[PATCH] score: Improve Scheduler Handler documentation
Sebastian Huber
Fri Sep 18 06:38:05 UTC 2020
cpukit/include/rtems/score/scheduler.h | 23 ++++++++---------
cpukit/include/rtems/score/schedulerimpl.h | 29 +++++++++++++++++++++-
2 files changed, 38 insertions(+), 14 deletions(-)
diff --git a/cpukit/include/rtems/score/scheduler.h b/cpukit/include/rtems/score/scheduler.h
index 9a6515ba1e..4b9936d756 100644
--- a/cpukit/include/rtems/score/scheduler.h
+++ b/cpukit/include/rtems/score/scheduler.h
@@ -30,12 +30,7 @@ extern "C" {
struct Per_CPU_Control;
- * @defgroup RTEMSScoreScheduler Scheduler Handler
- * @ingroup RTEMSScore
- * This handler encapsulates functionality related to managing sets of threads
- * that are ready for execution.
+ * @addtogroup RTEMSScoreScheduler
@@ -300,22 +295,24 @@ struct _Scheduler_Control {
- * @brief Registered schedulers.
+ * @brief This table contains the configured schedulers.
- * Application provided via <rtems/confdefs.h>.
+ * The table is defined by <rtems/confdefs.h> through the
+ * #CONFIGURE_SCHEDULER_TABLE_ENTRIES application configuration option.
* @see _Scheduler_Count.
extern const Scheduler_Control _Scheduler_Table[];
- * @brief Count of registered schedulers.
+ * @brief This constant contains the count of configured schedulers.
- * Application provided via <rtems/confdefs.h> on SMP configurations.
+ * In SMP configurations, the constant is defined by <rtems/confdefs.h> through
+ * the count of entries of the #CONFIGURE_SCHEDULER_TABLE_ENTRIES application
+ * configuration option.
- * It is very important that this is a compile-time constant on uni-processor
- * configurations (in this case RTEMS_SMP is not defined) so that the compiler
- * can optimize the some loops away
+ * In uniprocessor configurations, this is a compile time constant set to one.
+ * This is important so that the compiler can optimize the some loops away
* @see _Scheduler_Table.
diff --git a/cpukit/include/rtems/score/schedulerimpl.h b/cpukit/include/rtems/score/schedulerimpl.h
index e7fbb8b166..f37d9ecdc8 100644
--- a/cpukit/include/rtems/score/schedulerimpl.h
+++ b/cpukit/include/rtems/score/schedulerimpl.h
@@ -34,7 +34,34 @@ extern "C" {
#endif
- * @addtogroup RTEMSScoreScheduler
+ * @defgroup RTEMSScoreScheduler Scheduler Handler
+ * @ingroup RTEMSScore
+ * @brief This handler encapsulates functionality related to managing sets of
+ * threads that are ready for execution.
+ * Schedulers are used by the system to manage sets of threads that are ready
+ * for execution. A scheduler consists of
+ * * a scheduler algorithm implementation,
+ * * a scheduler index and an associated name, and
+ * * a set of processors own by the scheduler (may be empty, but never overlaps
+ * with a set owned by another scheduler).
+ * Each thread uses exactly one scheduler as its home scheduler. Threads may
+ * temporarily use also other scheduler due to actions of locking protocols.
+ * All properties of a scheduler can be configured and controlled by the user.
+ * Some properties are fixed at link time (defined by application configuration
+ * options), other properties can be changed at runtime through directive
+ * calls.
+ * The scheduler index, name, and initial processor set are defined for a
+ * particular application by the application configuration. The schedulers are
+ * registered in the ::_Scheduler_Table which has ::_Scheduler_Count entries.
2.26.2
