[PATCH v2 3/8] bsps: Break out AArch32 portions of GPT driver
Kinsey Moore kinsey.moore at oarcorp.com
Mon Sep 28 15:24:52 UTC 2020
This breaks AArch32-specific portions of the ARM GPT driver into their
own file so that the generic code can be moved for reuse by other
architectures.
 bsps/arm/imx/headers.am                       |  1 +
 bsps/arm/imx/include/bsp.h                    |  2 -
 bsps/arm/imx/start/bspstart.c                 |  3 +-
 .../clock/clock-arm-generic-timer-aarch32.c   | 76 +++++++++++++++++++
 bsps/arm/xen/headers.am                       |  1 +
 bsps/arm/xen/include/bsp.h                    |  2 -
 bsps/arm/xen/start/bspstart.c                 |  3 +-
 bsps/arm/xilinx-zynqmp/headers.am             |  1 +
 bsps/arm/xilinx-zynqmp/include/bsp.h          |  2 -
 bsps/arm/xilinx-zynqmp/start/bspstart.c       |  3 +-
 bsps/include/bsp/clock-arm-generic-timer.h    | 73 ++++++++++++++++++
 .../clock/clock-arm-generic-timer.c}          | 65 ++++------------
 c/src/lib/libbsp/arm/imx/Makefile.am          |  3 +-
 c/src/lib/libbsp/arm/xen/Makefile.am          |  3 +-
 .../lib/libbsp/arm/xilinx-zynqmp/Makefile.am  |  3 +-
 spec/build/bsps/arm/imx/bspimx.yml            |  4 +-
 spec/build/bsps/arm/xen/bspxen.yml            |  4 +-
 .../arm/xilinx-zynqmp/bspxilinxzynqmp.yml     |  4 +-
 18 files changed, 187 insertions(+), 66 deletions(-)
 create mode 100644 bsps/arm/shared/clock/clock-arm-generic-timer-aarch32.c
 create mode 100644 bsps/include/bsp/clock-arm-generic-timer.h
 rename bsps/{arm/shared/clock/clock-generic-timer.c => shared/clock/clock-arm-generic-timer.c} (71%)
diff --git a/bsps/arm/imx/headers.am b/bsps/arm/imx/headers.am
index 3a093b1698..76c1607871 100644
--- a/bsps/arm/imx/headers.am
+++ b/bsps/arm/imx/headers.am
@@ -21,3 +21,4 @@ include_bspdir = $(includedir)/bsp
 include_bsp_HEADERS =
 include_bsp_HEADERS += ../../../../../../bsps/arm/imx/include/bsp/imx-gpio.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/imx/include/bsp/irq.h
+include_bsp_HEADERS += ../../../../../../bsps/include/bsp/clock-arm-generic-timer.h
diff --git a/bsps/arm/imx/include/bsp.h b/bsps/arm/imx/include/bsp.h
index 134b3fd858..99b7a0d1d7 100644
--- a/bsps/arm/imx/include/bsp.h
+++ b/bsps/arm/imx/include/bsp.h
@@ -57,8 +57,6 @@ extern uintptr_t imx_gic_dist_base;
 #define BSP_ARM_A9MPCORE_SCU_BASE 0
-void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
 void *imx_get_reg_of_node(const void *fdt, int node);
 int imx_iomux_configure_pins(const void *fdt, uint32_t phandle);
diff --git a/bsps/arm/imx/start/bspstart.c b/bsps/arm/imx/start/bspstart.c
index 5fb07bf60a..ff5edaf5a1 100644
--- a/bsps/arm/imx/start/bspstart.c
+++ b/bsps/arm/imx/start/bspstart.c
@@ -18,6 +18,7 @@
 #include <bsp/fdt.h>
 #include <bsp/irq-generic.h>
 #include <bsp/linker-symbols.h>
+#include <bsp/clock-arm-generic-timer.h>
 #include <libfdt.h>
@@ -58,7 +59,7 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
   return intr[1] + MAGIC_IRQ_OFFSET;
+void aarch_generic_timer_get_config(
   uint32_t *irq
diff --git a/bsps/arm/shared/clock/clock-arm-generic-timer-aarch32.c b/bsps/arm/shared/clock/clock-arm-generic-timer-aarch32.c
new file mode 100644
index 0000000000..70509e2a86
--- /dev/null
+++ b/bsps/arm/shared/clock/clock-arm-generic-timer-aarch32.c
@@ -0,0 +1,76 @@
+ * @file
+ * @ingroup RTEMSBSPsARMShared
+ * @brief ARM-specific clock driver functions.
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <libcpu/arm-cp15.h>
+uint64_t aarch_gt_clock_get_compare_value(void)
+#ifdef ARM_GENERIC_TIMER_USE_VIRTUAL
+  return arm_cp15_get_counter_pl1_virtual_compare_value();
+#else
+  return arm_cp15_get_counter_pl1_physical_compare_value();
+#endif
+void aarch_gt_clock_set_compare_value(uint64_t cval)
+  arm_cp15_set_counter_pl1_virtual_compare_value(cval);
+#else
+  arm_cp15_set_counter_pl1_physical_compare_value(cval);
+#endif
+uint64_t aarch_gt_clock_get_count(void)
+  return arm_cp15_get_counter_virtual_count();
+#else
+  return arm_cp15_get_counter_physical_count();
+#endif
+void aarch_gt_clock_set_control(uint32_t ctl)
+  arm_cp15_set_counter_pl1_virtual_timer_control(ctl);
+#else
+  arm_cp15_set_counter_pl1_physical_timer_control(ctl);
+#endif
diff --git a/bsps/arm/xen/headers.am b/bsps/arm/xen/headers.am
index 952fa37670..4059d5fbb0 100644
--- a/bsps/arm/xen/headers.am
+++ b/bsps/arm/xen/headers.am
@@ -8,3 +8,4 @@ include_HEADERS += ../../../../../../bsps/arm/xen/include/tm27.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/xen/include/bsp/irq.h
diff --git a/bsps/arm/xen/include/bsp.h b/bsps/arm/xen/include/bsp.h
index e5b23a902e..ae03d81c1e 100644
--- a/bsps/arm/xen/include/bsp.h
+++ b/bsps/arm/xen/include/bsp.h
@@ -71,8 +71,6 @@ extern "C" {
 #define BSP_XEN_VPL011_BASE 0x22000000
 #define BSP_XEN_VPL011_LENGTH 0x1000
 BSP_START_TEXT_SECTION void bsp_xen_setup_mmu_and_cache(void);
 #ifdef __cplusplus
diff --git a/bsps/arm/xen/start/bspstart.c b/bsps/arm/xen/start/bspstart.c
index 6b826fc917..8de45a428d 100644
--- a/bsps/arm/xen/start/bspstart.c
+++ b/bsps/arm/xen/start/bspstart.c
@@ -30,10 +30,11 @@
 #include <bsp/bootcard.h>
-void arm_generic_timer_get_config( uint32_t *frequency, uint32_t *irq )
+void aarch_generic_timer_get_config( uint32_t *frequency, uint32_t *irq )
   *frequency = arm_cp15_get_counter_frequency();
diff --git a/bsps/arm/xilinx-zynqmp/headers.am b/bsps/arm/xilinx-zynqmp/headers.am
index 6cb3a00a52..5441f09856 100644
--- a/bsps/arm/xilinx-zynqmp/headers.am
+++ b/bsps/arm/xilinx-zynqmp/headers.am
@@ -8,3 +8,4 @@ include_HEADERS += ../../../../../../bsps/arm/xilinx-zynqmp/include/tm27.h
 include_bsp_HEADERS += ../../../../../../bsps/arm/xilinx-zynqmp/include/bsp/irq.h
diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h b/bsps/arm/xilinx-zynqmp/include/bsp.h
index 92f4d04421..9d33cf6134 100644
--- a/bsps/arm/xilinx-zynqmp/include/bsp.h
+++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
@@ -79,8 +79,6 @@ extern "C" {
 BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
 void zynqmp_debug_console_flush(void);
 #ifdef __cplusplus
diff --git a/bsps/arm/xilinx-zynqmp/start/bspstart.c b/bsps/arm/xilinx-zynqmp/start/bspstart.c
index ff79d78fed..e231fc3ef0 100644
--- a/bsps/arm/xilinx-zynqmp/start/bspstart.c
+++ b/bsps/arm/xilinx-zynqmp/start/bspstart.c
@@ -34,10 +34,11 @@
+void aarch_generic_timer_get_config(uint32_t *frequency, uint32_t *irq)
 #ifdef ARM_GENERIC_TIMER_FREQ
   *frequency = ARM_GENERIC_TIMER_FREQ;
diff --git a/bsps/include/bsp/clock-arm-generic-timer.h b/bsps/include/bsp/clock-arm-generic-timer.h
index 0000000000..1455994df4
--- /dev/null
+++ b/bsps/include/bsp/clock-arm-generic-timer.h
@@ -0,0 +1,73 @@
+ * @file
+ * @ingroup RTEMSBSPsShared
+ * @brief Header defining architecture-specific clock functions.
+ * are met:
+#include <rtems/score/basedefs.h>
+ * This function returns the current compare value for the ARM General Purpose Timer.
+ * @return The current compare value.
+uint64_t aarch_gt_clock_get_compare_value(void);
+ * This function sets the current compare value for the ARM General Purpose Timer.
+ * @param[in] cval The value to set as the compare value
+void aarch_gt_clock_set_compare_value(uint64_t cval);
+ * This function returns the count for the ARM General Purpose Timer.
+ * @return The current count.
+uint64_t aarch_gt_clock_get_count(void);
+ * This function sets the control register for the ARM General Purpose Timer.
+ * @param[in] ctl The value to set to the control register
+void aarch_gt_clock_set_control(uint32_t ctl);
+ * This function gets the frequency and IRQ number used by the ARM General Purpose Timer.
+ * @param[out] frequency The frequency at which the timer will fire.
+ * @param[out] irq The number of the IRQ on which the timer will fire.
+void aarch_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
diff --git a/bsps/arm/shared/clock/clock-generic-timer.c b/bsps/shared/clock/clock-arm-generic-timer.c
similarity index 71%
rename from bsps/arm/shared/clock/clock-generic-timer.c
rename to bsps/shared/clock/clock-arm-generic-timer.c
index 072583473e..94983f20d9 100644
--- a/bsps/arm/shared/clock/clock-generic-timer.c
+++ b/bsps/shared/clock/clock-arm-generic-timer.c
@@ -16,19 +16,18 @@
 #include <bsp/fatal.h>
 #include <bsp/irq.h>
 #include <rtems/counter.h>
 #include <rtems/sysinit.h>
 #include <rtems/timecounter.h>
 #include <rtems/score/smpimpl.h>
-#include <libcpu/arm-cp15.h>
- * Clock driver using the ARMv7-AR Generic Timer.  The BSP must provide the
- * following function via <bsp.h>:
+ * Clock driver using the ARMv7-AR/AArch64 Generic Timer.  The BSP must provide the
+ * following function:
- * void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
+ * void aarch_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
  * The BSP may optionally define ARM_GENERIC_TIMER_USE_VIRTUAL in <bsp.h> to
  * use the virtual timer instead of the physical timer.
@@ -45,53 +44,17 @@ static arm_gt_clock_context arm_gt_clock_instance;
 /* This is defined in dev/clock/clockimpl.h */
 void Clock_isr(rtems_irq_hdl_param arg);
-static inline uint64_t arm_gt_clock_get_compare_value(void)
-#ifdef ARM_GENERIC_TIMER_USE_VIRTUAL
-  return arm_cp15_get_counter_pl1_virtual_compare_value();
-#else
-  return arm_cp15_get_counter_pl1_physical_compare_value();
-#endif
-static inline void arm_gt_clock_set_compare_value(uint64_t cval)
-  arm_cp15_set_counter_pl1_virtual_compare_value(cval);
-#else
-  arm_cp15_set_counter_pl1_physical_compare_value(cval);
-#endif
-static inline uint64_t arm_gt_clock_get_count(void)
-  return arm_cp15_get_counter_virtual_count();
-#else
-  return arm_cp15_get_counter_physical_count();
-#endif
-static inline void arm_gt_clock_set_control(uint32_t ctl)
-  arm_cp15_set_counter_pl1_virtual_timer_control(ctl);
-#else
-  arm_cp15_set_counter_pl1_physical_timer_control(ctl);
-#endif
 static void arm_gt_clock_at_tick(void)
   uint64_t cval;
   uint32_t interval;
   interval = arm_gt_clock_instance.interval;
-  cval = arm_gt_clock_get_compare_value();
+  cval = aarch_gt_clock_get_compare_value();
   cval += interval;
-  arm_gt_clock_set_compare_value(cval);
+  aarch_gt_clock_set_compare_value(cval);
 #ifdef ARM_GENERIC_TIMER_UNMASK_AT_TICK
-  arm_gt_clock_set_control(0x1);
+  aarch_gt_clock_set_control(0x1);
 #endif /* ARM_GENERIC_TIMER_UNMASK_AT_TICK */
@@ -113,13 +76,13 @@ static void arm_gt_clock_handler_install(void)
 static uint32_t arm_gt_clock_get_timecount(struct timecounter *tc)
-  return (uint32_t) arm_gt_clock_get_count();
+  return (uint32_t) aarch_gt_clock_get_count();
 static void arm_gt_clock_gt_init(uint64_t cval)
 #if defined(RTEMS_SMP) && !defined(CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR)
@@ -152,7 +115,7 @@ static void arm_gt_clock_initialize(void)
   frequency = tc->tc_frequency;
   us_per_tick = rtems_configuration_get_microseconds_per_tick();
   interval = (uint32_t) ((frequency * us_per_tick) / 1000000);
-  cval = arm_gt_clock_get_count();
+  cval = aarch_gt_clock_get_count();
   cval += interval;
   arm_gt_clock_instance.interval = interval;
@@ -172,15 +135,15 @@ uint32_t _CPU_Counter_frequency(void)
 CPU_Counter_ticks _CPU_Counter_read(void)
 static void arm_gt_clock_early_init(void)
   uint32_t frequency;
-  arm_gt_clock_set_control(0x3);
+  aarch_gt_clock_set_control(0x3);
-  arm_generic_timer_get_config(
+  aarch_generic_timer_get_config(
     &frequency,
     &arm_gt_clock_instance.irq
diff --git a/c/src/lib/libbsp/arm/imx/Makefile.am b/c/src/lib/libbsp/arm/imx/Makefile.am
index f71508a077..7a865b2996 100644
--- a/c/src/lib/libbsp/arm/imx/Makefile.am
+++ b/c/src/lib/libbsp/arm/imx/Makefile.am
@@ -58,7 +58,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termio
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/imx/console/console-config.c
 # Clock
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-generic-timer.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/clock/clock-arm-generic-timer.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-arm-generic-timer-aarch32.c
 # Cache
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
diff --git a/c/src/lib/libbsp/arm/xen/Makefile.am b/c/src/lib/libbsp/arm/xen/Makefile.am
index 18cce5ec29..c642d7f991 100644
--- a/c/src/lib/libbsp/arm/xen/Makefile.am
+++ b/c/src/lib/libbsp/arm/xen/Makefile.am
@@ -29,7 +29,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/start/bsp-start-memcp
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
 # clock
 # cache
 # irq
diff --git a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
index 0b49990ce7..fd741873e5 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
@@ -64,7 +64,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/zynq-uart.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/zynq-uart-polled.c
 # Clock
 # Cache
diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
index 0d32669a4a..f1f679f8d7 100644
--- a/spec/build/bsps/arm/imx/bspimx.yml
+++ b/spec/build/bsps/arm/imx/bspimx.yml
@@ -29,6 +29,7 @@ install:
   source:
   - bsps/arm/imx/include/bsp/imx-gpio.h
   - bsps/arm/imx/include/bsp/irq.h
+  - bsps/include/bsp/clock-arm-generic-timer.h
 - destination: ${BSP_LIBDIR}
   source:
   - bsps/arm/imx/start/linkcmds
@@ -88,7 +89,8 @@ source:
 - bsps/arm/imx/start/imx_iomux.c
 - bsps/arm/shared/cache/cache-cp15.c
 - bsps/arm/shared/cache/cache-v7ar-disable-data.S
-- bsps/arm/shared/clock/clock-generic-timer.c
+- bsps/shared/clock/clock-arm-generic-timer.c
+- bsps/arm/shared/clock/clock-arm-generic-timer-aarch32.c
 - bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
 - bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
 - bsps/arm/shared/irq/irq-gic.c
diff --git a/spec/build/bsps/arm/xen/bspxen.yml b/spec/build/bsps/arm/xen/bspxen.yml
index df14fcce66..4bd86b5c60 100644
--- a/spec/build/bsps/arm/xen/bspxen.yml
+++ b/spec/build/bsps/arm/xen/bspxen.yml
@@ -17,6 +17,7 @@ install:
 - destination: ${BSP_INCLUDEDIR}/bsp
   source:
   - bsps/arm/xen/include/bsp/irq.h
 links:
 - role: build-dependency
   uid: ../grp
@@ -56,7 +57,8 @@ links:
   uid: ../../bspopts
 source:
diff --git a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
index fe56228c38..67bd1b0dd3 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
   source:
   - bsps/arm/xilinx-zynqmp/include/bsp/irq.h
 links:
   uid: ../grp
@@ -72,7 +73,8 @@ links:
   uid: ../../bspopts
 source:
2.20.1
