[PATCH v4] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Utkarsh Rai utkarsh.rai60 at gmail.com
Mon Sep 21 15:15:32 UTC 2020
Closes #3890
Signed-off-by: Utkarsh Rai <utkarsh.rai60 at gmail.com>
 spec/build/testsuites/psxtests/grp.yml        |   2 +
 .../psxtests/psxclocknanosleep01.yml          |  20 +++
 .../psxtests/psxclocknanosleep01/init.c       |  94 ++++++++++++++
 .../psxclocknanosleep01.doc                   |  13 ++
 .../psxclocknanosleep01.scn                   |  41 ++++++
 .../test-clock-nanosleep.c                    | 120 ++++++++++++++++++
 6 files changed, 290 insertions(+)
 create mode 100644 spec/build/testsuites/psxtests/psxclocknanosleep01.yml
 create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
 create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
 create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
 create mode 100644 testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index 47dedac275..3342fc6c18 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -79,6 +79,8 @@ links:
   uid: psxclock
 - role: build-dependency
   uid: psxclock01
+- role: build-dependency
+  uid: psxclocknanosleep01
   uid: psxclockrealtime01
diff --git a/spec/build/testsuites/psxtests/psxclocknanosleep01.yml b/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
new file mode 100644
index 0000000000..39ec1657d2
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 Utkarsh Rai (utkarsh.rai60 at mail.com)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxclocknanosleep01/init.c
+- testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
+stlib: []
+target: testsuites/psxtests/psxclocknanosleep01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/psxclocknanosleep01/init.c b/testsuites/psxtests/psxclocknanosleep01/init.c
index 0000000000..a5cb4d6054
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/init.c
@@ -0,0 +1,94 @@
+/* SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Utkarsh Rai
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/linkersets.h>
+#include <rtems/test.h>
+#include <rtems/test-info.h>
+#include <tmacros.h>
+const char rtems_test_name[] = "PSXCLOCKNANOSLEEP01";
+static char buffer[512];
+static const T_action actions[] = {
+	T_report_hash_sha256,
+	T_check_task_context,
+	T_check_file_descriptors,
+	T_check_rtems_barriers,
+	T_check_rtems_extensions,
+	T_check_rtems_message_queues,
+	T_check_rtems_partitions,
+	T_check_rtems_periods,
+	T_check_rtems_regions,
+	T_check_rtems_semaphores,
+	T_check_rtems_tasks,
+	T_check_rtems_timers,
+	T_check_posix_keys
+static const T_config config = {
+	.name = "POSIXCLOCKNANOSLEEPTEST01",
+	.buf = buffer,
+	.buf_size = sizeof( buffer ),
+	.putchar = rtems_put_char,
+	.verbosity = T_VERBOSE,
+	.now = T_now_clock,
+	.action_count = T_ARRAY_SIZE( actions ),
+	.actions = actions
+static void
+Init( rtems_task_argument arg )
+	int exit_code;
+	(void) arg;
+	TEST_BEGIN();
+	T_register();
+	exit_code = T_main( &config );
+	if (exit_code == 0) {
+		TEST_END();
+	rtems_test_exit( exit_code );
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
\ No newline at end of file
diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
index 0000000000..803c2cff15
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
@@ -0,0 +1,13 @@
+This file describes the directives and concepts tested by this test set.
+test set name: psxclocknanosleep01
+directives:
+- clock_nanosleep()
+concepts:
+- Test some invalid and extreme timeout values.
+- Ensure that the CLOCK_MONOTONIC based delay is not affected by changes to
+  CLOCK_REALTIME
diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
index 0000000000..aa0050e3cd
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
@@ -0,0 +1,41 @@
+*** BEGIN OF TEST PSXCLOCKNANOSLEEP01 ***
+*** TEST VERSION: 6.0.0.314dae32156aa3d1f54f1ee104b26604a32cae4f
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD:
+*** TEST TOOLS: 10.2.1 20200904 (RTEMS 6, RSB 47f32b8b1a597b5ed3475722bdc155249ef51115, Newlib a0d7982)
+A:POSIXCLOCKNANOSLEEPTEST01
+S:Platform:RTEMS
+S:Compiler:10.2.1 20200904 (RTEMS 6, RSB 47f32b8b1a597b5ed3475722bdc155249ef51115, Newlib a0d7982)
+S:Version:6.0.0.314dae32156aa3d1f54f1ee104b26604a32cae4f
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:0
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:0
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:0
+B:POSIXClock_Timeout_negative_sec_nsec
+P:0:0:UI1:test-clock-nanosleep.c:97
+E:POSIXClock_Timeout_negative_sec_nsec:N:1:F:0:D:0.003693
+P:0:0:UI1:test-clock-nanosleep.c:72
+E:POSIXClock_Timeout_negative_sec:N:1:F:0:D:0.000347
+B:POSIXClock_Timeout_negative_nsec
+P:0:0:UI1:test-clock-nanosleep.c:85
+E:POSIXClock_Timeout_negative_nsec:N:1:F:0:D:0.000227
+B:POSIXClock_Timeout_huge_nsec
+P:0:0:UI1:test-clock-nanosleep.c:60
+E:POSIXClock_Timeout_huge_nsec:N:1:F:0:D:0.000224
+B:POSIXClock_Timeout_finite
+P:0:0:UI1:test-clock-nanosleep.c:43
+P:1:0:UI1:test-clock-nanosleep.c:48
+E:POSIXClock_Timeout_finite:N:2:F:0:D:0.002504
+B:POSIXClock_Timeout_clock_modify
+P:0:0:UI1:test-clock-nanosleep.c:107
+P:1:0:UI1:test-clock-nanosleep.c:111
+P:2:0:UI1:test-clock-nanosleep.c:114
+P:3:0:UI1:test-clock-nanosleep.c:119
+E:POSIXClock_Timeout_clock_modify:N:4:F:0:D:1.009321
+Z:POSIXCLOCKNANOSLEEPTEST01:C:6:N:10:F:0:D:1.018286
+Y:ReportHash:SHA256:cc043d8e8d1a25d2d3a5fb341169ebd8b64e8ba10bc85f34c9905e89c1e01b4f
+*** END OF TEST PSXCLOCKNANOSLEEP01 ***
diff --git a/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c b/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
index 0000000000..d61829c5fe
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/test-clock-nanosleep.c
@@ -0,0 +1,120 @@
+ * are met:
+#endif
+#include <errno.h>
+#include <limits.h>
+#include <time.h>
+T_TEST_CASE( POSIXClock_Timeout_finite )
+  struct timespec delay_time;
+  int eno;
+  eno = clock_gettime( CLOCK_MONOTONIC, &delay_time );
+  T_eno_success( eno );
+  delay_time.tv_sec = 1;
+  eno = clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &delay_time, NULL );
+T_TEST_CASE( POSIXClock_Timeout_huge_nsec )
+  int eno;
+  delay_time.tv_nsec = LONG_MAX;
+  T_eno( EINVAL, eno );
+T_TEST_CASE( POSIXClock_Timeout_negative_sec )
+  int eno;
+  delay_time.tv_sec = -1;
+  delay_time.tv_nsec = 1;
+T_TEST_CASE( POSIXClock_Timeout_negative_nsec )
+  int eno;
+  delay_time.tv_nsec = -1;
+T_TEST_CASE(POSIXClock_Timeout_negative_sec_nsec)
+  int eno;
+  T_eno( EINVAL, eno);
+T_TEST_CASE( POSIXClock_Timeout_clock_modify )
+  struct timespec configure_time;
+  int eno;
+  eno = clock_gettime( CLOCK_REALTIME, &configure_time );
+  configure_time.tv_sec += 3600;
+  eno = clock_settime( CLOCK_REALTIME, &configure_time );
+  delay_time.tv_sec += 1;
2.17.1
