Comments in spec files in rtems.git
Chris Johns
chrisj at rtems.org
Tue Sep 22 01:38:14 UTC 2020
On 21/9/20 12:35 am, Sebastian Huber wrote:
> On 19/09/2020 02:43, Chris Johns wrote:
>> Hi,
>> Can comments be added to the .yml files under specs in rtems.git?
> the problem with comments in YAML files is that they are not preserved if you
> parse the files and write them back.
Could we have a comment block that is a YAML field? Hmm I see a description
field, I wonder if that could serve this purpose. Is that field available in all
files?
>> I was looking over a few files and wonder if some comments would help.
> Could you give an example? Maybe we could add an attribute for this.
I picked this file at random ...
https://git.rtems.org/rtems/tree/spec/build/bsps/optabi.yml
What does it do? It is needed in all BSP build files?
While this file ...
https://git.rtems.org/rtems/tree/spec/build/bsps/tst.yml
... has something which indicates what it is for and I assume I could edit this
and add more detail, for example it is automatically picked up or it needs to be
included in XXX.
Then in a BSP ...
https://git.rtems.org/rtems/tree/spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml
... says nothing about the board, has no links.
There is no way to see the dependencies between all the files unless you build a
mental image ...
and ../../opto2
What does this file do ...
https://git.rtems.org/rtems/tree/spec/build/bsps/powerpc/motorola_powerpc/qemufakerom.yml
