Removed 'unicode' keyword from pkgconfig.py
Stephen Clark
stephen.clark at oarcorp.com
Fri Sep 25 22:13:29 UTC 2020
I have attached a patch to remove the use of the 'unicode' keyword from the pkgconfig.py file.
This addresses #4094, where this same patch has been attached.
I was able to run the sb-set-builder script on the master, so I don't believe this problem exists on that branch.
Thanks,
Stephen Clark
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200925/3699b44a/attachment.html>
Desc: 0001-pkgconfig.py-Removed-use-of-unicode-keyword-for-pyth.patch
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200925/3699b44a/attachment.obj>
