How to use lvgl on pc386 BSP.
Christian Mauderer
oss at c-mauderer.de
Sat Sep 19 08:32:43 UTC 2020
Hello Karel,
I wasn't aware that there is a framebuffer driver in the PC BSP. Maybe
an alternative to using the BSP framebuffer driver could be to just port
the FreeBSD framebuffer driver for PC and use that one? That might could
be less work than fixing the PC BSPs driver.
If you want to continue to use the BSPs driver, I can try to have a more
detailled look at it. But like I said: I would expect that the FreeBSD
driver is simpler to use.
Best regards
Christian
On 19/09/2020 00:30, Karel Gardas wrote:
> On 9/18/20 11:51 PM, Karel Gardas wrote:
>> Whole demo output looks:
>> i386: isr=0 irr=1
>> i386: isr=0 irr=1
>> FB_VESA_RM frame buffer -- driver initializing..
>> RTEMS LVGL HELLO WORLD
>> nexus0: <RTEMS Nexus device>
>> pcib0 pcibus 0
>> pci0: <PCI bus> on pcib0
>> pci0: <bridge, HOST-PCI> at device 0.0 (no driver attached)
>> pci0: <bridge, PCI-ISA> at device 1.0 (no driver attached)
>> pci0: <mass storage, ATA> at device 1.1 (no driver attached)
>> pci0: <bridge> at device 1.3 (no driver attached)
>> pci0: <display, VGA> at device 2.0 (no driver attached)
>> pci0: <network, ethernet> at device 3.0 (no driver attached)
>> cpu0
>> FB_VESA_RM open device
>> The framebuffer device was opened successfully.
>> FB_VESA_RM ioctl called, cmd=4602
>> fbxres 1024, fbyres 768
>> fbbpp 32
>> FB_VESA_RM ioctl called, cmd=4600
>> fbbpp 32
>> 1024x768, 32bpp
>> 3145728 screen size.
>> Error: failed to map framebuffer device to memory: Not supported
> ^ that was form Qemu, from my testing hw box it looks as follows. Sorry
> for the dead Reaktek. Also it looks like VBE bios is kind of limited
> since EDID recommended resolution is monitors native: 2560x1440, but
> BIOS does not support it hence offers 1920x1440 as most close.
> i386: isr=0 irr=1
> pcib0 pcibus 0
> pcib1: <PCI-PCI bridge> at device 1.0 on pci0
> pci1: <PCI bus> on pcib1
> pci1: <display, VGA> at device 5.0 (no driver attached)
> pci1: <multimedia, HDA> at device 5.1 (no driver attached)
> pcib2: <PCI-PCI bridge> irq 10 at device 10.0 on pci0
> pci2: <PCI bus> on pcib2
> re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port
> 0xd800-0xd8ff mem 0xfdfff000-0xfdffffff,0xfdff8000-0xfdffbfff irq 10 at
> device 0.0 on pci2
> re0: Chip rev. 0x2c000000
> re0: MAC rev. 0x00200000
> re0: PHY write failed
> re0: PHY read failed
> re0: attaching PHYs failed
> device_attach: re0 attach returned 6
> pci0: <mass storage, SATA> at device 17.0 (no driver attached)
> pci0: <serial bus, USB> at device 18.0 (no driver attached)
> pci0: <serial bus, USB> at device 18.2 (no driver attached)
> pci0: <serial bus, USB> at device 19.0 (no driver attached)
> pci0: <serial bus, USB> at device 19.2 (no driver attached)
> pci0: <multimedia, HDA> at device 20.2 (no driver attached)
> pci0: <bridge, PCI-ISA> at device 20.3 (no driver attached)
> pcib3: <PCI-PCI bridge> at device 20.4 on pci0
> pci3: <PCI bus> on pcib3
> re0: <RealTek 8169/8169S/8169SB(L)/8110S/8110SB(L) Gigabit Ethernet>
> port 0xe800-0xe8ff mem 0xfebffc00-0xfebffcff irq 3 at device 5.0 on pci3
> re0: Chip rev. 0x04000000
> re0: MAC rev. 0x00000000
> miibus0: <MII bus> on re0
> rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
> rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX,
> 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master,
> 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1w
> info: re0: Using defaults for TSO: 65518/35/2048
> info: re0: Ethernet address: 00:0e:2e:7b:da:0b
> pci0: <serial bus, USB> at device 20.5 (no driver attached)
> pci0: <serial bus, USB> at device 22.0 (no driver attached)
> pci0: <serial bus, USB> at device 22.2 (no driver attached)
> pci0: <bridge, HOST-PCI> at device 24.0 (no driver attached)
> pci0: <bridge, HOST-PCI> at device 24.1 (no driver attached)
> pci0: <bridge, HOST-PCI> at device 24.2 (no driver attached)
> pci0: <bridge, HOST-PCI> at device 24.3 (no driver attached)
> pci0: <bridge, HOST-PCIFB_VESA_RM open device
>> at device 24.4 (no driver attached)
> cpu0
> TheFB_VESA_RM ioctl called, cmd=4602
> fbxres 1920, fbyres 1440
> fbbpp 32
> fbbpp 32
> 1920x1440, 32bpp
> 11059200 screen size.
> *** FATAL ***
> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> Exception 13 caught at PC ffffffff by thread 167837697
> Processor execution context at time of the fault was :
> EAX = 0 EBX = 0 ECX = 3662e4 EDX = 0
> ESI = 0 EDI = 3662bc EBP = ff ESP = 3af0a8
> Error code pushed by processor itself (if not 0) = 0
> Call Stack Trace of EIP:
> 0xef7eef7e 0xffffffff
> *** FATAL ***
> Exception 13 caught at PC 2ae863 by thread 167837697
> EAX = b EBX = ffffffff ECX = 339fee EDX = 0
> ESI = 3 EDI = 2adc40 EBP = 3aef58 ESP = 3aef1c
> 0x002906f8 0x002add03 0x002a7a4e 0x002ae4d9
> 0x002ae2f8
> RTEMS version: 6.0.0.97559a7077ee0996012bcbc6952bbfb96923d6ae
> RTEMS tools: 10.2.1 20200904 (RTEMS 6, RSB
> a81a237f3e2318d88a16b31aadb82333498e06fd, Newlib a0d7982)
> executing thread ID: 0x08a010001
> executing thread name: UI1
