[PATCH] user: Add migration hints from old build system
Sebastian Huber
Fri Sep 25 05:43:39 UTC 2020
Update #3818.
user/bld/index.rst | 84 ++++++++++++++++++++++++++++++++++++++++++++--
1 file changed, 82 insertions(+), 2 deletions(-)
diff --git a/user/bld/index.rst b/user/bld/index.rst
index b47cee8..376475c 100644
--- a/user/bld/index.rst
+++ b/user/bld/index.rst
@@ -1,7 +1,7 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2019 embedded brains GmbH
-.. Copyright (C) 2019 Sebastian Huber
+.. Copyright (C) 2019, 2020 embedded brains GmbH
+.. Copyright (C) 2019, 2020 Sebastian Huber
.. index:: BSP build system
.. index:: build system
@@ -283,3 +283,83 @@ example configuration file, building of the tests is enabled for the
[sparc/erc32]
[riscv/griscv]
+Migration from Autoconf/Automake
+The Autoconf/Automake based build system used a ``configure`` command to
+configure a single BSP and ``make`` to build it. The ``configure`` command is
+replaced by a ``./waf configure`` invocation with configuration file. The
+``make`` command is replaced by ``./waf`` and ``make install`` is replaced by
+``./waf install``.
+Here are some hints how a configure command line can be converted to options in
+the configuration file of the ``waf`` based build system. BSP options given at
+the configure command line have to be added to the BSP section in the
+configuration file.
+``--target=${arch}-rtems6`` ``--enable-rtembsp=${bsp}``
+ To build a BSP add ``[${arch}/${bsp}]`` to the configuration file.
+``--enable-ada`` | ``--disable-ada``
+ Set ``__RTEMS_ADA__`` to ``True`` or ``False`` in the BSP section of
+ the configuration file.
+``--enable-multiprocessing`` | ``--disable-multiprocessing``
+ Set ``RTEMS_MULTIPROCESSING`` to ``True`` or ``False`` in the BSP
+ section of the configuration file.
+``--enable-networking`` | ``--disable-networking``
+ Set ``RTEMS_NETWORKING`` to ``True`` or ``False`` in the BSP section of
+``--enable-posix`` | ``--disable-posix``
+ Set ``RTEMS_POSIX_API`` to ``True`` or ``False`` in the BSP section of
+``--enable-rtems-debug`` | ``--disable-rtems-debug``
+ Set ``RTEMS_DEBUG`` to ``True`` or ``False`` in the BSP section of the
+ configuration file.
+``--enable-smp`` | ``--disable-smp``
+ Set ``RTEMS_SMP`` to ``True`` or ``False`` in the BSP section of the
+``--enable-tests`` | ``--disable-tests``
+ Set ``BUILD_TESTS`` to ``True`` or ``False`` in the BSP section of the
+``--enable-tests=samples``
+ Set ``BUILD_SAMPLES`` to ``True`` or ``False`` in the BSP section of
+Please have a look at the following example configuration file.
+.. code-block:: ini
+ # --target=sparc-rtems6 --enable-rtemsbsp=erc32
+ [sparc/erc32]
+ # --enable-ada
+ __RTEMS_ADA__ = True
+ # --enable-multiprocessing
+ RTEMS_MULTIPROCESSING = False
+ # --enable-networking
+ RTEMS_NETWORKING = True
+ # --disable-posix
+ RTEMS_POSIX_API = False
+ # --enable-rtems-debug
+ RTEMS_DEBUG = True
+ # --disable-smp
+ RTEMS_SMP = False
+ # --enable-tests
+ BUILD_TESTS = True
+ # BSP_POWER_DOWN_AT_FATAL_HALT=
+ BSP_POWER_DOWN_AT_FATAL_HALT = False
2.26.2
