[PATCH 4/8] score: Improve _CORE_message_queue_Initialize()
Sebastian Huber
Thu Sep 24 12:12:51 UTC 2020
Return a status code and differentiate between error conditions.
Update #4007.
cpukit/include/rtems/score/coremsgimpl.h | 29 ++++++++++++------------
cpukit/include/rtems/score/status.h | 4 ++++
cpukit/posix/src/mqueueopen.c | 17 +++++++-------
cpukit/rtems/src/msgqcreate.c | 17 ++++++++------
cpukit/score/src/coremsg.c | 10 ++++----
testsuites/sptests/sp77/init.c | 2 +-
testsuites/sptests/spmsgq_err01/init.c | 11 +++++----
7 files changed, 50 insertions(+), 40 deletions(-)
diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
index e598dce96a..9403fb95fc 100644
--- a/cpukit/include/rtems/score/coremsgimpl.h
+++ b/cpukit/include/rtems/score/coremsgimpl.h
@@ -71,24 +71,25 @@ typedef int CORE_message_queue_Submit_types;
* @brief Initializes a message queue.
- * This package is the implementation of the CORE Message Queue Handler.
- * This core object provides task synchronization and communication functions
- * via messages passed to queue objects.
+ * @param[out] the_message_queue is the message queue to initialize.
+ * @param discipline is the blocking discipline for the message queue.
+ * @param maximum_pending_messages is the maximum number of messages that will
+ * be allowed to be pending at any given time.
+ * @param maximum_message_size is the size of the largest message that may be
+ * sent to this message queue instance.
- * This routine initializes @a the_message_queue
- * based on the parameters passed.
+ * @retval STATUS_SUCCESSFUL The message queue was initialized.
- * @param[out] the_message_queue The message queue to initialize.
- * @param discipline The blocking discipline for the message queue.
- * @param maximum_pending_messages The maximum number of messages
- * that will be allowed to pend at any given time.
- * @param maximum_message_size The size of the largest message that
- * may be sent to this message queue instance.
+ * @retval STATUS_MESSAGE_QUEUE_INVALID_SIZE Calculations with the maximum
+ * pending messages or maximum message size produced an integer overflow.
- * @retval true The message queue can be initialized.
- * @retval false Memory for the pending messages cannot be allocated.
+ * @retval STATUS_MESSAGE_QUEUE_NO_MEMORY There was not enough memory to
+ * allocate the message buffers.
-bool _CORE_message_queue_Initialize(
+Status_Control _CORE_message_queue_Initialize(
CORE_message_queue_Control *the_message_queue,
CORE_message_queue_Disciplines discipline,
uint32_t maximum_pending_messages,
diff --git a/cpukit/include/rtems/score/status.h b/cpukit/include/rtems/score/status.h
index b257ccc5db..bc374a5467 100644
--- a/cpukit/include/rtems/score/status.h
+++ b/cpukit/include/rtems/score/status.h
@@ -91,6 +91,10 @@ typedef enum {
STATUS_BUILD( STATUS_CLASSIC_INTERNAL_ERROR, EOVERFLOW ),
STATUS_MESSAGE_INVALID_SIZE =
STATUS_BUILD( STATUS_CLASSIC_INVALID_SIZE, EMSGSIZE ),
+ STATUS_MESSAGE_QUEUE_INVALID_SIZE =
+ STATUS_BUILD( STATUS_CLASSIC_INVALID_SIZE, ENOSPC ),
+ STATUS_MESSAGE_QUEUE_NO_MEMORY =
+ STATUS_BUILD( STATUS_CLASSIC_UNSATISFIED, ENOSPC ),
STATUS_MESSAGE_QUEUE_WAIT_IN_ISR =
STATUS_BUILD( STATUS_CLASSIC_INTERNAL_ERROR, EAGAIN ),
STATUS_MESSAGE_QUEUE_WAS_DELETED =
diff --git a/cpukit/posix/src/mqueueopen.c b/cpukit/posix/src/mqueueopen.c
index 35b8c923b1..af8abebea8 100644
--- a/cpukit/posix/src/mqueueopen.c
+++ b/cpukit/posix/src/mqueueopen.c
@@ -60,6 +60,7 @@ static mqd_t _POSIX_Message_queue_Create(
POSIX_Message_queue_Control *the_mq;
char *name;
+ Status_Control status;
/* length of name has already been validated */
@@ -97,14 +98,14 @@ static mqd_t _POSIX_Message_queue_Create(
* Joel: Cite POSIX or OpenGroup on above statement so we can determine
* if it is a real requirement.
- if (
- !_CORE_message_queue_Initialize(
- &the_mq->Message_queue,
- CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO,
- attr->mq_maxmsg,
- attr->mq_msgsize
+ status = _CORE_message_queue_Initialize(
+ &the_mq->Message_queue,
+ CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO,
+ attr->mq_maxmsg,
+ attr->mq_msgsize
+ if ( status != STATUS_SUCCESSFUL ) {
_POSIX_Message_queue_Free( the_mq );
_Workspace_Free( name );
rtems_set_errno_and_return_value( ENOSPC, MQ_OPEN_FAILED );
diff --git a/cpukit/rtems/src/msgqcreate.c b/cpukit/rtems/src/msgqcreate.c
index 3741347cc9..79b198199e 100644
--- a/cpukit/rtems/src/msgqcreate.c
+++ b/cpukit/rtems/src/msgqcreate.c
@@ -41,6 +41,7 @@ rtems_status_code rtems_message_queue_create(
Message_queue_Control *the_message_queue;
CORE_message_queue_Disciplines discipline;
#if defined(RTEMS_MULTIPROCESSING)
bool is_global;
#endif
@@ -107,12 +108,14 @@ rtems_status_code rtems_message_queue_create(
else
discipline = CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO;
- if ( ! _CORE_message_queue_Initialize(
- &the_message_queue->message_queue,
- discipline,
- count,
- max_message_size
+ &the_message_queue->message_queue,
+ discipline,
+ count,
+ max_message_size
if ( is_global )
_Objects_MP_Close(
@@ -121,7 +124,7 @@ rtems_status_code rtems_message_queue_create(
_Message_queue_Free( the_message_queue );
_Objects_Allocator_unlock();
- return RTEMS_UNSATISFIED;
+ return STATUS_GET_CLASSIC( status );
_Objects_Open(
diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
index 57882f6426..450470396c 100644
--- a/cpukit/score/src/coremsg.c
+++ b/cpukit/score/src/coremsg.c
@@ -26,7 +26,7 @@
( SIZE_MAX - sizeof( uintptr_t ) - 1 \
- sizeof( CORE_message_queue_Buffer_control ) )
@@ -37,7 +37,7 @@ bool _CORE_message_queue_Initialize(
/* Make sure the message size computation does not overflow */
if ( maximum_message_size > MESSAGE_SIZE_LIMIT ) {
- return false;
+ return STATUS_MESSAGE_QUEUE_INVALID_SIZE;
buffer_size = RTEMS_ALIGN_UP( maximum_message_size, sizeof( uintptr_t ) );
@@ -48,7 +48,7 @@ bool _CORE_message_queue_Initialize(
/* Make sure the memory allocation size computation does not overflow */
if ( maximum_pending_messages > SIZE_MAX / buffer_size ) {
- return false;
the_message_queue->message_buffers = _Workspace_Allocate(
@@ -56,7 +56,7 @@ bool _CORE_message_queue_Initialize(
if ( the_message_queue->message_buffers == NULL ) {
- return false;
+ return STATUS_MESSAGE_QUEUE_NO_MEMORY;
the_message_queue->maximum_pending_messages = maximum_pending_messages;
@@ -80,5 +80,5 @@ bool _CORE_message_queue_Initialize(
buffer_size
- return true;
+ return STATUS_SUCCESSFUL;
diff --git a/testsuites/sptests/sp77/init.c b/testsuites/sptests/sp77/init.c
index 2c4a71a73c..ada13643fa 100644
--- a/testsuites/sptests/sp77/init.c
+++ b/testsuites/sptests/sp77/init.c
@@ -32,7 +32,7 @@ rtems_task Init(
&id
- fatal_directive_check_status_only(status , RTEMS_UNSATISFIED ,
+ fatal_directive_check_status_only(status , RTEMS_INVALID_SIZE ,
"attempt to create message queue return: ");
TEST_END();
diff --git a/testsuites/sptests/spmsgq_err01/init.c b/testsuites/sptests/spmsgq_err01/init.c
index 1ff8490d1a..854377038e 100644
--- a/testsuites/sptests/spmsgq_err01/init.c
+++ b/testsuites/sptests/spmsgq_err01/init.c
@@ -101,8 +101,9 @@ rtems_task Init(
/* not enough memory for messages */
status = rtems_message_queue_create(
Queue_name[ 1 ],
- INT_MAX,
- MESSAGE_SIZE,
+ SIZE_MAX
+ / ( sizeof( uintptr_t ) + sizeof( CORE_message_queue_Buffer_control ) ),
+ 1,
RTEMS_DEFAULT_ATTRIBUTES,
&Queue_id[ 1 ]
@@ -123,10 +124,10 @@ rtems_task Init(
fatal_directive_status(
status,
- RTEMS_UNSATISFIED,
- "rtems_message_queue_create unsatisfied"
+ RTEMS_INVALID_SIZE,
+ "rtems_message_queue_create invalid size"
- puts( "TA1 - rtems_message_queue_create - Q 2 - RTEMS_UNSATISFIED #2" );
+ puts( "TA1 - rtems_message_queue_create - Q 2 - RTEMS_INVALID_SIZE" );
Queue_name[ 1 ],
2.26.2
