[PATCH v1 5/8] bsps/shared: Add PSCI-based bspreset implementation
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Sep 25 15:27:29 UTC 2020
This adds a bsp_reset implementation based on the ARM PSCI
specification often present in ARMv8 systems.
bsps/shared/start/bspreset-psci.c | 48 +++++++++++++++++++++++++++++++
1 file changed, 48 insertions(+)
create mode 100644 bsps/shared/start/bspreset-psci.c
diff --git a/bsps/shared/start/bspreset-psci.c b/bsps/shared/start/bspreset-psci.c
new file mode 100644
index 0000000000..33dd38e814
--- /dev/null
+++ b/bsps/shared/start/bspreset-psci.c
@@ -0,0 +1,48 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <bsp.h>
+#include <bsp/bootcard.h>
+void bsp_reset(void)
+ uint32_t PSCI_FN_SYSTEM_RESET = 0x84000009;
+ __asm__ volatile(
+#if defined(AARCH64_MULTILIB_ARCH_V8) || defined(AARCH64_MULTILIB_ARCH_V8_ILP32)
+ "mov x0, %0\n"
+#else
+ "mov r0, %0\n"
+#endif
+#ifdef BSP_RESET_SMC
+ "smc #0\n"
+#else
+ "hvc #0\n"
+#endif
+ : : "r" (PSCI_FN_SYSTEM_RESET)
2.20.1
