[PATCH] user: Add migration hints from old build system
Fri Sep 25 15:17:44 UTC 2020
On 25/09/2020 17:12, Gedare Bloom wrote:
>> +Migration from Autoconf/Automake
>> +The Autoconf/Automake based build system used a ``configure`` command to
>> +configure a single BSP and ``make`` to build it.  The ``configure`` command is
> You can make multiple BSPs, so it is a little bit imprecise. Maybe:
> "configure a single target architecture and one or more BSPs" and ``make`` ...
Ok, but I am not sure if it was an intentional feature that you could
build more than one BSP.
