configure options translated to waf config.ini?
Fri Sep 25 18:49:31 UTC 2020
On Thu, Sep 24, 2020 at 1:33 PM Chris Johns <chrisj at rtems.org> wrote:
> On 25/9/20 2:48 am, Joel Sherrill wrote:
> > I can't find any documentation which guides translating a
> > RTEMS configure command into the appropriate set of
> > options in a config.ini file for waf. The only example I could
> > find has BUILD_TESTS which implies it builds all tests
> > rather than just samples.
> > Guidance on translating configure options to config.ini
> > statements would be appreciated by me and I am sure
> > by others who will have to update their build procedures.
> > Guidance on the variables used to override configure.ac <http://configure.ac>
> > values is also needed but that isn't quite as critical as
> > just translating the various enable/disable settings.
> I have not done this yet so I do not have a 1:1 translation for configure
> options. Having this documented would be good.
> I discussed with Sebastian earlier in the week how this is to work and this is
> what I learnt ...
> 1. The `--rtems-bsps` option only seems to effect the `bsp_defaults` target. The
> configure process uses the .ini file you provide via the `--rtems-config`
> option. The default is `config.ini` if that option is not supplied.
> 2. The .ini file is only referenced by the configure phase of waf. It defines
> all the BSPs to built and any overriding option. You normally only have options
> in a .ini that are _not_ defaults. If you enter:
> ./waf bsp_defaults > config.ini
> all BSPs will be built and with default options. This is not what you normally want.
> 3. You can have a `[DEFAULTS]` (all caps) section and any option in that section
> applies to all BSP that support it. For example:
> [DEFAULTS]
No 'S'
> BUILD_TESTS = True
> will build the testsuite for all defined BSPs.
> 4. To build a BSP using its defaults simply add the BSP name as a section
> header. Note, BSP names use the RTEMS standard `arch/bsp` format. For example:
> [DEFAULT]
Like this
> BUILD_TESTS = True
> [arm/beagleboneblack]
> [arm/xilinx_zynq_a9_qemu]
> [i386/pc686]
> [sparc/erc32]
> Will build 4 BSPs with tests.
> 5. To change a default option you first need to see what is supported for your
> BSP. Currently the only option available is with ./waf and the `bsp_defaults`
> target with the BSP name of interest. For example:
> $ ./waf bsp_defaults --rtems-bsp=sparc/erc32
> Examine the list and add the one you want to change to your .ini file. For
> example to change the optimisation level:
> [sparc/erc32]
> OPTIMIZATION_FLAGS = -O -g -fdata-sections -ffunction-sections
> Remember to run the waf configure command again so the build picks up the
> changed option. In the case waf will see the compiler command has changed and it
> will rebuild all effected object files.
> 6. The .ini can be located any where. It does not need to reside in the source
> tree. The `--rtems-config` option can be used to point to any you have located
> outside the source tree. You can keep them in a separate repo or tool you
> maintain to build RTEMS.
> Chris
> devel mailing list
> devel at rtems.org
