[PATCH 2/8] score: Fix allocation size calculation
Thu Sep 24 16:30:43 UTC 2020
On Thu, Sep 24, 2020 at 6:13 AM Sebastian Huber
> The previous multiplication error check is broken on 64-bit machines.  Use the
> recommended check from SEI CERT C Coding Standard, "INT30-C. Ensure that
> unsigned integer operations do not wrap".
> Make sure the message size computation does not overflow.
> Update #4007.
>  cpukit/score/src/coremsg.c | 74 ++++++++++++--------------------------
>  1 file changed, 23 insertions(+), 51 deletions(-)
> diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
> index af8dbd6583..137d9973f4 100644
> --- a/cpukit/score/src/coremsg.c
> +++ b/cpukit/score/src/coremsg.c
> @@ -19,28 +19,12 @@
>  #endif
>  #include <rtems/score/coremsgimpl.h>
> +#include <rtems/score/assert.h>
>  #include <rtems/score/wkspace.h>
> - *  size_t_mult32_with_overflow
> - *  This method multiplies two size_t 32-bit numbers and checks
> - *  for overflow.  It returns false if an overflow occurred and
> - *  the result is bad.
> -static inline bool size_t_mult32_with_overflow(
> -  size_t  a,
> -  size_t  b,
> -  size_t *c
> -  long long x = (long long)a*b;
> -  if ( x > SIZE_MAX )
> -    return false;
> -  *c = (size_t) x;
> -  return true;
> +#define MESSAGE_SIZE_LIMIT \
> +  ( SIZE_MAX - sizeof( uintptr_t ) - 1 \
Minor: should it be - ( sizeof( uintptr_t ) - 1 )?
Or: - sizeof(uintptr_t) + 1
The alignment up can add at most sizeof(uintptr_t)-1 bytes overhead I
think is what this is trying to capture?
> +    - sizeof( CORE_message_queue_Buffer_control ) )
>  bool _CORE_message_queue_Initialize(
>    CORE_message_queue_Control     *the_message_queue,
> @@ -49,48 +33,36 @@ bool _CORE_message_queue_Initialize(
>    size_t                          maximum_message_size
> -  size_t message_buffering_required = 0;
> -  size_t aligned_message_size;
> +  size_t buffer_size;
>    the_message_queue->maximum_pending_messages   = maximum_pending_messages;
>    the_message_queue->number_of_pending_messages = 0;
>    the_message_queue->maximum_message_size       = maximum_message_size;
>    _CORE_message_queue_Set_notify( the_message_queue, NULL );
> -   * Align up the maximum message size to be an integral multiple of the
> -   * pointer size.
> -  aligned_message_size = RTEMS_ALIGN_UP(
> -    maximum_message_size,
> -   * Check for an integer overflow.  It can occur while aligning up the maximum
> -   * message size.
> -  if (aligned_message_size < maximum_message_size)
> +  /* Make sure the message size computation does not overflow */
> +  if ( maximum_message_size > MESSAGE_SIZE_LIMIT ) {
>      return false;
> -   *  Calculate how much total memory is required for message buffering and
> -   *  check for overflow on the multiplication.
> -  if ( !size_t_mult32_with_overflow(
> -        (size_t) maximum_pending_messages,
> -        aligned_message_size + sizeof(CORE_message_queue_Buffer_control),
> -        &message_buffering_required ) )
> +  buffer_size = RTEMS_ALIGN_UP( maximum_message_size, sizeof( uintptr_t ) );
> +  _Assert( buffer_size >= maximum_message_size );
> +  buffer_size += sizeof( CORE_message_queue_Buffer_control );
> +  _Assert( buffer_size >= sizeof( CORE_message_queue_Buffer_control ) );
> +  /* Make sure the memory allocation size computation does not overflow */
> +  if ( maximum_pending_messages > SIZE_MAX / buffer_size ) {
optimization: can we use mult instead?
  if ( maximum_pending_messages * buffer_size > SIZE_MAX )
save a few cycles...
>      return false;
> -   *  Attempt to allocate the message memory
> -  the_message_queue->message_buffers = (CORE_message_queue_Buffer *)
> -     _Workspace_Allocate( message_buffering_required );
> +  the_message_queue->message_buffers = _Workspace_Allocate(
> +    (size_t) maximum_pending_messages * buffer_size
... and the compiler should propagate that value to here to save even
more cycles. Or it could be put in a variable for simpler code.
> -  if (the_message_queue->message_buffers == 0)
> +  if ( the_message_queue->message_buffers == NULL ) {
>      return false;
>     *  Initialize the pool of inactive messages, pending messages,
> @@ -100,7 +72,7 @@ bool _CORE_message_queue_Initialize(
>      &the_message_queue->Inactive_messages,
>      the_message_queue->message_buffers,
> -    aligned_message_size + sizeof( CORE_message_queue_Buffer_control )
> +    buffer_size
>    _Chain_Initialize_empty( &the_message_queue->Pending_messages );
> 2.26.2
> devel mailing list
> devel at rtems.org
