[PATCH v1 7/9] bsps/pc386: Separate smp API functions. Makes smpfatal08 link
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Wed Sep 16 10:06:33 UTC 2020
Hi Sebastian,
Sure.
Is there an easy way to only send the updated patch to the mailinglist or should I send in the full patch set with v2?
Cheers,
  Jan
> -----Original Message-----
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Sent: Tuesday, September 15, 2020 6:38 AM
> To: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
> Subject: Re: [PATCH v1 7/9] bsps/pc386: Separate smp API functions. Makes
> smpfatal08 link
> Hello Jan,
> On 31/05/2020 16:22, Jan Sommer wrote:
> > diff --git a/bsps/i386/pc386/start/bspsmp.c
> > b/bsps/i386/pc386/start/bspsmp.c new file mode 100644 index
> > 0000000000..026f86916f
> > --- /dev/null
> > +++ b/bsps/i386/pc386/start/bspsmp.c
> > @@ -0,0 +1,43 @@
> > +#include <rtems/score/smpimpl.h>
> this file has no license and copyright header. Would you mind sending a patch
> which adds one. Ideally based on this template:
> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-
> assembler-source-file-template
