[PATCH 7/8] rtems: Remove Message_queue_Control::attribute_set
Sebastian Huber
Fri Sep 25 15:02:49 UTC 2020
On 25/09/2020 17:00, Gedare Bloom wrote:
> On Thu, Sep 24, 2020 at 10:35 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 24/09/2020 18:45, Gedare Bloom wrote:
>>> There should be an mptest added for global mq
>> This should be already covered by tests mp09 .. mp13.
> I wasn't clear. Should we test global mq with this 'construct' feature also?
Ok, I will change one of the mptests to use construct instead of create.
