[PATCH] build: Fix dependencies for start and asm files
Sebastian Huber
Thu Sep 17 05:57:00 UTC 2020
Add explicit asm target feature. Add a build start file node list and
use it as a test program dependency.
Close #3846.
Close #4080.
wscript | 41 ++++++++++++++++++++++++++++++++++++-----
1 file changed, 36 insertions(+), 5 deletions(-)
diff --git a/wscript b/wscript
index 2e42918ebb..d47f25c094 100755
--- a/wscript
+++ b/wscript
@@ -40,6 +40,8 @@ try:
except:
import ConfigParser as configparser
+from waflib.TaskGen import after, before_method, feature
is_windows_host = os.name == "nt" or sys.platform in ["msys", "cygwin"]
default_prefix = "/opt/rtems/6"
compilers = ["gcc", "clang"]
@@ -149,6 +151,31 @@ def _is_enabled(enabled, enabled_by):
return enabled_by in enabled
+def _explicit_asm_target(self, node):
+ task = self.create_task(
+ "asm", node, self.bld.bldnode.make_node(self.target)
+ try:
+ self.compiled_tasks.append(task)
+ except AttributeError:
+ self.compiled_tasks = [task]
+ return task
+ at feature("explicit_asm_target")
+ at before_method("process_source")
+def _enable_explicit_asm_target(self):
+ self.mappings = dict(self.mappings) # Copy
+ self.mappings[".S"] = _explicit_asm_target
+ at after("apply_link")
+ at feature("cprogram", "cxxprogram")
+def process_start_files(self):
+ if getattr(self, "start_files", False):
+ self.link_task.dep_nodes.extend(self.bld.start_files)
class Item(object):
def __init__(self, uid, data):
self.uid = uid
@@ -246,12 +273,10 @@ class Item(object):
target = os.path.splitext(source)[0] + ".o"
bld(
asflags=self.data["asflags"],
- before=["cstlib"],
cppflags=cppflags + self.data["cppflags"],
- features="asm c",
+ features="explicit_asm_target asm c",
includes=bic.includes + self.data["includes"],
- rule="${CC} ${ASFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES} ${CPPPATH_ST:INCPATHS} -c ${SRC[0]} -o ${TGT}",
- source=[source] + deps,
+ source=source + deps,
target=target,
return target
@@ -532,7 +557,12 @@ class StartFileItem(Item):
super(StartFileItem, self).__init__(uid, data)
def do_build(self, bld, bic):
- self.asm(bld, bic, self.data["source"], self.get(bld, "target"))
+ tgt = self.asm(bld, bic, self.data["source"], self.get(bld, "target"))
+ node = bld.bldnode.make_node(tgt)
+ try:
+ bld.start_files.append(node)
+ bld.start_files = [node]
self.install_target(bld)
@@ -626,6 +656,7 @@ class TestProgramItem(Item):
install_path=None,
ldflags=bic.ldflags + self.data["ldflags"],
source=self.data["source"],
+ start_files=True,
stlib=self.data["stlib"],
target=self.get(bld, "target"),
use=self.data["use-before"] + bic.use + self.data["use-after"],
2.26.2
