[PATCH v1 1/2] bsps/shared/ofw: Implement RTEMS OFW interface
Christian Mauderer oss at c-mauderer.de
Sat Sep 19 10:43:37 UTC 2020
Hello Niteesh,
sorry for adding another delay: I think the new build system needs a bit
of time to settle. As soon as there are some more PASS in the table that
Sebastian created [1] (especially for beagle) we should try to get these
patches merged. Before that I would like to avoid big changes because it
might get hard to distinguish new bugs from build system bugs.
Best regards
Christian
[1] https://devel.rtems.org/wiki/Release/6/Waf%20BSP%20Checklist
On 16/09/2020 19:05, Niteesh G. S. wrote:
> Hello,
> Sorry for the delay, I was a bit occupied with my university work.
> Now since the new build system is merged I would like to get my
> GSoC work merged too.
> The goal of this series patches is to implement the OFW API into RTEMS
> and modify libBSD to use this RTEMS API instead of its own.
> Thanks,
> Niteesh.
> On Wed, Sep 16, 2020 at 10:33 PM G S Niteesh Babu <niteesh.gs at gmail.com
> <mailto:niteesh.gs at gmail.com>> wrote:
>     RTEMS OFW is a FDT only implementation of the OpenFirmWare
>     interface. This API is created to be compatible with FreeBSD
>     OpenFirmWare interface. The main intention is to make
>     porting of FreeBSD drivers to RTEMS easier.
>     Most functions implemented have an direct one-one mapping
>     with the original OFW API and some extra auxiliary functions
>     were implemented to make working with device trees easier in
>     RTEMS.
>     Update #3784
>      bsps/include/ofw/ofw.h        | 548 +++++++++++++++++++++++++++
>      bsps/include/ofw/ofw_compat.h |  74 ++++
>      bsps/shared/ofw/ofw.c         | 682 ++++++++++++++++++++++++++++++++++
>      spec/build/bsps/obj.yml       |   5 +
>      4 files changed, 1309 insertions(+)
>      create mode 100644 bsps/include/ofw/ofw.h
>      create mode 100644 bsps/include/ofw/ofw_compat.h
>      create mode 100644 bsps/shared/ofw/ofw.c
>     diff --git a/bsps/include/ofw/ofw.h b/bsps/include/ofw/ofw.h
>     new file mode 100644
>     index 0000000000..411010be89
>     --- /dev/null
>     +++ b/bsps/include/ofw/ofw.h
>     @@ -0,0 +1,548 @@
>     +/* SPDX-License-Identifier: BSD-2-Clause */
>     + * @file
>     + * @ingroup ofw
>     + * RTEMS FDT implementation of OpenFirmWare Interface.
>     + * RTEMS OFW is a FDT only implementation of the OpenFirmWare
>     interface.
>     + * This API is created to be compatible with FreeBSD OpenFirmWare
>     interface.
>     + * The main intention is to make porting of FreeBSD drivers to
>     RTEMS easier.
>     + * Copyright (C) 2020 Niteesh Babu G S <niteesh.gs at gmail.com
>     + * Redistribution and use in source and binary forms, with or without
>     + * modification, are permitted provided that the following conditions
>     + * are met:
>     + * 1. Redistributions of source code must retain the above copyright
>     + *    notice, this list of conditions and the following disclaimer.
>     + * 2. Redistributions in binary form must reproduce the above copyright
>     in the
>     + *    documentation and/or other materials provided with the
>     distribution.
>     + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>     CONTRIBUTORS "AS IS"
>     + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>     LIMITED TO, THE
>     + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>     PARTICULAR PURPOSE
>     + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>     CONTRIBUTORS BE
>     + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>     + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>     + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>     BUSINESS
>     + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>     WHETHER IN
>     + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>     OTHERWISE)
>     + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>     ADVISED OF THE
>     + * POSSIBILITY OF SUCH DAMAGE.
>     +#ifndef _OFW_H
>     +#define _OFW_H
>     +#ifdef __cplusplus
>     +extern "C" {
>     +#endif
>     +#include <rtems.h>
>     +#include <stdint.h>
>     +#include <sys/types.h>
>     + * Represents a node in the device tree. The offset from fdtp to
>     node is used
>     + * instead of fdt offset to make sure this is compatible with OF
>     interface in
>     + * FreeBSD.
>     +typedef uint32_t  phandle_t;
>     + * Represents the effective phandle of the node.
>     +typedef uint32_t  ihandle_t;
>     + * Represents the data type of the buffer.
>     +typedef uint32_t  pcell_t;
>     + * @struct rtems_ofw_memory_area
>     + * This is used to represent elements(FDT properties) that define
>     + * region of memory address.
>     +typedef struct {
>     +  /** The start address of the memory region. */
>     +  uint32_t start;
>     +  /** The size of the memory region. */
>     +  uint32_t size;
>     +} rtems_ofw_memory_area;
>     + * @struct rtems_ofw_ranges
>     + * This is used to represent the ranges property in the device tree.
>     +typedef struct {
>     +  /** The physical address within the child bus address space */
>     +  uint32_t child_bus;
>     +  /** The physical address within the parent bus address space */
>     +  uint32_t parent_bus;
>     +  /** The size of the range in the child’s address space */
>     +  uint32_t size;
>     +} rtems_ofw_ranges;
>     + * @brief Gets the node that is next to @a node.
>     + * @param[in] node Node offset
>     + * @retval Peer node offset Successful operation.
>     + * @retval 0 No peer node or invalid node handle
>     +phandle_t rtems_ofw_peer(
>     +  phandle_t   node
>     + * @brief Gets the node that is the child of @a node.
>     + * @retval child node offset Successful operation.
>     + * @retval 0 No child node or invalid node handle
>     +phandle_t rtems_ofw_child(
>     +  phandle_t   node
>     + * @brief Gets the node that is the parent of @a node.
>     +phandle_t rtems_ofw_parent(
>     +  phandle_t   node
>     + * @brief Gets the length of the property mentioned in @a propname.
>     + * @param[in] prop Property name
>     + * @retval -1 Invalid node or property
>     + * @retval  Length of property on successful operation
>     +ssize_t rtems_ofw_get_prop_len(
>     +  phandle_t   node,
>     +  const char *propname
>     + * @brief Gets the value of property mentioned in @a propname.
>     + * @param[out] buf The property value gets stored in this buffer
>     (Pre-allocated)
>     + * @param[in] len Length of the buffer
>     +ssize_t rtems_ofw_get_prop(
>     +  phandle_t    node,
>     +  const char  *propname,
>     +  void        *buf,
>     +  size_t       len
>     + * @brief Gets the value of property mentioned in @a prop.
>     + * Gets the value of property of @a node and converts the value
>     into the host's
>     + * endianness.
>     buffer(Pre-allocated)
>     + * after converted to the host's endianness
>     +ssize_t rtems_ofw_get_enc_prop(
>     +  phandle_t    node,
>     +  const char  *prop,
>     +  pcell_t     *buf,
>     +  size_t       len
>     + * @brief Checks if the property @a propname is present in @a node.
>     + * @param[in] propname Property name
>     + *  @retval  0 Property not present.
>     + *  @retval  1 Property is present.
>     +int rtems_ofw_has_prop(
>     +  phandle_t    node,
>     + * @brief Searches for property @a propname in @a node.
>     + * Searches the node and its parent recursively for the property
>     and fills the
>     + * buffer with the first found value.
>     (Pre-allocated)
>     + * @retval  Length of the property if property is found.
>     + * @retval  -1 Property is not found.
>     +ssize_t rtems_ofw_search_prop(
>     +  phandle_t    node,
>     +  void        *buf,
>     +  size_t       len
>     and fills the
>     + * buffer with the first value found after converting it to the
>     endianness of
>     + * the host.
>     +ssize_t rtems_ofw_search_enc_prop(
>     +  phandle_t    node,
>     +  pcell_t     *buf,
>     +  size_t       len
>     + * Same as rtems_ofw_getprop, but the @a buf is allocated in this
>     routine and
>     + * the user is responsible for freeing it.
>     + * @param[out] buf The buffer is allocated in this routine and user is
>     + * responsible for freeing.
>     +ssize_t rtems_ofw_get_prop_alloc(
>     +  phandle_t    node,
>     +  void       **buf
>     + * @brief Gets multiple values of the property @a propname.
>     + * Same as rtems_ofw_getprop_alloc but it can read properties with
>     multiple
>     + * values.
>     + * For eg: reg = <0x1000 0x10 0x2000 0x20>
>     + * @param[in] elsz Size of the single value
>     + * @retval   Number of values read.
>     +ssize_t rtems_ofw_get_prop_alloc_multi(
>     +  phandle_t    node,
>     +  int          elsz,
>     +  void       **buf
>     + * Same as rtems_ofw_getprop_alloc but the value stored in the
>     buffer is
>     + * converted into the host's endianness.
>     +ssize_t rtems_ofw_get_enc_prop_alloc(
>     +  phandle_t    node,
>     +  void       **buf
>     + * Same as rtems_ofw_getprop_alloc_multi but the values stored in
>     the buffer
>     + * are converted to the host's endianness.
>     +ssize_t rtems_ofw_get_enc_prop_alloc_multi(
>     +  phandle_t     node,
>     +  int           elsz,
>     +  void        **buf
>     + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc
>     functions.
>     + * @param[in] buf Buffer to be freed
>     +void rtems_ofw_free(
>     +  void   *buf
>     + * @brief Finds the next property of @a node.
>     + * Finds the next property of the node and when @a propname is NULL
>     it returns
>     + * the value in the first property.
>     + * @param[in] previous Previous property name
>     + * @param[out] buf The value of the next property gets stored in
>     this buffer
>     + * (Pre-allocated)
>     + * @retval  -1 node or previous property does not exist
>     + * @retval   0 no more properties
>     + * @retval   1 success
>     +int rtems_ofw_next_prop(
>     +  phandle_t    node,
>     +  const char  *previous,
>     +  char        *buf,
>     +  size_t       len
>     + * @brief Sets the property @name of @a node to @a buf.
>     + * @param[in] name Property name
>     + * @param[in] buf Buffer contains the value to be set.
>     + * @retval  -1 node does not exist
>     + * @retval   0 on success
>     + * @retval   libFDT error codes on unsuccessful setting operation
>     +int rtems_ofw_set_prop(
>     +  phandle_t    node,
>     +  const char  *name,
>     +  const void  *buf,
>     +  size_t       len
>     + * @brief Converts a device specifier to a fully qualified path name.
>     + * @param[in] dev device specifier
>     + * @param[out] buf The path is filled into the buffer(Pre-allocated)
>     + * @param[in] length of the buffer
>     + * @retval  -1 always. Unimplemented.
>     +ssize_t rtems_ofw_canon(
>     +  const char  *dev,
>     +  char        *buf,
>     +  size_t       len
>     + * @brief Finds the node at the given path
>     + * @param[in] path to the node from root
>     + * @retval   node handle on success
>     +phandle_t rtems_ofw_find_device(
>     +  const char  *path
>     + * @brief This routine converts effective phandle @a xref to node
>     offset.
>     + * @param[in] xref Node phandle
>     + * @retval Node offset on success
>     + * @retval Node phandle on failure
>     +phandle_t rtems_ofw_node_from_xref(
>     +  phandle_t   xref
>     + * @brief This routine converts node offset to effective phandle of
>     @a node.
>     + * @retval Node phandle on success
>     + * @retval Node offset on failure
>     +phandle_t rtems_ofw_xref_from_node(
>     +  phandle_t   node
>     + * instance handles(ihandle_t) as same as phandles in the FDT
>     implementation
>     + * of OF interface.
>     + * @brief Converts @a instance handle to phandle.
>     + * instance are same as node offsets in FDT.
>     + * @param[in] instance Node offset
>     + * @retval phandle of node on success.
>     + * @retval instance of node on failure.
>     +phandle_t rtems_ofw_instance_to_package(
>     +  ihandle_t   instance
>     + * @brief Find the node's path from phandle.
>     + * @param[out] buf Path is filled into this buffer(Pre-allocated).
>     + * @param[in] len Length of the buffer.
>     +ssize_t rtems_ofw_package_to_path(
>     +  phandle_t   node,
>     +  char       *buf,
>     +  size_t      len
>     + * @brief Find the node's path from ihandle.
>     +ssize_t rtems_ofw_instance_to_path(
>     +  ihandle_t  instance,
>     +  char      *buf,
>     +  size_t     len
>     + * @brief Queries the node's reg value.
>     + * This routine fills the buffer @a buf with the values in reg
>     property of node
>     + * @a node. It reads all the values of the property and fills the
>     buffer to max
>     + * size.
>     + * This routine is local to RTEMS OFW and does not have an
>     corresponding
>     + * FreeBSD OFW pair.
>     + * @param[out] buf Register values are stored in this
>     + * @param[in] size Length of the buffer.
>     + * @retval -1 If reg property is missing.
>     + * @retval  Length of the reg property in bytes.
>     +int rtems_ofw_get_reg(
>     +  phandle_t              node,
>     +  rtems_ofw_memory_area *buf,
>     +  size_t                 size
>     + * @brief Queries the node's interrupt value.
>     + * This routine fills the buffer @a buf with the interrupt number.
>     In case of
>     + * multiple numbers it fills the buffer to its full extent.
>     corresponding
>     + * @param[out] buf Interrupt values are stored in this
>     + * @retval -1 If interrupts property is missing.
>     + * @retval  The number of interrupt numbers read.
>     +int rtems_ofw_get_interrupts(
>     +  phandle_t            node,
>     +  rtems_vector_number *buf,
>     +  size_t               size
>     + * @brief Queries the node's status.
>     corresponding
>     + * @retval true  Status is OK or empty.
>     + * @retval false Status is not OK or missing.
>     +bool rtems_ofw_node_status( phandle_t node );
>     + * @brief Gets node phandle from compatible property.
>     corresponding
>     + * @param[in] compat Compatible string
>     + * @retval 0 Node with @a compat as compatible string not found
>     + * @retval Node phandle on success.
>     +phandle_t rtems_ofw_find_device_by_compat( const char *compat );
>     +#ifdef __cplusplus
>     +#endif
>     +#endif /* _OFW_H */
>     diff --git a/bsps/include/ofw/ofw_compat.h
>     b/bsps/include/ofw/ofw_compat.h
>     index 0000000000..be4a5ea3ce
>     --- /dev/null
>     +++ b/bsps/include/ofw/ofw_compat.h
>     @@ -0,0 +1,74 @@
>     + * @file
>     + * @ingroup ofw
>     + * This file defines necessary symbols to make the RTEMS OFW API
>     compatible
>     + * with FreeBSD OFW.
>     + * are met:
>     in the
>     distribution.
>     LIMITED TO, THE
>     PARTICULAR PURPOSE
>     CONTRIBUTORS BE
>     BUSINESS
>     WHETHER IN
>     OTHERWISE)
>     ADVISED OF THE
>     +#ifndef _OFW_COMPAT_H
>     +#define _OFW_COMPAT_H
>     +#ifdef __cplusplus
>     +extern "C" {
>     +#endif
>     +#include <ofw/ofw.h>
>     +#define OF_peer                   rtems_ofw_peer
>     +#define OF_child                  rtems_ofw_child
>     +#define OF_parent                 rtems_ofw_parent
>     +#define OF_getproplen             rtems_ofw_get_prop_len
>     +#define OF_getprop                rtems_ofw_get_prop
>     +#define OF_getencprop             rtems_ofw_get_enc_prop
>     +#define OF_hasprop                rtems_ofw_has_prop
>     +#define OF_searchprop             rtems_ofw_search_prop
>     +#define OF_searchencprop          rtems_ofw_search_enc_prop
>     +#define OF_getprop_alloc          rtems_ofw_get_prop_alloc
>     +#define OF_getprop_alloc_multi    rtems_ofw_get_prop_alloc_multi
>     +#define OF_getencprop_alloc_multi rtems_ofw_get_enc_prop_alloc_multi
>     +#define OF_getencprop_alloc       rtems_ofw_get_enc_prop_alloc
>     +#define OF_prop_free              rtems_ofw_free
>     +#define OF_nextprop               rtems_ofw_next_prop
>     +#define OF_setprop                rtems_ofw_set_prop
>     +#define OF_canon                  rtems_ofw_canon
>     +#define OF_finddevice             rtems_ofw_find_device
>     +#define OF_package_to_path        rtems_ofw_package_to_path
>     +#define OF_node_from_xref         rtems_ofw_node_from_xref
>     +#define OF_xref_from_node         rtems_ofw_xref_from_node
>     +#define OF_instance_to_package    rtems_ofw_instance_to_package
>     +#define OF_instance_to_path       rtems_ofw_instance_to_path
>     +#ifdef __cplusplus
>     +#endif
>     +#endif /* _OFW_COMPAT_H */
>     diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
>     index 0000000000..2b1dff8bf8
>     --- /dev/null
>     +++ b/bsps/shared/ofw/ofw.c
>     @@ -0,0 +1,682 @@
>     + * @file
>     + * @ingroup ofw
>     + * are met:
>     in the
>     distribution.
>     LIMITED TO, THE
>     PARTICULAR PURPOSE
>     CONTRIBUTORS BE
>     BUSINESS
>     WHETHER IN
>     OTHERWISE)
>     ADVISED OF THE
>     +#ifdef HAVE_CONFIG_H
>     +#include "config.h"
>     +#endif
>     +#include <bsp/fdt.h>
>     +#include <sys/param.h>
>     +#include <libfdt.h>
>     +#include <assert.h>
>     +#include <rtems/sysinit.h>
>     +const void *fdtp = NULL;
>     +static phandle_t rtems_fdt_offset_to_phandle( int offset )
>     +  if (offset < 0) {
>     +    return 0;
>     +  return (phandle_t)offset + fdt_off_dt_struct(fdtp);
>     +static int rtems_fdt_phandle_to_offset( phandle_t handle )
>     +  int off;
>     +  int fdt_off;
>     +  off = (int) handle;
>     +  fdt_off = fdt_off_dt_struct(fdtp);
>     +  if (off < fdt_off) {
>     +    return -1;
>     +  return off - fdt_off;
>     +static void rtems_ofw_init( void ) {
>     +  int rv;
>     +  const void *fdt;
>     +  fdt = bsp_fdt_get();
>     +  rv = fdt_check_header(fdt);
>     +   * If the FDT is invalid exit through fatal.
>     +  if (rv != 0) {
>     +    rtems_fatal_error_occurred(RTEMS_NOT_CONFIGURED);
>     +  fdtp = fdt;
>     +RTEMS_SYSINIT_ITEM(
>     +  rtems_ofw_init,
>     +  RTEMS_SYSINIT_BSP_PRE_DRIVERS,
>     +  RTEMS_SYSINIT_ORDER_FIRST
>     +phandle_t rtems_ofw_peer( phandle_t node )
>     +  int offset;
>     +  if (node == 0) {
>     +    int root = fdt_path_offset(fdtp, "/");
>     +    return rtems_fdt_offset_to_phandle(root);
>     +  offset = rtems_fdt_phandle_to_offset(node);
>     +  if (offset < 0) {
>     +    return 0;
>     +  offset = fdt_next_subnode(fdtp, offset);
>     +  return rtems_fdt_offset_to_phandle(offset);
>     +phandle_t rtems_ofw_child( phandle_t node )
>     +  int offset;
>     +  if (offset < 0) {
>     +    return 0;
>     +  offset = fdt_first_subnode(fdtp, offset);
>     +phandle_t rtems_ofw_parent( phandle_t node )
>     +  int offset;
>     +  if (offset < 0) {
>     +    return 0;
>     +  offset = fdt_parent_offset(fdtp, offset);
>     +  phandle_t node,
>     +  int offset;
>     +  int len;
>     +  const void *prop;
>     +  if (offset < 0) {
>     +    return -1;
>     +  prop = fdt_getprop(fdtp, offset, propname, &len);
>     +  if (prop == NULL && strcmp(propname, "name") == 0) {
>     +    fdt_get_name(fdtp, offset, &len);
>     +    return len + 1;
>     +  if (prop == NULL && strcmp(propname, "/chosen") == 0) {
>     +    if (strcmp(propname, "fdtbootcpu") == 0)
>     +      return sizeof(pcell_t);
>     +    if (strcmp(propname, "fdtmemreserv") == 0)
>     +      return 2 * sizeof(uint64_t) * fdt_num_mem_rsv(fdtp);
>     +  if (prop == NULL) {
>     +    return -1;
>     +  return len;
>     +  phandle_t    node,
>     +  void        *buf,
>     +  size_t       bufsize
>     +  const void *prop;
>     +  int offset;
>     +  int len;
>     +  uint32_t cpuid;
>     +  if (offset < 0) {
>     +    return -1;
>     +    prop = fdt_get_name(fdtp, offset, &len);
>     +    strncpy(buf, prop, bufsize);
>     +    return len + 1;
>     +    if (strcmp(propname, "fdtbootcpu") == 0) {
>     +      cpuid = cpu_to_fdt32(fdt_boot_cpuid_phys(fdtp));
>     +      len = sizeof(cpuid);
>     +      prop = &cpuid;
>     +    if (strcmp(propname, "fdtmemreserv") == 0) {
>     +      prop = (char *)fdtp + fdt_off_mem_rsvmap(fdtp);
>     +      len = sizeof(uint64_t)*2*fdt_num_mem_rsv(fdtp);
>     +    return -1;
>     +  bcopy(prop, buf, MIN(len, bufsize));
>     +  return len;
>     +  phandle_t    node,
>     +  const char  *prop,
>     +  pcell_t     *buf,
>     +  size_t       len
>     +  ssize_t rv;
>     +  assert(len % 4 == 0);
>     +  rv = rtems_ofw_get_prop(node, prop, buf, len);
>     +  if (rv < 0) {
>     +    return rv;
>     +  for (int i = 0; i < (len / 4); i++) {
>     +    buf[i] = fdt32_to_cpu(buf[i]);
>     +  return rv;
>     +  phandle_t    node,
>     +  ssize_t rv;
>     +  rv = rtems_ofw_get_prop_len(node, propname);
>     +  return rv >= 0 ? 1 : 0;
>     +  phandle_t    node,
>     +  void        *buf,
>     +  size_t       len
>     +  ssize_t rv;
>     +  for (; node != 0; node = rtems_ofw_parent(node)) {
>     +    if ((rv = rtems_ofw_get_prop(node, propname, buf, len) != -1)) {
>     +      return rv;
>     +  return -1;
>     +  phandle_t    node,
>     +  pcell_t     *buf,
>     +  size_t       len
>     +  ssize_t rv;
>     +    if ((rv = rtems_ofw_get_enc_prop(node, propname, buf, len) !=
>     -1)) {
>     +      return rv;
>     +  return -1;
>     +  phandle_t    node,
>     +  void       **buf
>     +  ssize_t len;
>     +  *buf = NULL;
>     +  if ((len = rtems_ofw_get_prop_len(node, propname)) == -1) {
>     +    return -1;
>     +  if (len > 0) {
>     +    *buf = malloc(len);
>     +    if (*buf == NULL) {
>     +      return -1;
>     +    if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
>     +      rtems_ofw_free(buf);
>     +      *buf = NULL;
>     +      return -1;
>     +  return len;
>     +  phandle_t    node,
>     +  int          elsz,
>     +  void       **buf
>     +  ssize_t len;
>     +  *buf = NULL;
>     +  if ((len = rtems_ofw_get_prop_len(node, propname)) == -1 ||
>     +      (len % elsz != 0)) {
>     +    return -1;
>     +  if (len > 0) {
>     +      return -1;
>     +      *buf = NULL;
>     +      return -1;
>     +  return (len / elsz);
>     +  phandle_t    node,
>     +  void       **buf
>     +  ssize_t len;
>     +  *buf = NULL;
>     +    return -1;
>     +  if (len > 0) {
>     +      return -1;
>     +    if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
>     +      *buf = NULL;
>     +      return -1;
>     +  return len;
>     +  phandle_t     node,
>     +  int           elsz,
>     +  void        **buf
>     +  ssize_t len;
>     +  *buf = NULL;
>     +    return -1;
>     +  if (len > 0) {
>     +      return -1;
>     +      *buf = NULL;
>     +      return -1;
>     +void rtems_ofw_free( void *buf )
>     +  free(buf);
>     +  phandle_t    node,
>     +  char        *buf,
>     +  size_t       len
>     +  const void *name;
>     +  const void *prop;
>     +  int offset;
>     +  if (offset < 0) {
>     +    return -1;
>     +  if (previous == NULL) {
>     +    offset = fdt_first_property_offset(fdtp, offset);
>     +  } else {
>     +    fdt_for_each_property_offset(offset, fdtp, offset) {
>     +      prop = fdt_getprop_by_offset(fdtp, offset, (const char
>     **)&name, NULL);
>     +      if (prop == NULL)
>     +        return -1;
>     +      if (strcmp(previous, name) != 0)
>     +        continue;
>     +      offset = fdt_next_property_offset(fdtp, offset);
>     +      break;
>     +  if (offset < 0)
>     +    return 0;
>     +  prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name,
>     &offset);
>     +  if (prop == NULL)
>     +    return -1;
>     +  strncpy(buf, name, len);
>     +  return 1;
>     +  phandle_t    node,
>     +  const char  *name,
>     +  const void  *buf,
>     +  size_t       len
>     +  int offset;
>     +  if (offset < 0)
>     +    return -1;
>     +  if (fdt_setprop_inplace(fdtp, offset, name, buf, len) != 0)
>     +    return (fdt_setprop(fdtp, offset, name, buf, len));
>     +  return 0;
>     +phandle_t rtems_ofw_find_device( const char *path )
>     +  int offset;
>     +  offset = fdt_path_offset(fdtp, path);
>     +  if (offset < 0)
>     +    return -1;
>     +static phandle_t rtems_ofw_get_effective_phandle(
>     +  phandle_t node,
>     +  phandle_t xref
>     +  phandle_t child;
>     +  phandle_t ref;
>     +  for (child = rtems_ofw_child(node); child != 0; child =
>     rtems_ofw_peer(child)) {
>     +    ref = rtems_ofw_get_effective_phandle(child, xref);
>     +    if (ref != -1)
>     +      return ref;
>     +    if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref))
>     == -1 &&
>     +        rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref,
>     sizeof(ref)) == -1 &&
>     +        rtems_ofw_get_enc_prop(child, "linux,phandle", &ref,
>     sizeof(ref)) == -1
>     +      continue;
>     +    if (ref == xref)
>     +      return child;
>     +  return -1;
>     +phandle_t rtems_ofw_node_from_xref( phandle_t xref )
>     +  phandle_t node;
>     +  if ((node = rtems_ofw_get_effective_phandle(rtems_ofw_peer(0),
>     xref)) == -1)
>     +    return xref;
>     +  return node;
>     +phandle_t rtems_ofw_xref_from_node( phandle_t node )
>     +  phandle_t ref;
>     +    if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref))
>     == -1 &&
>     +        rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref,
>     +        rtems_ofw_get_enc_prop(node, "linux,phandle", &ref,
>     sizeof(ref)) == -1)
>     +      return node;
>     +    return ref;
>     +phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
>     +  return rtems_ofw_node_from_xref(instance);
>     +  phandle_t   node,
>     +  char       *buf,
>     +  size_t      len
>     +  int offset;
>     +  int rv;
>     +  rv = fdt_get_path(fdtp, offset, buf, len);
>     +  if (rv != 0)
>     +    return -1;
>     +  return rv;
>     +  char      *buf,
>     +  size_t     len
>     +  int offset;
>     +  int rv;
>     +  offset = rtems_ofw_instance_to_package(instance);
>     +  offset = rtems_fdt_phandle_to_offset(offset);
>     +  if (rv != 0)
>     +    return -1;
>     +  return rv;
>     +  phandle_t              node,
>     +  size_t                 size
>     +  int len;
>     +  int offset;
>     +  int nranges;
>     +  int nregs;
>     +  phandle_t parent;
>     +  rtems_ofw_ranges range;
>     +  const rtems_ofw_ranges *ptr;
>     +  len = rtems_ofw_get_enc_prop(node, "reg", (pcell_t *)buf, size);
>     +  if (len <= 0) {
>     +    return len;
>     +  nregs = MIN(len, size) / sizeof(rtems_ofw_memory_area);
>     +  for (parent = rtems_ofw_parent(node); parent > 0;
>     +      parent = rtems_ofw_parent(parent)) {
>     +    offset = rtems_fdt_phandle_to_offset(parent);
>     +    ptr = fdt_getprop(fdtp, offset, "ranges", &len);
>     +    if (len < 0) {
>     +      break;
>     +    nranges = len / sizeof(rtems_ofw_ranges);
>     +    offset = 0;
>     +    for (int i=0; i < nregs; i++) {
>     +      for (int j=0; j < nranges; j++) {
>     +        range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
>     +        range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
>     +        range.size = fdt32_to_cpu(ptr[j].size);
>     +        if (buf[i].start >= range.child_bus &&
>     +            buf[i].start < range.child_bus + range.size) {
>     +          offset = range.parent_bus - range.child_bus;
>     +          break;
>     +      buf[i].start += offset;
>     +  return nregs;
>     +  phandle_t            node,
>     +  size_t               size
>     +  int rv;
>     +  rv = rtems_ofw_get_enc_prop(node, "interrupts", buf, size);
>     +  if (rv <= 0) {
>     +    return rv;
>     +  return MIN(size, rv) / sizeof(rtems_vector_number);
>     +  int len;
>     +  const char buf[10];
>     +  len = rtems_ofw_get_prop(node, "status", &buf[0], sizeof(buf));
>     +  if ((len == -1) ||
>     +      (strncmp(buf, "okay", MIN(5, len)) == 0) ||
>     +      (strncmp(buf, "ok", MIN(3, len)) == 0)) {
>     +      return true;
>     +  return false;
>     +  int offset;
>     +  offset = fdt_node_offset_by_compatible(fdtp, -1, compat);
>     diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
>     index 8809238057..0ea07fc83d 100644
>     --- a/spec/build/bsps/obj.yml
>     +++ b/spec/build/bsps/obj.yml
>     @@ -24,6 +24,10 @@ install:
>        - bsps/include/bsp/u-boot.h
>        - bsps/include/bsp/uart-output-char.h
>        - bsps/include/bsp/utility.h
>     +- destination: ${BSP_INCLUDEDIR}/ofw
>     +  source:
>     +  - bsps/include/ofw/ofw.h
>     +  - bsps/include/ofw/ofw_compat.h
>      - destination: ${BSP_INCLUDEDIR}/libchip
>        source:
>        - bsps/include/libchip/am29lv160.h
>     @@ -104,4 +108,5 @@ source:
>      - bsps/shared/dev/serial/z85c30_reg.c
>      - bsps/shared/start/bootcard.c
>      - bsps/shared/rtems-version.c
>     +- bsps/shared/ofw/ofw.c
>      type: build
>     2.17.1
> devel mailing list
> devel at rtems.org
