[PATCH] user: Add migration hints from old build system
Sebastian Huber
Sun Sep 27 07:46:40 UTC 2020
On 26/09/2020 17:50, Joel Sherrill wrote:
> Why the __ around RTEMS_ADA and no other option?
There is a one to one correspondence between the BSP option name and the
define in <rtems/score/cpuopts.h>.
> I think the first order of business is to explain how to translate
> existing configure and build steps to the new one. I think adding a
> simple example with a couple of enable/disable and the corresponding
> waf would help. Every user has to face this.
> Then explaining multiple bsps but I don't know how common that is in
> actual use.
> Let's focus on getting folks across the transition hurdle first.
I think this is all covered by:
https://docs.rtems.org/branches/master/user/bld/index.html
