Master broken?
Wed Sep 23 03:19:11 UTC 2020
On 23/9/20 1:14 pm, Chris Johns wrote:
> Hi,
> I cannot build master. I am using ...
... using the autotools build system.
> powerpc-rtems6-gcc (GCC) 10.2.1 20200918
>  (RTEMS 6, RSB 1ea1c9cdc56313e33abf39fce23a2ddf308ff5b3, Newlib 749cbcc)
> for the powerpc, i386 and arm. I am seeing with psim and pc686 ...
> ./../../cpukit/librtemscpu.a(taskcreate.o): in function `rtems_task_create':
> /opt/work/chris/rtems/kernel/rtems.git/c/src/../../cpukit/rtems/src/taskcreate.c:83:
> undefined reference to `_RTEMS_tasks_Create'
> and on the pc686 this is happening ...
> ......./cpukit/librtemscpu.a(rtems-trace-buffer-vars.o): in function
> `rtems_trace_names_size':
> /opt/work/chris/rtems/kernel/rtems.git/c/src/../../cpukit/libmisc/capture/rtems-trace-buffer-vars.c:19:
> undefined reference to `__rtld_trace_names_size'
> I have not bothered to check an arm BSP.
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
