[PATCH 7/8] rtems: Remove Message_queue_Control::attribute_set
Thu Sep 24 16:45:57 UTC 2020
There should be an mptest added for global mq
On Thu, Sep 24, 2020 at 6:13 AM Sebastian Huber
> Add Message_queue_Control::is_global if RTEMS_MULTIPROCESSING is defined.  This
> reduces the Message_queue_Control size in standard RTEMS configurations.
> Update #4007.
>  cpukit/include/rtems/rtems/messagedata.h |  6 ++++--
>  cpukit/libmisc/monitor/mon-queue.c       | 16 +++++++++++++++-
>  cpukit/rtems/src/msgqcreate.c            | 12 ++++++------
>  cpukit/rtems/src/msgqdelete.c            |  2 +-
>  4 files changed, 26 insertions(+), 10 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/messagedata.h b/cpukit/include/rtems/rtems/messagedata.h
> index fa1f681473..8c72fba078 100644
> --- a/cpukit/include/rtems/rtems/messagedata.h
> +++ b/cpukit/include/rtems/rtems/messagedata.h
> @@ -40,8 +40,10 @@ typedef struct {
>    Objects_Control             Object;
>    /** This field is the instance of the SuperCore Message Queue. */
>    CORE_message_queue_Control  message_queue;
> -  /** This field is the attribute set as defined by the API. */
> -  rtems_attribute             attribute_set;
> +#if defined(RTEMS_MULTIPROCESSING)
> +  /** This field is true if the message queue is offered globally */
> +  bool                        is_global;
> +#endif
>  }   Message_queue_Control;
> diff --git a/cpukit/libmisc/monitor/mon-queue.c b/cpukit/libmisc/monitor/mon-queue.c
> index 9430797c6c..aadfcd3989 100644
> --- a/cpukit/libmisc/monitor/mon-queue.c
> +++ b/cpukit/libmisc/monitor/mon-queue.c
> @@ -16,7 +16,21 @@ rtems_monitor_queue_canonical(
>      const Message_queue_Control *rtems_queue = (const Message_queue_Control *) queue_void;
> -    canonical_queue->attributes = rtems_queue->attribute_set;
> +    canonical_queue->attributes = 0;
> +    if (
> +      rtems_queue->message_queue.operations
> +        == &_Thread_queue_Operations_priority
> +      canonical_queue->attributes |= RTEMS_PRIORITY;
> +    if ( rtems_queue->is_global ) {
> +      canonical_queue->attributes |= RTEMS_GLOBAL;
> +#endif
>      canonical_queue->maximum_message_size = rtems_queue->message_queue.maximum_message_size;
>      canonical_queue->maximum_pending_messages = rtems_queue->message_queue.maximum_pending_messages;
>      canonical_queue->number_of_pending_messages = rtems_queue->message_queue.number_of_pending_messages;
> diff --git a/cpukit/rtems/src/msgqcreate.c b/cpukit/rtems/src/msgqcreate.c
> index 79b198199e..20787f00a6 100644
> --- a/cpukit/rtems/src/msgqcreate.c
> +++ b/cpukit/rtems/src/msgqcreate.c
> @@ -53,11 +53,11 @@ rtems_status_code rtems_message_queue_create(
>      return RTEMS_INVALID_ADDRESS;
> -  if ( !_System_state_Is_multiprocessing ) {
> -    attribute_set = _Attributes_Clear( attribute_set, RTEMS_GLOBAL );
> +  if ( _System_state_Is_multiprocessing ) {
> +    is_global = _Attributes_Is_global( attribute_set );
> +  } else {
> +    is_global = false;
> -  is_global = _Attributes_Is_global( attribute_set );
>  #endif
>    if ( count == 0 )
> @@ -99,9 +99,9 @@ rtems_status_code rtems_message_queue_create(
>      _Objects_Allocator_unlock();
>      return RTEMS_TOO_MANY;
> -#endif
> -  the_message_queue->attribute_set = attribute_set;
> +  the_message_queue->is_global = is_global;
> +#endif
>    if (_Attributes_Is_priority( attribute_set ) )
>      discipline = CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY;
> diff --git a/cpukit/rtems/src/msgqdelete.c b/cpukit/rtems/src/msgqdelete.c
> index 791f96e676..e1d57addc9 100644
> --- a/cpukit/rtems/src/msgqdelete.c
> +++ b/cpukit/rtems/src/msgqdelete.c
> @@ -60,7 +60,7 @@ rtems_status_code rtems_message_queue_delete(
> -  if ( _Attributes_Is_global( the_message_queue->attribute_set ) ) {
> +  if ( the_message_queue->is_global ) {
>      _Objects_MP_Close(
>        &_Message_queue_Information,
>        the_message_queue->Object.id
> 2.26.2
> devel mailing list
> devel at rtems.org
