[PATCH 2/3] bsp/motorola_powerpc: Remove obsolete GCC option
Sebastian Huber
Sun Sep 20 15:47:56 UTC 2020
commit 20c89ab7c5091ee48535392cae2177aa1a1c43eb
Author: Segher Boessenkool <segher at kernel.crashing.org>
Date: Fri Jan 12 21:50:52 2018 +0100
rs6000: Remove -mstring
-mstring is only enabled by default on 601, and with -Os on some
configurations. It is almost always slower (than not using it) and
does not very often lead to smaller code.
This patch disables it. If a user uses -mstring he gets a warning
(but not with -mno-string). I left the target attribute in place, it
just doesn't do anything anymore.
The patch also deletes a whole bunch of code. The 'N' and 'O' output
modifiers are now unused, but now is not the time to delete them.
spec/build/bsps/powerpc/motorola_powerpc/abi.yml | 3 ---
spec/build/bsps/powerpc/motorola_powerpc/boot.yml | 2 +-
2 files changed, 1 insertion(+), 4 deletions(-)
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/abi.yml b/spec/build/bsps/powerpc/motorola_powerpc/abi.yml
index f3e4613658..5e1d47b169 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/abi.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/abi.yml
@@ -12,21 +12,18 @@ default-by-variant:
- value:
- -mcpu=7400
- -mmultiple
- - -mstring
- -mstrict-align
variants:
- powerpc/qemuprep-altivec
- value:
- -mcpu=powerpc
- -mmultiple
- - -mstring
- -mstrict-align
variants:
- powerpc/qemuprep
- value:
- -mcpu=604
- -mmultiple
- - -mstring
- -mstrict-align
- -meabi
variants:
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/boot.yml b/spec/build/bsps/powerpc/motorola_powerpc/boot.yml
index 3f7a9e3dc8..8c8c0eb372 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/boot.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/boot.yml
@@ -19,7 +19,7 @@ do-build: |
if f != "-meabi":
flags += " " + f
asmflags = "-DASM " + flags
- cflags = "-msoft-float -mstrict-align -fno-builtin -Wall -mmultiple -mstring -O2 -fomit-frame-pointer -ffixed-r13 -mno-sdata " + flags
+ cflags = "-msoft-float -mstrict-align -fno-builtin -Wall -mmultiple -O2 -fomit-frame-pointer -ffixed-r13 -mno-sdata " + flags
source = []
source.append(cc(self, bld, bic, asmflags, "bsps/powerpc/motorola_powerpc/bootloader/head.S"))
source.append(cc(self, bld, bic, asmflags, "bsps/powerpc/motorola_powerpc/bootloader/exception.S"))
2.26.2
