[PATCH] cpukit/mghttpd/mongoose: Fix format truncation warning
Chris Johns
chrisj at rtems.org
Thu Sep 17 01:15:25 UTC 2020
On 17/9/20 9:50 am, Joel Sherrill wrote:
> On Wed, Sep 16, 2020, 6:43 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 16/9/20 11:42 pm, Joel Sherrill wrote:
> > snprintf() is a safe method and I strongly disagree with the blanket
> replacement
> > of many safe methods with memcpy().
> > Based on what POSIX profiles snprintf() is included in and the safety and
> > security requirements those profiles are designed to meet, snprintf() is
> > supported by RTOSes that can meet DO-178 Level A.
> > If the POSIX method being reviewed is in the FACE Safety Base or Safety
> Extended
> > profile, then it is OK to use and has been used in flight qualified
> > applications. And that is a general statement meaning running on any of a
> > variety of RTOSes. If the usage is incorrect, let's fix it but blanket
> changing
> > them is wrong.
> This is really good information, thank you.
> No problem. That doesn't mean you can't do something stupid with it but
> sprintf() would be discouraged and isn't in those profiles as I recall.
> I see EPICS is reporting similar issues at the moment and looking to work around
> them.
> And no one is questioning why? What's the risk?
> Is there a history of why this has been added to compilers as a warning?
> I have no idea..snprintf has a length and avoids overwrites.
> I would suggest that we find a safety or security coding standard that warns
> about whatever methods this catches.
> Personally replacing snprintf and strong operations with memmove is semantically
> wrong.
I found this....
https://developers.redhat.com/blog/2018/05/24/detecting-string-truncation-with-gcc-8/
The "Handling Truncation When It Occurs" section in the blog post is something
worth considering. It seems the return value of call should be checked. That
seems reasonable.
