qoriq_e6500_32 with smp - compiler error
Gedare Bloom
gedare at rtems.org
Sat Sep 26 19:51:48 UTC 2020
[DEFAULT]
BUILD_TESTS = True
[sparc/erc32]
[sparc64/usiii]
[powerpc/qoriq_e6500_32]
[powerpc/qoriq_e6500_32_smp]
INHERIT = qoriq_e6500_32
RTEMS_SMP = True
[powerpc/qoriq_e6500_64]
[powerpc/qoriq_e6500_64_smp]
INHERIT = qoriq_e6500_64
RTEMS_SMP = True
It breaks before I get to the _64 ones though.
On Sat, Sep 26, 2020 at 1:55 AM Sebastian Huber
> On 25/09/2020 21:35, Gedare Bloom wrote:
> > When I build the qoriq_e6500_32 with SMP enabled in the new build
> > system, I hit this error:
> > [ 77/4070] Compiling bsps/powerpc/shared/cache/cache.c
> > In file included from ../../../bsps/powerpc/shared/cache/cache.c:319:
> > ../../../bsps/powerpc/include/../../../bsps/shared/cache/cacheimpl.h:92:2:
> > error: #error "CPU_DATA_CACHE_ALIGNMENT (" ## CPU_DATA_CACHE_ALIGNMENT
> > ## ") is greater than CPU_CACHE_LINE_BYTES (" ## CPU_CACHE_LINE_BYTES
> > 92 | #error "CPU_DATA_CACHE_ALIGNMENT (" ##
> > CPU_DATA_CACHE_ALIGNMENT ## ") is greater than CPU_CACHE_LINE_BYTES ("
> > ## CPU_CACHE_LINE_BYTES ## ")"
> > ../../../bsps/powerpc/include/../../../bsps/shared/cache/cacheimpl.h:96:2:
> > error: #error "CPU_INSTRUCTION_CACHE_ALIGNMENT is greater than
> > CPU_CACHE_LINE_BYTES"
> > 96 | #error "CPU_INSTRUCTION_CACHE_ALIGNMENT is greater than
> > I haven't been able to dig into it. The autotools build doesn't hit
> > the same problem.
> I cannot reproduce this issue, what is your configuration file?
