BSP_CONSOLE_MINOR option for Zynq board with new build system
Sebastian Huber
Fri Sep 25 14:13:40 UTC 2020
Hello Jan,
On 25/09/2020 15:36, Jan.Sommer at dlr.de wrote:
> Hello,
> I am currently making my first steps with the new build system and so far it is amazing.
> Especially, the inheritance option is very handy for maintaining different configurations.
> Therefore, a big thank you to Sebastian and everyone else involved.
thanks for having a look at it.
> I ran into a smaller problem when compiling for a zynq-board.
> I tried to override BSP_CONSOLE_MINOR=0, but it seems that the option is interpreted as a Boolean and then the define not set.
> At least I run into:
> ../../../bsps/arm/xilinx-zynq/start/bspreset.c: In function 'bsp_reset':
> ../../../bsps/arm/xilinx-zynq/start/bspreset.c:37:49: error: 'BSP_CONSOLE_MINOR' undeclared (first use in this function)
> 37 | zynq_uart_reset_tx_flush(&zynq_uart_instances[BSP_CONSOLE_MINOR]);
Yes, this could be a potential problem in several BSPs. I used a script
to convert the BSP options, but to detect if it was an integer or
boolean type was just an heuristic. In order to fix this, you first have
to find the build specification item of the option:
spec/build/bsps/arm/xilinx-zynqmp/optconminor.yml:name: BSP_CONSOLE_MINOR
spec/build/bsps/arm/xilinx-zynq/optconminor.yml:name: BSP_CONSOLE_MINOR
So, we have this option duplicated. This is an issue on its own. At some
point in time we should unify the options across the BSPs.
Then open the file (spec/build/bsps/arm/xilinx-zynq/optconminor.yml):
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
actions:
- get-boolean: null
- define-condition: null
build-type: option
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
default: true
default-by-variant: []
description: |
minor number of console device
enabled-by: true
links: []
type: build
Under actions you see what is done with the value specified by the
configuration file (or the default value). See also:
https://docs.rtems.org/branches/master/eng/req/items.html#spectypebuildoptionaction
This patch fixes probably the issue:
diff --git a/spec/build/bsps/arm/xilinx-zynq/optconminor.yml
b/spec/build/bsps/arm/xilinx-zynq/optconminor.yml
index 55074c6dac..486eb92d33 100644
--- a/spec/build/bsps/arm/xilinx-zynq/optconminor.yml
+++ b/spec/build/bsps/arm/xilinx-zynq/optconminor.yml
@@ -1,15 +1,16 @@
actions:
-- get-boolean: null
-- define-condition: null
+- get-integer: null
+- define: null
build-type: option
copyrights:
-default: true
+default: 1
description: |
enabled-by: true
+format: '{}'
links: []
type: build
The integer options need a "format" attribute.
