running pc686 samples on QEMU on RTEMS 5.1?
Cudmore, Alan P. (GSFC-5820)
alan.p.cudmore at nasa.gov
Wed Sep 23 21:02:26 UTC 2020
NASA’s Core Flight System open source bundle has support for the RTEMS 4.11 pc686 BSP.
RTEMS is built with the following options:
../rtems/configure --target=i386-rtems4.11 \
--enable-rtemsbsp=pc686 \
--prefix=${HOME}/rtems-4.11 \
--enable-networking \
--enable-cxx \
--disable-posix \
--disable-deprecated \
BSP_ENABLE_VGA=0 \
CLOCK_DRIVER_USE_TSC=1 \
USE_COM1_AS_CONSOLE=1 \
BSP_PRESS_KEY_FOR_RESET=0 \
BSP_RESET_BOARD_AT_EXIT=1
And the code (or samples such as ticker) are run with the following QEMU command:
qemu-system-i386 -m 128 \
-kernel core-cpu1.exe \
-drive file=fat:rw:${INSTALL_DIR}/cpu1,format=raw \
-nographic \
-no-reboot
(Where core-cpu1.exe is the cross compiled application. I can also run ticker.exe and other samples with this command )
When I build the pc686 BSP with the same examples and try running on QEMU with the same options, QEMU returns immediately.
Is there a different set of options I should use for the pc686 BSP on RTEMS 5.1?
Thanks,
Alan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200923/bb52a9a4/attachment.html>
