>                  'sys/contrib/ck/include/gcc/x86/ck_f_pr.h',
>                  'sys/contrib/ck/include/gcc/x86/ck_pr.h',
>                  'sys/fs/devfs/devfs_int.h',
> -                'sys/rpc/netconfig.h',
> -                'sys/rpc/types.h',
>                  'sys/security/audit/audit.h',
>                  'sys/security/mac/mac_framework.h',
>                  'sys/sys/acl.h',
> @@ -569,7 +576,7 @@ class fdt(builder.Module):
>                  'rtems/ofw_machdep.c',
> @@ -606,7 +613,7 @@ class tty(builder.Module):
> -#        self.addRTEMSSourceFiles(
> +#        self.addRTEMSKernelSourceFiles(
>  #                'rtems/ofw_machdep.c',
> @@ -643,7 +650,7 @@ class mmc(builder.Module):
>                  'sys/arm/at91/at91_mci.c',
> @@ -682,7 +689,7 @@ class mmc_ti(builder.Module):
>                  'local/sdhci_if.c',
>                  'local/gpiobus_if.c',
> @@ -1082,7 +1089,7 @@ class dev_usb_wlan(builder.Module):
>                  'sys/dev/usb/wlan/if_zydreg.h',
>                  'local/runfw.c',
> @@ -1194,7 +1201,7 @@ class dev_wlan_rtwn(builder.Module):
>                  'sys/dev/rtwn/usb/rtwn_usb_var.h',
>                  'local/rtwn-rtl8192cfwT.c',
>                  'local/rtwn-rtl8188eufw.c',
> @@ -1403,7 +1410,7 @@ class dev_net(builder.Module):
>                  'sys/dev/mii/ksz8091rnb_50MHz.c',
> @@ -1697,7 +1704,7 @@ class nvme(builder.Module):
>                  'sys/dev/nvd/nvd.c',
> @@ -2105,14 +2112,16 @@ class netipsec(builder.Module):
>              mm.generator['source'](libipsec_cflags)
> self.addFile(mm.generator['file']('ipsec-tools/src/libipsec/policy_token.l',
>                                            mm.generator['path'](),
>  mm.generator['lex']('__libipsec',
>  'policy_parse.c',
>  libipsec_cflags)))
> self.addFile(mm.generator['file']('ipsec-tools/src/libipsec/policy_parse.y',
> @@ -2174,7 +2183,8 @@ class netipsec(builder.Module):
>              mm.generator['source'](racoon_cflags,
>                                     ['freebsd/crypto/openssl'])
> self.addFile(mm.generator['file']('ipsec-tools/src/racoon/cftoken.l',
> @@ -2182,7 +2192,8 @@ class netipsec(builder.Module):
>        'cftoken.c',
>  racoon_cflags,
>  build=False)))
> self.addFile(mm.generator['file']('ipsec-tools/src/racoon/cfparse.y',
> @@ -2190,7 +2201,8 @@ class netipsec(builder.Module):
> 'cfparse.h',
> racoon_cflags,
> build=False)))
> self.addFile(mm.generator['file']('ipsec-tools/src/racoon/prsa_tok.l',
> @@ -2198,7 +2210,8 @@ class netipsec(builder.Module):
>  'prsa_tok.c',
>  racoon_cflags,
>  build=False)))
> self.addFile(mm.generator['file']('ipsec-tools/src/racoon/prsa_par.y',
> @@ -2211,7 +2224,7 @@ class netipsec(builder.Module):
>                  'rtems/ipsec.h',
>                  'rtems/rtems-bsd-racoon.c',
>                  'rtems/rtems-bsd-rc-conf-ipsec.c',
> @@ -2231,7 +2244,8 @@ class netipsec(builder.Module):
>              mm.generator['source'](setkey_cflags)
> self.addFile(mm.generator['file']('ipsec-tools/src/setkey/token.l',
> @@ -2239,7 +2253,8 @@ class netipsec(builder.Module):
>        'token.c',
>  setkey_cflags,
>  build=False)))
> self.addFile(mm.generator['file']('ipsec-tools/src/setkey/parse.y',
> @@ -2247,7 +2262,7 @@ class netipsec(builder.Module):
>        'parse.h',
> setkey_cflags,
> build=False)))
>                  'rtems/rtems-bsd-shell-setkey.c',
> @@ -2585,6 +2600,156 @@ class pf(builder.Module):
> +# RPC for user space, remove when NFSv2 is removed
> +class rpc_user(builder.Module):
> +    def __init__(self, manager):
> +        super(rpc_user, self).__init__(manager, type(self).__name__)
> +    def generate(self):
> +        mm = self.manager
> +        # User space support for legacy nfsv2 client, remove when nfsv2
> is removed
> +        self.addUserSpaceHeaderFiles(
> +                'include/rpc/clnt.h',
> +                'include/rpc/pmap_rmt.h',
> +                'include/rpc/svc_soc.h',
> +                'include/rpc/nettype.h',
> +                'include/rpc/xdr.h',
> +                'include/rpc/svc.h',
> +                'include/rpc/rpc_msg.h',
> +                'include/rpc/rpcsec_gss.h',
> +                'include/rpc/raw.h',
> +                'include/rpc/clnt_stat.h',
> +                'include/rpc/auth.h',
> +                'include/rpc/svc_dg.h',
> +                'include/rpc/auth_kerb.h',
> +                'include/rpc/auth_des.h',
> +                'include/rpc/rpcb_clnt.h',
> +                'include/rpc/rpc.h',
> +                'include/rpc/des.h',
> +                'include/rpc/des_crypt.h',
> +                'include/rpc/svc_auth.h',
> +                'include/rpc/pmap_clnt.h',
> +                'include/rpc/clnt_soc.h',
> +                'include/rpc/pmap_prot.h',
> +                'include/rpc/auth_unix.h',
> +                'include/rpc/rpc_com.h',
> +                'include/rpc/rpcent.h',
> +                'include/rpcsvc/nis_db.h',
> +                'include/rpcsvc/nislib.h',
> +                'include/rpcsvc/nis_tags.h',
> +                'include/rpcsvc/ypclnt.h',
> +                'include/rpcsvc/yp_prot.h',
> +                'lib/libc/rpc/mt_misc.h',
> +                'lib/libc/rpc/rpc_com.h',
> +                                          'include/rpc/rpcb_prot.x',
> +                                          mm.generator['freebsd-path'](),
> +                                          mm.generator['convert'](),
> +                                          mm.generator['rpc-gen']()))
> +                                          'include/rpcsvc/nis.x',
> +        self.addUserSpaceSourceFiles(
> +                'lib/libc/rpc/auth_des.c',
> +                'lib/libc/rpc/authdes_prot.c',
> +                'lib/libc/rpc/auth_none.c',
> +                'lib/libc/rpc/auth_time.c',
> +                'lib/libc/rpc/auth_unix.c',
> +                'lib/libc/rpc/authunix_prot.c',
> +                'lib/libc/rpc/bindresvport.c',
> +                'lib/libc/rpc/clnt_bcast.c',
> +                'lib/libc/rpc/clnt_dg.c',
> +                'lib/libc/rpc/clnt_generic.c',
> +                'lib/libc/rpc/clnt_perror.c',
> +                'lib/libc/rpc/clnt_raw.c',
> +                'lib/libc/rpc/clnt_simple.c',
> +                'lib/libc/rpc/clnt_vc.c',
> +                'lib/libc/rpc/crypt_client.c',
> +                'lib/libc/rpc/des_crypt.c',
> +                'lib/libc/rpc/des_soft.c',
> +                'lib/libc/rpc/getnetconfig.c',
> +                'lib/libc/rpc/getnetpath.c',
> +                'lib/libc/rpc/getpublickey.c',
> +                'lib/libc/rpc/getrpcent.c',
> +                'lib/libc/rpc/getrpcport.c',
> +                'lib/libc/rpc/key_call.c',
> +                'lib/libc/rpc/key_prot_xdr.c',
> +                'lib/libc/rpc/mt_misc.c',
> +                'lib/libc/rpc/netname.c',
> +                'lib/libc/rpc/netnamer.c',
> +                'lib/libc/rpc/pmap_clnt.c',
> +                'lib/libc/rpc/pmap_getmaps.c',
> +                'lib/libc/rpc/pmap_getport.c',
> +                'lib/libc/rpc/pmap_prot2.c',
> +                'lib/libc/rpc/pmap_prot.c',
> +                'lib/libc/rpc/pmap_rmt.c',
> +                'lib/libc/rpc/rpcb_clnt.c',
> +                'lib/libc/rpc/rpcb_prot.c',
> +                'lib/libc/rpc/rpcb_st_xdr.c',
> +                'lib/libc/rpc/rpc_callmsg.c',
> +                'lib/libc/rpc/rpc_commondata.c',
> +                'lib/libc/rpc/rpcdname.c',
> +                'lib/libc/rpc/rpc_dtablesize.c',
> +                'lib/libc/rpc/rpc_generic.c',
> +                'lib/libc/rpc/rpc_prot.c',
> +                'lib/libc/rpc/rpcsec_gss_stub.c',
> +                'lib/libc/rpc/rpc_soc.c',
> +                'lib/libc/rpc/rtime.c',
> +                'lib/libc/rpc/svc_auth.c',
> +                'lib/libc/rpc/svc_auth_des.c',
> +                'lib/libc/rpc/svc_auth_unix.c',
> +                'lib/libc/rpc/svc.c',
> +                'lib/libc/rpc/svc_dg.c',
> +                'lib/libc/rpc/svc_generic.c',
> +                'lib/libc/rpc/svc_raw.c',
> +                'lib/libc/rpc/svc_run.c',
> +                'lib/libc/rpc/svc_simple.c',
> +                'lib/libc/rpc/svc_vc.c',
> +                'lib/libc/xdr/xdr_array.c',
> +                'lib/libc/xdr/xdr.c',
> +                'lib/libc/xdr/xdr_float.c',
> +                'lib/libc/xdr/xdr_mem.c',
> +                'lib/libc/xdr/xdr_rec.c',
> +                'lib/libc/xdr/xdr_reference.c',
> +                'lib/libc/xdr/xdr_sizeof.c',
> +                'lib/libc/xdr/xdr_stdio.c',
> +            mm.generator['source'](['-DINET'])
> +# NFSv2 Client
> +class nfsv2(builder.Module):
> +        super(nfsv2, self).__init__(manager, type(self).__name__)
> +        mm = self.manager
> +        self.addDependency(mm['rpc_user'])
> +                'nfsclient/mount_prot_xdr.c',
> +                'nfsclient/nfs.c',
> +                'nfsclient/nfs_prot_xdr.c',
> +                'nfsclient/rpcio.c',
>  # PCI
> @@ -2630,6 +2795,7 @@ class pci(builder.Module):
>  # User space
> @@ -2665,36 +2831,6 @@ class user_space(builder.Module):
>                  'include/nsswitch.h',
>                  'include/resolv.h',
>                  'include/res_update.h',
> -                'include/rpc/clnt.h',
> -                'include/rpc/pmap_rmt.h',
> -                'include/rpc/svc_soc.h',
> -                'include/rpc/nettype.h',
> -                'include/rpc/xdr.h',
> -                'include/rpc/svc.h',
> -                'include/rpc/rpc_msg.h',
> -                'include/rpc/rpcsec_gss.h',
> -                'include/rpc/raw.h',
> -                'include/rpc/clnt_stat.h',
> -                'include/rpc/auth.h',
> -                'include/rpc/svc_dg.h',
> -                'include/rpc/auth_kerb.h',
> -                'include/rpc/auth_des.h',
> -                'include/rpc/rpcb_clnt.h',
> -                'include/rpc/rpc.h',
> -                'include/rpc/des.h',
> -                'include/rpc/des_crypt.h',
> -                'include/rpc/svc_auth.h',
> -                'include/rpc/pmap_clnt.h',
> -                'include/rpc/clnt_soc.h',
> -                'include/rpc/pmap_prot.h',
> -                'include/rpc/auth_unix.h',
> -                'include/rpc/rpc_com.h',
> -                'include/rpc/rpcent.h',
> -                'include/rpcsvc/nis_db.h',
> -                'include/rpcsvc/nislib.h',
> -                'include/rpcsvc/nis_tags.h',
> -                'include/rpcsvc/ypclnt.h',
> -                'include/rpcsvc/yp_prot.h',
>                  'include/sysexits.h',
>                  'lib/lib80211/lib80211_ioctl.h',
>                  'lib/lib80211/lib80211_regdomain.h',
> @@ -2724,8 +2860,6 @@ class user_space(builder.Module):
>                  'lib/libc/net/res_config.h',
>                  'lib/libc/resolv/res_debug.h',
>                  'lib/libc/resolv/res_private.h',
> -                'lib/libc/rpc/mt_misc.h',
> -                'lib/libc/rpc/rpc_com.h',
>                  'lib/libc/stdio/local.h',
>                  'lib/libkvm/kvm.h',
>                  'lib/libmemstat/memstat.h',
> @@ -2741,22 +2875,14 @@ class user_space(builder.Module):
>                  'usr.bin/netstat/netstat.h'
> -        self.addFile(mm.generator['file']('include/rpc/rpcb_prot.x',
> -                                          mm.generator['freebsd-path'](),
> -                                          mm.generator['convert'](),
> -                                          mm.generator['rpc-gen']()))
> -        self.addFile(mm.generator['file']('include/rpcsvc/nis.x',
> -        self.addFile(mm.generator['file']('sbin/route/keywords',
> +                                          'sbin/route/keywords',
>  mm.generator['route-keywords']()))
> -        self.addFile(mm.generator['file']('sbin/pfctl/parse.y',
> +                                          'sbin/pfctl/parse.y',
> @@ -2796,7 +2922,7 @@ class user_space(builder.Module):
>                  'include/machine/rtems-bsd-regdomain.h',
>                  'rtems/rtems-bsd-regdomain.c',
> @@ -2891,72 +3017,9 @@ class user_space(builder.Module):
>                  'lib/libc/resolv/res_send.c',
>                  'lib/libc/resolv/res_state.c',
>                  'lib/libc/resolv/res_update.c',
> -                'lib/libc/rpc/auth_des.c',
> -                'lib/libc/rpc/authdes_prot.c',
> -                'lib/libc/rpc/auth_none.c',
> -                'lib/libc/rpc/auth_time.c',
> -                'lib/libc/rpc/auth_unix.c',
> -                'lib/libc/rpc/authunix_prot.c',
> -                'lib/libc/rpc/bindresvport.c',
> -                'lib/libc/rpc/clnt_bcast.c',
> -                'lib/libc/rpc/clnt_dg.c',
> -                'lib/libc/rpc/clnt_generic.c',
> -                'lib/libc/rpc/clnt_perror.c',
> -                'lib/libc/rpc/clnt_raw.c',
> -                'lib/libc/rpc/clnt_simple.c',
> -                'lib/libc/rpc/clnt_vc.c',
> -                'lib/libc/rpc/crypt_client.c',
> -                'lib/libc/rpc/des_crypt.c',
> -                'lib/libc/rpc/des_soft.c',
> -                'lib/libc/rpc/getnetconfig.c',
> -                'lib/libc/rpc/getnetpath.c',
> -                'lib/libc/rpc/getpublickey.c',
> -                'lib/libc/rpc/getrpcent.c',
> -                'lib/libc/rpc/getrpcport.c',
> -                'lib/libc/rpc/key_call.c',
> -                'lib/libc/rpc/key_prot_xdr.c',
> -                'lib/libc/rpc/mt_misc.c',
> -                'lib/libc/rpc/netname.c',
> -                'lib/libc/rpc/netnamer.c',
> -                'lib/libc/rpc/pmap_clnt.c',
> -                'lib/libc/rpc/pmap_getmaps.c',
> -                'lib/libc/rpc/pmap_getport.c',
> -                'lib/libc/rpc/pmap_prot2.c',
> -                'lib/libc/rpc/pmap_prot.c',
> -                'lib/libc/rpc/pmap_rmt.c',
> -                'lib/libc/rpc/rpcb_clnt.c',
> -                'lib/libc/rpc/rpcb_prot.c',
> -                'lib/libc/rpc/rpcb_st_xdr.c',
> -                'lib/libc/rpc/rpc_callmsg.c',
> -                'lib/libc/rpc/rpc_commondata.c',
> -                'lib/libc/rpc/rpcdname.c',
> -                'lib/libc/rpc/rpc_dtablesize.c',
> -                'lib/libc/rpc/rpc_generic.c',
> -                'lib/libc/rpc/rpc_prot.c',
> -                'lib/libc/rpc/rpcsec_gss_stub.c',
> -                'lib/libc/rpc/rpc_soc.c',
> -                'lib/libc/rpc/rtime.c',
> -                'lib/libc/rpc/svc_auth.c',
> -                'lib/libc/rpc/svc_auth_des.c',
> -                'lib/libc/rpc/svc_auth_unix.c',
> -                'lib/libc/rpc/svc.c',
> -                'lib/libc/rpc/svc_dg.c',
> -                'lib/libc/rpc/svc_generic.c',
> -                'lib/libc/rpc/svc_raw.c',
> -                'lib/libc/rpc/svc_run.c',
> -                'lib/libc/rpc/svc_simple.c',
> -                'lib/libc/rpc/svc_vc.c',
>                  'lib/libc/stdio/fgetln.c',
>                  'lib/libc/stdlib/strtonum.c',
>                  'lib/libc/string/strsep.c',
> -                'lib/libc/xdr/xdr_array.c',
> -                'lib/libc/xdr/xdr.c',
> -                'lib/libc/xdr/xdr_float.c',
> -                'lib/libc/xdr/xdr_mem.c',
> -                'lib/libc/xdr/xdr_rec.c',
> -                'lib/libc/xdr/xdr_reference.c',
> -                'lib/libc/xdr/xdr_sizeof.c',
> -                'lib/libc/xdr/xdr_stdio.c',
>                  'lib/libmemstat/memstat_all.c',
>                  'lib/libmemstat/memstat.c',
>                  'lib/libmemstat/memstat_malloc.c',
> @@ -3068,6 +3131,7 @@ class crypto_openssl(builder.Module):
>      def generate(self):
>          mm = self.manager
> +        self.addDependency(mm['user_space'])
>                  'crypto/openssl/crypto/aes/aes_locl.h',
> @@ -4021,21 +4085,22 @@ class crypto_openssl(builder.Module):
>  'freebsd/crypto/openssl/crypto/ec/curve448',
>  'freebsd/crypto/openssl/crypto/ec/curve448/arch_32'])
> self.addFile(mm.generator['file']('crypto/openssl/crypto/LPdir_unix.c',
>  mm.generator['from-FreeBSD-to-RTEMS-UserSpaceSourceConverter'](),
>  mm.generator['from-RTEMS-To-FreeBSD-SourceConverter'](),
> mm.generator['buildSystemFragmentComposer']()))
> self.addFile(mm.generator['file']('crypto/openssl/crypto/ec/ecp_nistz256_table.c',
> mm.generator['buildSystemComposer']()))
>  # /usr/bin/openssl
> -# depends on crypto_openssl, user_space
>  class usr_bin_openssl(builder.Module):
> @@ -4043,6 +4108,7 @@ class usr_bin_openssl(builder.Module):
>      def generate(self):
>          mm = self.manager
> +        self.addDependency(mm['crypto_openssl'])
>                  'crypto/openssl/apps/apps.h',
> @@ -4115,7 +4181,7 @@ class usr_bin_openssl(builder.Module):
>                  'rtems/rtems-bsd-shell-openssl.c',
> @@ -4233,14 +4299,16 @@ class contrib_libpcap(builder.Module):
>          gen_cflags = cflags + ['-DNEED_YYPARSE_WRAPPER=1',
>                                 '-Dyylval=pcap_lval']
> -        self.addFile(mm.generator['file']('contrib/libpcap/scanner.l',
> +                                          'contrib/libpcap/scanner.l',
>                                            mm.generator['lex']('pcap',
>        'scanner.c',
>  gen_cflags)))
> -        self.addFile(mm.generator['file']('contrib/libpcap/grammar.y',
> +                                          'contrib/libpcap/grammar.y',
> @@ -4811,7 +4879,7 @@ class usr_sbin_wpa_supplicant(builder.Module):
>                                      'freebsd/usr.sbin/wpa/wpa_supplicant',
>                                      'freebsd/crypto/openssl/crypto'])
>                  'rtems/rtems-bsd-shell-wpa_supplicant.c',
>                  'rtems/rtems-wpa_supplicant_mutex.c',
> @@ -4920,7 +4988,7 @@ class dhcpcd(builder.Module):
>              mm.generator['source']('-D__FreeBSD__ -DTHERE_IS_NO_FORK
> -DMASTER_ONLY -DINET')
>                  'rtems/rtems-bsd-shell-dhcpcd.c',
> @@ -4958,6 +5026,7 @@ class mdnsresponder(builder.Module):
>  class dpaa(builder.Module):
> @@ -5057,7 +5126,7 @@ class regulator(builder.Module):
>      def generate(self):
>          mm = self.manager
>                  'local/regdev_if.c',
>                  'local/regnode_if.c',
> @@ -5223,6 +5292,9 @@ def load(mm):
>      mm.addModule(pf(mm))
>      mm.addModule(dev_net(mm))
> +    mm.addModule(rpc_user(mm))
> +    mm.addModule(nfsv2(mm))
>      # Add PCI
>      mm.addModule(pci(mm))
> diff --git a/waf_libbsd.py b/waf_libbsd.py
> index bdd1cf4a..d7a0c224 100644
> --- a/waf_libbsd.py
> +++ b/waf_libbsd.py
> @@ -1,6 +1,6 @@
> -'''LibBSD build configuration to waf integration module.
> +"""LibBSD build configuration to waf integration module.
> reserved.
> @@ -37,12 +37,6 @@
> -# Python 3 does no longer know the basestring class. Catch that.
> -try:
> -    basestring
> -except NameError:
> -    basestring = (str, bytes)
>  import os
>  import sys
>  import tempfile
> @@ -86,11 +80,11 @@ class Builder(builder.ModuleManager):
>          return sources
>      def generate(self, rtems_version):
> -        def _dataInsert(data, cpu, frag):
> +        def _dataInsert(data, cpu, space, frag):
> -            # The default handler returns an empty string. Skip it.
> +            # The default handler returns None. Skip it.
> -            if type(frag) is not str:
> +            if frag is not None:
>                  # Start at the top of the tree
>                  d = data
>                  path = frag[0]
> @@ -99,6 +93,10 @@ class Builder(builder.ModuleManager):
>                  # Select the sub-part of the tree as the compile options
>                  # specialise how files are built.
>                  d = d[path[0]]
> +                # Group based on the space, ie kernel or user
> +                if space not in d:
> +                    d[space] = {}
> +                d = d[space]
>                  if type(path[1]) is list:
>                      p = ' '.join(path[1])
>                  else:
> @@ -144,11 +142,14 @@ class Builder(builder.ModuleManager):
>              m = self[mn]
>              if m.conditionalOn == "none":
>                  for f in m.files:
> -                    _dataInsert(self.data, 'all', f.getFragment())
> +                    _dataInsert(self.data, 'all', f.getSpace(),
> +                                f.getFragment())
>              for cpu, files in sorted(m.cpuDependentSourceFiles.items()):
>                  for f in files:
> -                    _dataInsert(self.data, cpu, f.getFragment())
> +                    _dataInsert(self.data, cpu, f.getSpace(),
> +                                f.getFragment())
> +        # Start here if you need to understand self.data. Add 'True or'
>          if self.trace:
>              import pprint
>              pprint.pprint(self.data)
> @@ -206,21 +207,45 @@ class Builder(builder.ModuleManager):
>                  defines += ['%s=1' % (o.strip().upper())]
> -        # Include paths
> -        includes = []
> -        buildinclude = 'build-include'
> -        if 'cpu-include-paths' in config:
> +        # Include paths, maintain paths for each build space.
> +        include_paths = config['include-paths']
> +        if 'build' not in include_paths:
> +            bld.fatal('no build include path found in include-path
> defaults')
> +        buildinclude = include_paths['build']
> +        if isinstance(buildinclude, list):
> +            buildinclude = buildinclude[0]
> +        inc_paths = sorted(include_paths)
> +        inc_paths.remove('build')
> +        inc_paths.remove('cpu')
> +        includes = {}
> +        for inc in inc_paths:
> +            includes[inc] = include_paths[inc]
> +        # cpu include paths must be the first searched
> +        if 'cpu' in include_paths:
>              cpu = bld.get_env()['RTEMS_ARCH']
> -            for i in config['cpu-include-paths']:
> -                includes += [i.replace('@CPU@', cpu)]
> -        if 'include-paths' in config:
> -            includes += config['include-paths']
> -        if 'build-include-path' in config:
> -            buildinclude = config['build-include-path']
> -            if not isinstance(buildinclude, basestring):
> -                buildinclude = buildinclude[0]
> -        includes += [buildinclude]
> +            for i in include_paths['cpu']:
> +                includes['kernel'].insert(0, i.replace('@CPU@', cpu))
> +        includes['kernel'] += [buildinclude]
> +        # Path mappings
> +        if 'path-mappings' in config:
> +            for source, target in config['path-mappings']:
> +                for space in includes:
> +                    incs = includes[space]
> +                    if source in incs:
> +                        target = [target] if isinstance(target,
> +                                                        str) else target
> +                        i = incs.index(source)
> +                        incs.remove(source)
> +                        incs[i:i] = target
> +        # Place the kernel include paths after the user paths
> +        includes['user'] += includes['kernel']
>          # Path mappings
> @@ -325,7 +350,7 @@ class Builder(builder.ModuleManager):
>          # KVM Symbols
>          if 'KVMSymbols' in self.data:
> -            kvmsymbols = self.data['KVMSymbols']
> +            kvmsymbols = self.data['KVMSymbols']['kernel']
>              if 'includes' in kvmsymbols['files']:
>                  kvmsymbols_includes = kvmsymbols['files']['includes']
>              else:
> @@ -337,7 +362,7 @@ class Builder(builder.ModuleManager):
>              bld.objects(target='kvmsymbols',
>                          features='c',
>                          cflags=cflags,
> -                        includes=kvmsymbols_includes + includes,
> +                        includes=kvmsymbols_includes + includes['kernel'],
>                          source=kvmsymbols['files']['all']['default'][0])
>              libbsd_use += ["kvmsymbols"]
> @@ -348,7 +373,7 @@ class Builder(builder.ModuleManager):
>          if 'RPCGen' in self.data:
>              if bld.env.AUTO_REGEN:
> -                rpcgen = self.data['RPCGen']
> +                rpcgen = self.data['RPCGen']['user']
>                  rpcname = rpcgen['files']['all']['default'][0][:-2]
>                  bld(target=rpcname + '.h',
>                      source=rpcname + '.x',
> @@ -359,7 +384,7 @@ class Builder(builder.ModuleManager):
>          if 'RouteKeywords' in self.data:
> -                routekw = self.data['RouteKeywords']
> +                routekw = self.data['RouteKeywords']['user']
>                  rkwname = routekw['files']['all']['default'][0]
>                  rkw_rule = host_shell + "cat ${SRC} | " + \
>                             "awk 'BEGIN { r = 0 } { if (NF == 1) " + \
> @@ -371,7 +396,7 @@ class Builder(builder.ModuleManager):
>          # Lex
>          if 'lex' in self.data:
> -            lexes = self.data['lex']
> +            lexes = self.data['lex']['user']
>              for l in sorted(lexes.keys()):
>                  lex = lexes[l]['all']['default']
>                  if 'cflags' in lex:
> @@ -392,7 +417,7 @@ class Builder(builder.ModuleManager):
>                      bld.objects(target='lex_%s' % (lex['sym']),
>                                  features='c',
>                                  cflags=cflags,
> -                                includes=lexIncludes + includes,
> +                                includes=lexIncludes + includes['user'],
>                                  defines=defines + lexDefines,
>                                  source=lex['file'][:-2] + '.c')
>                  libbsd_use += ['lex_%s' % (lex['sym'])]
> @@ -401,7 +426,7 @@ class Builder(builder.ModuleManager):
>          # Yacc
>          if 'yacc' in self.data:
> -            yaccs = self.data['yacc']
> +            yaccs = self.data['yacc']['user']
>              for y in sorted(yaccs.keys()):
>                  yacc = yaccs[y]['all']['default']
>                  yaccFile = yacc['file']
> @@ -432,7 +457,7 @@ class Builder(builder.ModuleManager):
>                      bld.objects(target='yacc_%s' % (yaccSym),
>                                  features='c',
>                                  cflags=cflags,
> -                                includes=yaccIncludes + includes,
> +                                includes=yaccIncludes + includes['user'],
>                                  defines=defines + yaccDefines,
>                                  source=yaccFile[:-2] + '.c')
>                  libbsd_use += ['yacc_%s' % (yaccSym)]
> @@ -442,34 +467,40 @@ class Builder(builder.ModuleManager):
>          # specific files for those flags.
>          objs = 0
> -        sources = sorted(self.data['sources'])
> -        if 'default' in sources:
> -            sources.remove('default')
> -        for flags in sources:
> -            objs += 1
> -            build = self.data['sources'][flags]
> -            target = 'objs%02d' % (objs)
> -            bld_sources = Builder._sourceList(bld, build['all'])
> -            archs = sorted(build)
> -            for i in ['all', 'cflags', 'includes']:
> -                if i in archs:
> -                    archs.remove(i)
> -            for arch in archs:
> -                if bld.get_env()['RTEMS_ARCH'] == arch:
> -                    bld_sources += Builder._sourceList(bld, build[arch])
> -            bld.objects(target=target,
> -                        features='c',
> -                        cflags=cflags + sorted(build.get('cflags', [])),
> -                        includes=sorted(build.get('includes', [])) +
> includes,
> -                        defines=defines,
> -                        source=bld_sources)
> -            libbsd_use += [target]
> -        # We hold the 'default' cflags set of files to the end to create
> the
> -        # static library with.
> -        build = self.data['sources']['default']
> +        for space in sorted(self.data['sources']):
> +            sources = sorted(self.data['sources'][space])
> +            if space == 'kernel' and 'default' in sources:
> +                sources.remove('default')
> +            for flags in sources:
> +                objs += 1
> +                build = self.data['sources'][space][flags]
> +                target = 'objs%02d' % (objs)
> +                bld_sources = Builder._sourceList(bld, build['all'])
> +                archs = sorted(build)
> +                for i in ['all', 'cflags', 'includes']:
> +                    if i in archs:
> +                        archs.remove(i)
> +                for arch in archs:
> +                    if bld.get_env()['RTEMS_ARCH'] == arch:
> +                        bld_sources += Builder._sourceList(bld,
> build[arch])
> +                bld_cflags = sorted(build.get('cflags', []))
> +                if 'default' in bld_cflags:
> +                    bld_cflags.remove('default')
> +                bld.objects(target=target,
> +                            features='c cxx',
> +                            cflags=cflags + bld_cflags,
> +                            cxxflags=cxxflags,
> +                            includes=sorted(build.get('includes', [])) +
> +                            includes[space],
> +                            defines=defines,
> +                            source=bld_sources)
> +                libbsd_use += [target]
> +        # We hold the kernel 'default' cflags set of files to the end to
> +        # create the static library with.
> +        build = self.data['sources']['kernel']['default']
>          archs.remove('all')
> @@ -480,7 +511,7 @@ class Builder(builder.ModuleManager):
>                    features='c cxx',
>                    cflags=cflags,
>                    cxxflags=cxxflags,
> -                  includes=includes,
> +                  includes=includes['kernel'],
>                    defines=defines,
>                    source=bld_sources,
>                    use=libbsd_use)
> @@ -522,9 +553,9 @@ class Builder(builder.ModuleManager):
>          tests = []
>          if 'tests' in self.data:
> -            tests = self.data['tests']
> +            tests = self.data['tests']['user']
>          for testName in sorted(tests):
> -            test = self.data['tests'][testName]['all']
> +            test = tests[testName]['all']
>              test_source = []
>              libs = ['bsd', 'm', 'z', 'rtemstest']
>              for cfg in test:
> @@ -542,7 +573,7 @@ class Builder(builder.ModuleManager):
>                  bld.program(target='%s.exe' % (testName),
>                              features='cprogram',
>                              cflags=cflags,
> +                            includes=includes['user'],
>                              source=test_sources,
>                              use=['bsd'],
>                              lib=libs,
> diff --git a/wscript b/wscript
> index e9541327..466b50be 100644
> --- a/wscript
> +++ b/wscript
> @@ -1,9 +1,9 @@
> -'''RTEMS LibBSD is a transparent source build of the FreeBSD kernel
> +"""RTEMS LibBSD is a transparent source build of the FreeBSD kernel
>  source for RTEMS.
>  To use see README.waf shipped with this file.
>  # Copyright (c) 2015-2016 Chris Johns <chrisj at rtems.org>. All rights
> reserved.
> 2.24.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200915/f9d2df79/attachment-0001.html>
