[PATCH v2 2/9] score: Fix allocation size calculation
Sebastian Huber
Fri Sep 25 09:51:25 UTC 2020
The previous multiplication error check is broken on 64-bit machines. Use the
recommended check from SEI CERT C Coding Standard, "INT30-C. Ensure that
unsigned integer operations do not wrap".
Make sure the message size computation does not overflow.
Update #4007.
cpukit/score/src/coremsg.c | 74 ++++++++++++--------------------------
1 file changed, 23 insertions(+), 51 deletions(-)
diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
index af8dbd6583..04c1799c69 100644
--- a/cpukit/score/src/coremsg.c
+++ b/cpukit/score/src/coremsg.c
@@ -19,28 +19,12 @@
#endif
+#include <rtems/score/assert.h>
- * size_t_mult32_with_overflow
- * This method multiplies two size_t 32-bit numbers and checks
- * for overflow. It returns false if an overflow occurred and
- * the result is bad.
-static inline bool size_t_mult32_with_overflow(
- size_t a,
- size_t b,
- size_t *c
- long long x = (long long)a*b;
- if ( x > SIZE_MAX )
- return false;
- *c = (size_t) x;
- return true;
+#define MESSAGE_SIZE_LIMIT \
+ ( SIZE_MAX - sizeof( uintptr_t ) + 1 \
+ - sizeof( CORE_message_queue_Buffer_control ) )
bool _CORE_message_queue_Initialize(
CORE_message_queue_Control *the_message_queue,
@@ -49,48 +33,36 @@ bool _CORE_message_queue_Initialize(
size_t maximum_message_size
- size_t message_buffering_required = 0;
- size_t aligned_message_size;
+ size_t buffer_size;
the_message_queue->maximum_pending_messages = maximum_pending_messages;
the_message_queue->number_of_pending_messages = 0;
the_message_queue->maximum_message_size = maximum_message_size;
_CORE_message_queue_Set_notify( the_message_queue, NULL );
- * Align up the maximum message size to be an integral multiple of the
- * pointer size.
- aligned_message_size = RTEMS_ALIGN_UP(
- maximum_message_size,
- * Check for an integer overflow. It can occur while aligning up the maximum
- * message size.
- if (aligned_message_size < maximum_message_size)
+ /* Make sure the message size computation does not overflow */
+ if ( maximum_message_size > MESSAGE_SIZE_LIMIT ) {
return false;
- * Calculate how much total memory is required for message buffering and
- * check for overflow on the multiplication.
- if ( !size_t_mult32_with_overflow(
- (size_t) maximum_pending_messages,
- aligned_message_size + sizeof(CORE_message_queue_Buffer_control),
- &message_buffering_required ) )
+ buffer_size = RTEMS_ALIGN_UP( maximum_message_size, sizeof( uintptr_t ) );
+ _Assert( buffer_size >= maximum_message_size );
+ buffer_size += sizeof( CORE_message_queue_Buffer_control );
+ _Assert( buffer_size >= sizeof( CORE_message_queue_Buffer_control ) );
+ /* Make sure the memory allocation size computation does not overflow */
+ if ( maximum_pending_messages > SIZE_MAX / buffer_size ) {
return false;
- * Attempt to allocate the message memory
- the_message_queue->message_buffers = (CORE_message_queue_Buffer *)
- _Workspace_Allocate( message_buffering_required );
+ the_message_queue->message_buffers = _Workspace_Allocate(
+ (size_t) maximum_pending_messages * buffer_size
- if (the_message_queue->message_buffers == 0)
+ if ( the_message_queue->message_buffers == NULL ) {
return false;
* Initialize the pool of inactive messages, pending messages,
@@ -100,7 +72,7 @@ bool _CORE_message_queue_Initialize(
&the_message_queue->Inactive_messages,
the_message_queue->message_buffers,
- aligned_message_size + sizeof( CORE_message_queue_Buffer_control )
+ buffer_size
_Chain_Initialize_empty( &the_message_queue->Pending_messages );
2.26.2
