[PATCH] build: Fix dependencies for start and asm files
Thu Sep 17 06:07:06 UTC 2020
On 17/9/20 3:57 pm, Sebastian Huber wrote:
> Add explicit asm target feature.  Add a build start file node list and
> use it as a test program dependency.
> Close #3846.
> Close #4080.
>  wscript | 41 ++++++++++++++++++++++++++++++++++++-----
>  1 file changed, 36 insertions(+), 5 deletions(-)
> diff --git a/wscript b/wscript
> index 2e42918ebb..d47f25c094 100755
> --- a/wscript
> +++ b/wscript
> @@ -40,6 +40,8 @@ try:
>  except:
>      import ConfigParser as configparser
> +from waflib.TaskGen import after, before_method, feature
>  is_windows_host = os.name == "nt" or sys.platform in ["msys", "cygwin"]
>  default_prefix = "/opt/rtems/6"
>  compilers = ["gcc", "clang"]
> @@ -149,6 +151,31 @@ def _is_enabled(enabled, enabled_by):
>      return enabled_by in enabled
> +def _explicit_asm_target(self, node):
> +    task = self.create_task(
> +        "asm", node, self.bld.bldnode.make_node(self.target)
> +    try:
> +        self.compiled_tasks.append(task)
> +    except AttributeError:
> +        self.compiled_tasks = [task]
> +    return task
> + at feature("explicit_asm_target")
explicit_asm?
> + at before_method("process_source")
> +def _enable_explicit_asm_target(self):
> +    self.mappings = dict(self.mappings)  # Copy
> +    self.mappings[".S"] = _explicit_asm_target
> + at after("apply_link")
> + at feature("cprogram", "cxxprogram")
> +def process_start_files(self):
> +    if getattr(self, "start_files", False):
> +        self.link_task.dep_nodes.extend(self.bld.start_files)
>  class Item(object):
>      def __init__(self, uid, data):
>          self.uid = uid
> @@ -246,12 +273,10 @@ class Item(object):
>              target = os.path.splitext(source)[0] + ".o"
>          bld(
>              asflags=self.data["asflags"],
> -            before=["cstlib"],
>              cppflags=cppflags + self.data["cppflags"],
> -            features="asm c",
> +            features="explicit_asm_target asm c",
I think ...
           features="explicit_asm asm c",
... reads better.
>              includes=bic.includes + self.data["includes"],
> -            rule="${CC} ${ASFLAGS} ${CPPFLAGS} ${DEFINES_ST:DEFINES} ${CPPPATH_ST:INCPATHS} -c ${SRC[0]} -o ${TGT}",
> -            source=[source] + deps,
> +            source=source + deps,
>              target=target,
>          return target
> @@ -532,7 +557,12 @@ class StartFileItem(Item):
>          super(StartFileItem, self).__init__(uid, data)
>      def do_build(self, bld, bic):
> -        self.asm(bld, bic, self.data["source"], self.get(bld, "target"))
> +        tgt = self.asm(bld, bic, self.data["source"], self.get(bld, "target"))
> +        node = bld.bldnode.make_node(tgt)
> +        try:
> +            bld.start_files.append(node)
> +            bld.start_files = [node]
>          self.install_target(bld)
> @@ -626,6 +656,7 @@ class TestProgramItem(Item):
>              install_path=None,
>              ldflags=bic.ldflags + self.data["ldflags"],
>              source=self.data["source"],
> +            start_files=True,
>              stlib=self.data["stlib"],
>              target=self.get(bld, "target"),
>              use=self.data["use-before"] + bic.use + self.data["use-after"],
