[PATCH] shell: Fixing bug in line editing of the shell with CTRL-U.
Frank Kühndel frank.kuehndel at embedded-brains.de
Mon Sep 28 14:17:32 UTC 2020
Hello,
we fixed the minor issues in the patch, created two tickets (#4096 for
milestone 5 and #4097 for 6) and Sebastian Huber added the fix to the
git sources.
Many thank to all reviewers for their helpful comments.
Greetings,
Frank
On 9/27/20 9:26 AM, Chris Johns wrote:
> On 26/9/20 2:06 am, Joel Sherrill wrote:
>> On Fri, Sep 25, 2020, 10:06 AM Gedare Bloom <gedare at rtems.org
>> <mailto:gedare at rtems.org>> wrote:
>>     On Fri, Sep 25, 2020 at 3:11 AM Frank Kuehndel
>>     <frank.kuehndel at embedded-brains.de
>>     <mailto:frank.kuehndel at embedded-brains.de>> wrote:
>>     > This patch fixes a tiny bug in the command line editing of the RTEMS
>>     shell. Typing CTRL-U in the shell should remove all characters left of the
>>     cursor. After pressing CTRL-U, the current implementation does wrongly place
>>     the cursor at the end of the line instead at its beginning.
>>     > To reproduce the bug, start the shell and type 'abc123' (no <RETURN>):
>>     > > ~/src/rtems $ qemu-system-arm -net none -nographic -M realview-pbx-a9 -m
>>     256M -kernel build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl10.exe
>>     > > *** BEGIN OF TEST libdl (RTL) 10 ***
>>     > > *** TEST VERSION: 6.0.0.d9bdf166644f612dd628fe4951c12c6f8e94ba5f
>>     > > *** TEST STATE: USER_INPUT
>>     > > *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
>>     > > *** TEST TOOLS: 10.2.1 20200904 (RTEMS 6, RSB
>>     31f936a7b74d60bda609a9960c6e1a705ba54974, Newlib a0d7982)
>>     > > RTL (libdl) commands: dl, rtl
>>     > > RTEMS Shell on /dev/foobar. Use 'help' to list commands.
>>     > > SHLL [/] # abc123
>>     > Then move the cursor onto the '1' by hitting three times the <ARROW-LEFT>
>>     key. Next type <CTRL>-U:
>>     > > SHLL [/] # 123
>>     > Note that the cursor is at the end of the line (after '3') instead of
>>     correctly at the beginning (on the '1'), now.
>>     > Continuing typing 'echo ' incorrectly results in the output:
>>     > > SHLL [/] # 123echo 123
>>     > The patch changes this behavior so that the cursor in the second last step
>>     will be on the '1' and typing 'echo ' will then correctly reflected as:
>>     > > SHLL [/] # echo 123
>>     Please put the above bug details into a ticket
>>     https://devel.rtems.org/wiki/NewTicket with a milestone of 6
>> Why wouldn't this also be appropriate for 5?
> It is fine for 5 with a ticket.
>> And can anyone confirm this happens on real hardware? Sometimes control
>> characters act funny on simulators.
> It is broken on hardware so the simulator and hardware match.
> Chris
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Frank Kühndel
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
Phone: +49-89-18 94 741 - 23
Fax:   +49-89-18 94 741 - 09
PGP: Public key available on request.
PGP: Fingerprint: EE89 0670 B8BE 551A ED4E  FB85 829C 306F 649C 05B9
