[PATCH v2 6/8] score: Add AArch64 port
Kinsey Moore kinsey.moore at oarcorp.com
Mon Sep 28 15:24:55 UTC 2020
This adds a CPU port for AArch64(ARMv8) with support for exceptions and
interrupts.
 cpukit/include/rtems/score/tls.h              |   4 +-
 .../cpu/aarch64/aarch64-context-validate.S    | 305 ++++++++++
 .../aarch64-context-volatile-clobber.S        | 100 ++++
 .../cpu/aarch64/aarch64-exception-default.S   | 418 +++++++++++++
 .../cpu/aarch64/aarch64-exception-default.c   |  50 ++
 .../aarch64/aarch64-exception-frame-print.c   | 108 ++++
 .../cpu/aarch64/aarch64-exception-interrupt.S | 317 ++++++++++
 .../score/cpu/aarch64/aarch64-thread-idle.c   |  48 ++
 cpukit/score/cpu/aarch64/cpu.c                | 196 +++++++
 cpukit/score/cpu/aarch64/cpu_asm.S            | 134 +++++
 .../cpu/aarch64/include/libcpu/vectors.h      | 100 ++++
 cpukit/score/cpu/aarch64/include/rtems/asm.h  |  89 +++
 .../cpu/aarch64/include/rtems/score/aarch64.h |  83 +++
 .../cpu/aarch64/include/rtems/score/cpu.h     | 549 ++++++++++++++++++
 .../aarch64/include/rtems/score/cpuatomic.h   |  42 ++
 .../cpu/aarch64/include/rtems/score/cpuimpl.h |  83 +++
 spec/build/cpukit/cpuaarch64.yml              |  35 ++
 spec/build/cpukit/librtemscpu.yml             |   2 +
 18 files changed, 2662 insertions(+), 1 deletion(-)
 create mode 100644 cpukit/score/cpu/aarch64/aarch64-context-validate.S
 create mode 100644 cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S
 create mode 100644 cpukit/score/cpu/aarch64/aarch64-exception-default.S
 create mode 100644 cpukit/score/cpu/aarch64/aarch64-exception-default.c
 create mode 100644 cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
 create mode 100644 cpukit/score/cpu/aarch64/aarch64-thread-idle.c
 create mode 100644 cpukit/score/cpu/aarch64/cpu.c
 create mode 100644 cpukit/score/cpu/aarch64/cpu_asm.S
 create mode 100644 cpukit/score/cpu/aarch64/include/libcpu/vectors.h
 create mode 100644 cpukit/score/cpu/aarch64/include/rtems/asm.h
 create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/aarch64.h
 create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
 create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
 create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
 create mode 100644 spec/build/cpukit/cpuaarch64.yml
diff --git a/cpukit/include/rtems/score/tls.h b/cpukit/include/rtems/score/tls.h
index 65a49d87be..66961f0083 100644
--- a/cpukit/include/rtems/score/tls.h
+++ b/cpukit/include/rtems/score/tls.h
@@ -85,7 +85,9 @@ typedef struct TLS_Thread_control_block {
   struct TLS_Thread_control_block *tcb;
 #else /* !__i386__ */
   TLS_Dynamic_thread_vector *dtv;
-#if CPU_SIZEOF_POINTER == 4
+/* gcc under AArch64/LP64 expects a 16 byte TCB at the beginning of the TLS
+ * data segment and indexes into it accordingly for TLS variable addresses */
+#if CPU_SIZEOF_POINTER == 4 || defined(AARCH64_MULTILIB_ARCH_V8)
   uintptr_t reserved;
 #endif
 #endif /* __i386__ */
diff --git a/cpukit/score/cpu/aarch64/aarch64-context-validate.S b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
new file mode 100644
index 0000000000..31c8d5571c
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
@@ -0,0 +1,305 @@
+ * @file
+ * @ingroup RTEMSScoreCPUAArch64
+ * @brief Implementation of _CPU_Context_validate
+ * This file implements _CPU_Context_validate for use in spcontext01.
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/asm.h>
+#include <rtems/score/cpu.h>
+#define FRAME_OFFSET_X4 0
+#define FRAME_OFFSET_X5 8
+#define FRAME_OFFSET_X6 16
+#define FRAME_OFFSET_X7 24
+#define FRAME_OFFSET_X8 32
+#define FRAME_OFFSET_X9 40
+#define FRAME_OFFSET_X10 48
+#define FRAME_OFFSET_X11 56
+#define FRAME_OFFSET_LR 64
+#ifdef AARCH64_MULTILIB_VFP
+  #define FRAME_OFFSET_V8 72
+  #define FRAME_OFFSET_V9 88
+  #define FRAME_OFFSET_V10 104
+  #define FRAME_OFFSET_V11 120
+  #define FRAME_OFFSET_V12 136
+  #define FRAME_OFFSET_V13 152
+  #define FRAME_OFFSET_V14 168
+  #define FRAME_OFFSET_V15 184
+  #define FRAME_SIZE (FRAME_OFFSET_V15 + 16)
+#else
+  #define FRAME_SIZE (FRAME_OFFSET_LR + 8)
+#endif
+	.section	.text
+FUNCTION_ENTRY(_CPU_Context_validate)
+	/* Save */
+	sub	sp, sp, #FRAME_SIZE
+	str	x4, [sp, #FRAME_OFFSET_X4]
+	str	x5, [sp, #FRAME_OFFSET_X5]
+	str	x6, [sp, #FRAME_OFFSET_X6]
+	str	x7, [sp, #FRAME_OFFSET_X7]
+	str	x8, [sp, #FRAME_OFFSET_X8]
+	str	x9, [sp, #FRAME_OFFSET_X9]
+	str	x10, [sp, #FRAME_OFFSET_X10]
+	str	x11, [sp, #FRAME_OFFSET_X11]
+	str	lr, [sp, #FRAME_OFFSET_LR]
+	str	d8, [sp, #FRAME_OFFSET_V8]
+	str	d9, [sp, #FRAME_OFFSET_V9]
+	str	d10, [sp, #FRAME_OFFSET_V10]
+	str	d11, [sp, #FRAME_OFFSET_V11]
+	str	d12, [sp, #FRAME_OFFSET_V12]
+	str	d13, [sp, #FRAME_OFFSET_V13]
+	str	d14, [sp, #FRAME_OFFSET_V14]
+	str	d15, [sp, #FRAME_OFFSET_V15]
+#endif
+	/* Fill */
+	/* R1 is used for temporary values */
+	mov	x1, x0
+	/* R2 contains the stack pointer */
+	mov	x2, sp
+.macro fill_register reg
+	add	x1, x1, #1
+	mov	\reg, x1
+.endm
+	/* X3 contains the FPSCR */
+	mrs	x3, FPSR
+	ldr	x4, =0xf000001f
+	bic	x3, x3, x4
+	and	x4, x4, x0
+	orr	x3, x3, x4
+	msr	FPSR, x3
+#else
+	fill_register	x3
+#endif
+	fill_register	x4
+	fill_register	x5
+	fill_register	x6
+	fill_register	x7
+	fill_register	x8
+	fill_register	x9
+	fill_register	x10
+	fill_register	x11
+	fill_register	x12
+	fill_register	lr
+.macro fill_vfp_register regnum
+	add	x1, x1, #1
+	fmov	d\regnum\(), x1
+	fmov	v\regnum\().D[1], x1
+.endm
+	fill_vfp_register	0
+	fill_vfp_register	1
+	fill_vfp_register	2
+	fill_vfp_register	3
+	fill_vfp_register	4
+	fill_vfp_register	5
+	fill_vfp_register	6
+	fill_vfp_register	7
+	fill_vfp_register	8
+	fill_vfp_register	9
+	fill_vfp_register	10
+	fill_vfp_register	11
+	fill_vfp_register	12
+	fill_vfp_register	13
+	fill_vfp_register	14
+	fill_vfp_register	15
+	fill_vfp_register	16
+	fill_vfp_register	17
+	fill_vfp_register	18
+	fill_vfp_register	19
+	fill_vfp_register	20
+	fill_vfp_register	21
+	fill_vfp_register	22
+	fill_vfp_register	23
+	fill_vfp_register	24
+	fill_vfp_register	25
+	fill_vfp_register	26
+	fill_vfp_register	27
+	fill_vfp_register	28
+	fill_vfp_register	29
+	fill_vfp_register	30
+	fill_vfp_register	31
+#endif /* AARCH64_MULTILIB_VFP */
+	/* Check */
+check:
+.macro check_register reg
+	add	x1, x1, #1
+	cmp	\reg, x1
+	bne	restore
+.endm
+	/* A compare involving the stack pointer is deprecated */
+	mov	x1, sp
+	cmp	x2, x1
+	bne	restore
+	mov	x1, x0
+#ifndef AARCH64_MULTILIB_VFP
+	check_register	x3
+#endif
+	check_register	x4
+	check_register	x5
+	check_register	x6
+	check_register	x7
+	check_register	x8
+	check_register	x9
+	check_register	x10
+	check_register	x11
+	check_register	x12
+	check_register	lr
+	b	check_vfp
+#endif
+	b	check
+	/* Restore */
+restore:
+	ldr	x4, [sp, #FRAME_OFFSET_X4]
+	ldr	x5, [sp, #FRAME_OFFSET_X5]
+	ldr	x6, [sp, #FRAME_OFFSET_X6]
+	ldr	x7, [sp, #FRAME_OFFSET_X7]
+	ldr	x8, [sp, #FRAME_OFFSET_X8]
+	ldr	x9, [sp, #FRAME_OFFSET_X9]
+	ldr	x10, [sp, #FRAME_OFFSET_X10]
+	ldr	x11, [sp, #FRAME_OFFSET_X11]
+	ldr	lr, [sp, #FRAME_OFFSET_LR]
+	ldr	d8, [sp, #FRAME_OFFSET_V8]
+	ldr	d9, [sp, #FRAME_OFFSET_V9]
+	ldr	d10, [sp, #FRAME_OFFSET_V10]
+	ldr	d11, [sp, #FRAME_OFFSET_V11]
+	ldr	d12, [sp, #FRAME_OFFSET_V12]
+	ldr	d13, [sp, #FRAME_OFFSET_V13]
+	ldr	d14, [sp, #FRAME_OFFSET_V14]
+	ldr	d15, [sp, #FRAME_OFFSET_V15]
+#endif
+	add	sp, sp, #FRAME_SIZE
+	ret
+FUNCTION_END(_CPU_Context_validate)
+check_vfp:
+.macro check_vfp_register regnum
+	add	x1, x1, #1
+	fmov	x4, d\regnum
+	fmov	x5, v\regnum\().D[1]
+	cmp	x5, x4
+	bne	1f
+	cmp	x1, x4
+	bne	1f
+	b	2f
+1:
+	b	restore
+2:
+.endm
+	mrs	x4, FPSR
+	cmp	x4, x3
+	bne	restore
+	check_vfp_register	0
+	check_vfp_register	1
+	check_vfp_register	2
+	check_vfp_register	3
+	check_vfp_register	4
+	check_vfp_register	5
+	check_vfp_register	6
+	check_vfp_register	7
+	check_vfp_register	8
+	check_vfp_register	9
+	check_vfp_register	10
+	check_vfp_register	11
+	check_vfp_register	12
+	check_vfp_register	13
+	check_vfp_register	14
+	check_vfp_register	15
+	check_vfp_register	16
+	check_vfp_register	17
+	check_vfp_register	18
+	check_vfp_register	19
+	check_vfp_register	20
+	check_vfp_register	21
+	check_vfp_register	22
+	check_vfp_register	23
+	check_vfp_register	24
+	check_vfp_register	25
+	check_vfp_register	26
+	check_vfp_register	27
+	check_vfp_register	28
+	check_vfp_register	29
+	check_vfp_register	30
+	check_vfp_register	31
+	/* Restore x4 and x5 */
+	mov	x1, x0
+	fill_register	x4
+	fill_register	x5
+	b	check
diff --git a/cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S b/cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S
index 0000000000..2be5ce69ff
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S
@@ -0,0 +1,100 @@
+ * @file
+ * @brief Implementation of _CPU_Context_volatile_clobber
+ * This file implements _CPU_Context_volatile_clobber for use in spcontext01.
+ * are met:
+#endif
+	.section	.text
+FUNCTION_ENTRY(_CPU_Context_volatile_clobber)
+.macro clobber_register reg
+	sub	x0, x0, #1
+	mov	\reg, x0
+.endm
+	mrs	x1, FPCR
+	ldr	x2, =0xf000001f
+	bic	x1, x1, x2
+	and	x2, x2, x0
+	orr	x1, x1, x2
+	msr	FPCR, x1
+.macro clobber_vfp_register reg
+	sub	x0, x0, #1
+	fmov	\reg, x0
+.endm
+	clobber_vfp_register	d0
+	clobber_vfp_register	d1
+	clobber_vfp_register	d2
+	clobber_vfp_register	d3
+	clobber_vfp_register	d4
+	clobber_vfp_register	d5
+	clobber_vfp_register	d6
+	clobber_vfp_register	d7
+	clobber_vfp_register	d16
+	clobber_vfp_register	d17
+	clobber_vfp_register	d18
+	clobber_vfp_register	d19
+	clobber_vfp_register	d20
+	clobber_vfp_register	d21
+	clobber_vfp_register	d22
+	clobber_vfp_register	d23
+	clobber_vfp_register	d24
+	clobber_vfp_register	d25
+	clobber_vfp_register	d26
+	clobber_vfp_register	d27
+	clobber_vfp_register	d28
+	clobber_vfp_register	d29
+	clobber_vfp_register	d30
+	clobber_vfp_register	d31
+	clobber_register	x1
+	clobber_register	x2
+	clobber_register	x3
+	clobber_register	x12
+	ret
+FUNCTION_END(_CPU_Context_volatile_clobber)
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.S b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
index 0000000000..607a1edac1
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
@@ -0,0 +1,418 @@
+ * @file
+ * @brief Implementation of AArch64 exception vector table.
+ * This file implements the AArch64 exception vector table and its embedded
+ * jump handlers along with the code necessary to call higher level C handlers.
+ * are met:
+#endif
+.extern _AArch64_Exception_default
+.globl	bsp_start_vector_table_begin
+.globl	bsp_start_vector_table_end
+.globl	bsp_start_vector_table_size
+.globl	bsp_vector_table_size
+.section ".text"
+ * This is the exception vector table and the pointers to the default
+ * exceptions handlers.
+/* TODO(kmoore) The current implementation here assumes that SP is not misaligned */
+	.macro	JUMP_HANDLER
+	mov x0, #0x7f			/* mask to use in BIC, lower 7 bits */
+	bic x0,	lr,	x0		/* lr contains PC, mask off to the base of the current vector */
+	ldr x0,	[x0,	#0x78]		/* load address from the last word in the vector */
+	blr x0				/* branch and link to address in x0, no reason to save current LR since it has already been saved and current contents are junk */
+	ldp x0,	lr,	[sp],	#16	/* pop x0,lr from stack */
+	eret				/* return from exception */
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	nop
+	.endm
+	.macro	JUMP_TARGET_SP0
+	/* takes up the space of 2 instructions */
+#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
+	.word .print_exception_dump_sp0
+	.word 0x0
+#else
+	.dword .print_exception_dump_sp0
+#endif
+	.endm
+	.macro	JUMP_TARGET_SPx
+	.word .print_exception_dump_spx
+	.word 0x0
+#else
+	.dword .print_exception_dump_spx
+#endif
+	.endm
+bsp_start_vector_table_begin:
+.balign 0x800
+Vector_table_el3:
+curr_el_sp0_sync: // The exception handler for the synchronous exception from the current EL using SP0.
+	stp x0,	lr,	[sp, #-16]!	/* push x0,lr on to the stack */
+	bl curr_el_sp0_sync_get_pc	/* get current execution address */
+curr_el_sp0_sync_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SP0
+.balign 0x80
+curr_el_sp0_irq: // The exception handler for the IRQ exception from the current EL using SP0.
+	bl curr_el_sp0_irq_get_pc	/* get current execution address */
+curr_el_sp0_irq_get_pc:			/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SP0
+.balign 0x80
+curr_el_sp0_fiq: // The exception handler for the FIQ exception from the current EL using SP0.
+	bl curr_el_sp0_fiq_get_pc	/* get current execution address */
+curr_el_sp0_fiq_get_pc:			/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SP0
+.balign 0x80
+curr_el_sp0_serror: // The exception handler for the system error exception from the current EL using SP0.
+	bl curr_el_sp0_serror_get_pc	/* get current execution address */
+curr_el_sp0_serror_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SP0
+.balign 0x80
+curr_el_spx_sync: // The exception handler for the synchronous exception from the current EL using the // current SP.
+	bl curr_el_spx_sync_get_pc	/* get current execution address */
+curr_el_spx_sync_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+curr_el_spx_irq: // The exception handler for IRQ exception from the current EL using the current SP.
+	bl curr_el_spx_irq_get_pc	/* get current execution address */
+curr_el_spx_irq_get_pc:			/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+curr_el_spx_fiq: // The exception handler for the FIQ exception from the current EL using the current SP.
+	bl curr_el_spx_fiq_get_pc	/* get current execution address */
+curr_el_spx_fiq_get_pc:			/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+curr_el_spx_serror: // The exception handler for the system error exception from the current EL using the // current SP.
+	bl curr_el_spx_serror_get_pc	/* get current execution address */
+curr_el_spx_serror_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+lower_el_aarch64_sync: // The exception handler for the synchronous exception from a lower EL (AArch64).
+	bl lower_el_aarch64_sync_get_pc	/* get current execution address */
+lower_el_aarch64_sync_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+lower_el_aarch64_irq: // The exception handler for the IRQ exception from a lower EL (AArch64).
+	bl lower_el_aarch64_irq_get_pc	/* get current execution address */
+lower_el_aarch64_irq_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+lower_el_aarch64_fiq: // The exception handler for the FIQ exception from a lower EL (AArch64).
+	bl lower_el_aarch64_fiq_get_pc	/* get current execution address */
+lower_el_aarch64_fiq_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+lower_el_aarch64_serror: // The exception handler for the system error exception from a lower EL(AArch64).
+	bl lower_el_aarch64_serror_get_pc	/* get current execution address */
+lower_el_aarch64_serror_get_pc:			/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+lower_el_aarch32_sync: // The exception handler for the synchronous exception from a lower EL(AArch32).
+	bl lower_el_aarch32_sync_get_pc	/* get current execution address */
+lower_el_aarch32_sync_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+lower_el_aarch32_irq: // The exception handler for the IRQ exception from a lower EL (AArch32).
+	bl lower_el_aarch32_irq_get_pc	/* get current execution address */
+lower_el_aarch32_irq_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+lower_el_aarch32_fiq: // The exception handler for the FIQ exception from a lower EL (AArch32).
+	bl lower_el_aarch32_fiq_get_pc	/* get current execution address */
+lower_el_aarch32_fiq_get_pc:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+.balign 0x80
+lower_el_aarch32_serror: // The exception handler for the system error exception from a lower EL(AArch32).
+	bl lower_el_aarch32_serror_get_pc	/* get current execution address */
+lower_el_aarch32_serror_get_pc	:		/* current PC now in LR */
+	JUMP_HANDLER
+	JUMP_TARGET_SPx
+bsp_start_vector_table_end:
+	.set	bsp_start_vector_table_size, bsp_start_vector_table_end - bsp_start_vector_table_begin
+	.set	bsp_vector_table_size, bsp_start_vector_table_size
+/* This involves switching a few things around. the real x0 and lr are on SPx and need to be retrieved
+ * while the lr upon entry contains the pointer into the AArch64 vector table */
+.print_exception_dump_spx:
+/* switch to exception stack (SP0) */
+	msr spsel, #0
+/* save space for exception context */
+	sub sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
+/* push exception vector, LR currently points into the actual exception vector table */
+	and lr, lr, #0x780
+	lsr lr, lr, #7
+	str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET]
+/* pop x0,lr from stack, saved by generic handler */
+/* this modifies the stack pointer back to the pre-vector-handler value which is safe because this will never return */
+	msr spsel, #1
+	msr spsel, #0
+/* save LR */
+	str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]
+/* push the start of the context */
+	bl .push_exception_context_start
+/* save original sp in x0 for .push_exception_context_finish */
+	msr spsel, #1
+	mov x0, sp
+	msr spsel, #0
+/* push the remainder of the context */
+	bl .push_exception_context_finish
+/* save sp into x0 for handler */
+	mov x0, sp
+/* jump into the handler */
+	bl _AArch64_Exception_default
+	/* Just in case */
+	b	twiddle
+.print_exception_dump_sp0:
+/* push exception vector, LR currently points into the actual exception vector */
+	lsr lr, lr, #7
+/* get x0,lr from stack, saved by generic handler */
+	add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
+	ldp x0,	lr, [sp]
+/* save LR */
+	add x0, sp, #(AARCH64_EXCEPTION_FRAME_SIZE + 16)
+/* save sp (exception frame) into x0 for handler */
+	mov x0, sp
+twiddle:
+	b	twiddle
+/* assumes SP is at the base of the context and LR has already been pushed */
+.push_exception_context_start:
+/* push x0-x29(fp) */
+	stp x0,  x1,  [sp, #0x00]
+	stp x2,  x3,  [sp, #0x10]
+	stp x4,  x5,  [sp, #0x20]
+	stp x6,  x7,  [sp, #0x30]
+	stp x8,  x9,  [sp, #0x40]
+	stp x10, x11, [sp, #0x50]
+	stp x12, x13, [sp, #0x60]
+	stp x14, x15, [sp, #0x70]
+	stp x16, x17, [sp, #0x80]
+	stp x18, x19, [sp, #0x90]
+	stp x20, x21, [sp, #0xa0]
+	stp x22, x23, [sp, #0xb0]
+	stp x24, x25, [sp, #0xc0]
+	stp x26, x27, [sp, #0xd0]
+	stp x28, x29, [sp, #0xe0]
+	ret
+/* Expects original SP to be stored in x0 */
+.push_exception_context_finish:
+/* get exception LR for PC */
+	mrs x1, ELR_EL1
+/* push sp and pc */
+	stp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET]
+/* get daif and spsr */
+	mrs x0, DAIF
+	mrs x1, SPSR_EL1
+/* push daif and spsr */
+	stp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
+/* get ESR and FAR */
+	mrs x0, ESR_EL1
+	mrs x1, FAR_EL1
+/* push FAR and ESR */
+	stp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
+/* get fpcr and fpsr */
+	mrs x0, FPSR
+	mrs x1, FPCR
+/* push fpcr and fpsr */
+	stp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
+/* push VFP registers */
+	stp q0,  q1,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
+	stp q2,  q3,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
+	stp q4,  q5,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
+	stp q6,  q7,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
+	stp q8,  q9,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
+	stp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
+	stp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
+	stp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
+	stp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
+	stp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
+	stp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
+	stp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
+	stp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
+	stp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
+	stp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
+	stp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
+/* done, return to exception handler */
+	ret
+/* apply the exception frame to the current register status, SP points to the EF */
+.pop_exception_context_and_ret:
+/* pop daif and spsr */
+	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
+/* restore daif and spsr */
+	msr DAIF, x2
+	msr SPSR_EL1, x3
+/* pop FAR and ESR */
+	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
+/* restore ESR and FAR */
+	msr ESR_EL1, x2
+	msr FAR_EL1, x3
+/* pop fpcr and fpsr */
+	ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
+/* restore fpcr and fpsr */
+	msr FPSR, x2
+	msr FPCR, x3
+/* restore LR */
+	ldr lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]
+/* pop VFP registers */
+	ldp q0,  q1,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
+	ldp q2,  q3,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
+	ldp q4,  q5,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
+	ldp q6,  q7,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
+	ldp q8,  q9,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
+	ldp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
+	ldp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
+	ldp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
+	ldp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
+	ldp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
+	ldp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
+	ldp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
+	ldp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
+	ldp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
+	ldp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
+	ldp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
+/* pop x0-x29(fp) */
+	ldp x2,  x3,  [sp, #0x10]
+	ldp x4,  x5,  [sp, #0x20]
+	ldp x6,  x7,  [sp, #0x30]
+	ldp x8,  x9,  [sp, #0x40]
+	ldp x10, x11, [sp, #0x50]
+	ldp x12, x13, [sp, #0x60]
+	ldp x14, x15, [sp, #0x70]
+	ldp x16, x17, [sp, #0x80]
+	ldp x18, x19, [sp, #0x90]
+	ldp x20, x21, [sp, #0xa0]
+	ldp x22, x23, [sp, #0xb0]
+	ldp x24, x25, [sp, #0xc0]
+	ldp x26, x27, [sp, #0xd0]
+	ldp x28, x29, [sp, #0xe0]
+/* pop sp (TODO(kmoore): ignored, factor out) and ELR */
+	ldp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET]
+/* restore exception LR */
+	msr ELR_EL1, x1
+	ldp x0,  x1,  [sp, #0x00]
+	/* We must clear reservations here to ensure consistency with atomic operations */
+	clrex
+	ret
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.c b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
index 0000000000..2ebb3dee9f
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief Implementation of _AArch64_Exception_default
+ * This file implements _AArch64_Exception_default for use as part of the
+ * default exception handling code which dumps all system registers.
+ * are met:
+#endif
+#include <rtems/fatal.h>
+void _AArch64_Exception_default( CPU_Exception_frame *frame )
+  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
index 0000000000..cd919c3214
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
@@ -0,0 +1,108 @@
+ * @file
+ * @brief Implementation of _CPU_Exception_frame_print.
+ * This file implements _CPU_Exception_frame_print for use in fatal output.
+ * It dumps all standard integer and floating point registers as well as some
+ * of the more important system registers.
+ * are met:
+#endif
+#include <inttypes.h>
+#include <rtems/bspIo.h>
+void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
+  printk(
+    "\n"
+    "X0   = 0x%016" PRIx64  " X17  = 0x%016" PRIx64 "\n"
+    "X1   = 0x%016" PRIx64  " X18  = 0x%016" PRIx64 "\n"
+    "X2   = 0x%016" PRIx64  " X19  = 0x%016" PRIx64 "\n"
+    "X3   = 0x%016" PRIx64  " X20  = 0x%016" PRIx64 "\n"
+    "X4   = 0x%016" PRIx64  " X21  = 0x%016" PRIx64 "\n"
+    "X5   = 0x%016" PRIx64  " X22  = 0x%016" PRIx64 "\n"
+    "X6   = 0x%016" PRIx64  " X23  = 0x%016" PRIx64 "\n"
+    "X7   = 0x%016" PRIx64  " X24  = 0x%016" PRIx64 "\n"
+    "X8   = 0x%016" PRIx64  " X25  = 0x%016" PRIx64 "\n"
+    "X9   = 0x%016" PRIx64  " X26  = 0x%016" PRIx64 "\n"
+    "X10  = 0x%016" PRIx64  " X27  = 0x%016" PRIx64 "\n"
+    "X11  = 0x%016" PRIx64  " X28  = 0x%016" PRIx64 "\n"
+    "X12  = 0x%016" PRIx64  " FP   = 0x%016" PRIx64 "\n"
+    "X13  = 0x%016" PRIx64  " LR   = 0x%016" PRIxPTR "\n"
+    "X14  = 0x%016" PRIx64  " SP   = 0x%016" PRIx64 "\n"
+    "X15  = 0x%016" PRIx64  " PC   = 0x%016" PRIxPTR "\n"
+    "X16  = 0x%016" PRIx64  " DAIF = 0x%016" PRIx64 "\n"
+    "VEC  = 0x%016" PRIxPTR " CPSR = 0x%016" PRIx64 "\n"
+    "ESR  = 0x%016" PRIx64  " FAR  = 0x%016" PRIx64 "\n",
+    frame->register_x0, frame->register_x17,
+    frame->register_x1, frame->register_x18,
+    frame->register_x2, frame->register_x19,
+    frame->register_x3, frame->register_x20,
+    frame->register_x4, frame->register_x21,
+    frame->register_x5, frame->register_x22,
+    frame->register_x6, frame->register_x23,
+    frame->register_x7, frame->register_x24,
+    frame->register_x8, frame->register_x25,
+    frame->register_x9, frame->register_x26,
+    frame->register_x10, frame->register_x27,
+    frame->register_x11, frame->register_x28,
+    frame->register_x12, frame->register_fp,
+    frame->register_x13, (intptr_t)frame->register_lr,
+    frame->register_x14, frame->register_sp,
+    frame->register_x15, (intptr_t)frame->register_pc,
+    frame->register_x16, frame->register_daif,
+    (intptr_t) frame->vector, frame->register_cpsr,
+    frame->register_syndrome, frame->register_fault_address
+  const uint128_t *qx = &frame->register_q0;
+  int i;
+  printk(
+    "FPCR = 0x%016" PRIx64 " FPSR = 0x%016" PRIx64 "\n",
+    frame->register_fpcr, frame->register_fpsr
+  for ( i = 0; i < 32; ++i ) {
+    uint64_t low = (uint64_t) qx[i];
+    uint64_t high = (uint64_t) (qx[i] >> 32);
+    printk( "Q%02i  = 0x%016" PRIx64 "%016" PRIx64 "\n", i, high, low );
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
index 0000000000..f6f308c4f6
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
@@ -0,0 +1,317 @@
+ * @file
+ * @brief Implementation of AArch64 interrupt exception handling
+ * This file implements the SP0 and SPx interrupt exception handlers to
+ * deal with nested and non-nested interrupts.
+ * are met:
+#endif
+.globl	_AArch64_Exception_interrupt_no_nest
+.globl	_AArch64_Exception_interrupt_nest
+  #define SELF_CPU_CONTROL_GET_REG w19
+#else
+  #define SELF_CPU_CONTROL_GET_REG x19
+#endif
+#define SELF_CPU_CONTROL x19
+#define NON_VOLATILE_SCRATCH x20
+/* it's understood that CPU state is saved prior to this and restored after this */
+/* NOTE: This function does not follow the AArch64 procedure call specification
+ * because all relevant state is known to be saved in the interrupt context,
+ * hence the blind usage of x19, x20, and x21 */
+.AArch64_Interrupt_Handler:
+	/* Get per-CPU control of current processor */
+	GET_SELF_CPU_CONTROL	SELF_CPU_CONTROL_GET_REG
+	/* Increment interrupt nest and thread dispatch disable level */
+	ldr	w2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+	ldr	w3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+	add	w2, w2, #1
+	add	w3, w3, #1
+	str	w2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+	str	w3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+	/* Save LR */
+	mov	x21, LR
+	/* Call BSP dependent interrupt dispatcher */
+	bl	bsp_interrupt_dispatch
+	/* Restore LR */
+	mov	LR, x21
+	/* Load some per-CPU variables */
+	ldr	w0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+	ldrb	w1, [SELF_CPU_CONTROL, #PER_CPU_DISPATCH_NEEDED]
+	ldr	w2, [SELF_CPU_CONTROL, #PER_CPU_ISR_DISPATCH_DISABLE]
+	ldr	w3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+	/* Decrement levels and determine thread dispatch state */
+	eor	w1, w1, w0
+	sub	w0, w0, #1
+	orr	w1, w1, w0
+	orr	w1, w1, w2
+	sub	w3, w3, #1
+	/* Store thread dispatch disable and ISR nest levels */
+	str	w0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+	str	w3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+	/* Return should_skip_thread_dispatch in x0 */
+	mov	x0, x1
+	/* Return from handler */
+	ret
+.AArch64_Perform_Thread_Dispatch:
+	/* Thread dispatch */
+	mrs	NON_VOLATILE_SCRATCH, DAIF
+.Ldo_thread_dispatch:
+	/* Set ISR dispatch disable and thread dispatch disable level to one */
+	mov	w0, #1
+	str	w0, [SELF_CPU_CONTROL, #PER_CPU_ISR_DISPATCH_DISABLE]
+	/* Save LR */
+	mov	x21, LR
+	/* Call _Thread_Do_dispatch(), this function will enable interrupts */
+	mov	x0, SELF_CPU_CONTROL
+	mov	x1, NON_VOLATILE_SCRATCH
+	mov	x2, #0x80
+	bic	x1, x1, x2
+	bl	_Thread_Do_dispatch
+	/* Restore LR */
+	mov	LR, x21
+	/* Disable interrupts */
+	msr	DAIF, NON_VOLATILE_SCRATCH
+#ifdef RTEMS_SMP
+#endif
+	/* Check if we have to do the thread dispatch again */
+	ldrb	w0, [SELF_CPU_CONTROL, #PER_CPU_DISPATCH_NEEDED]
+	cmp	w0, #0
+	bne	.Ldo_thread_dispatch
+	/* We are done with thread dispatching */
+	mov	w0, #0
+	/* Return from thread dispatch */
+	ret
+/* Must save corruptible registers and non-corruptible registers expected to be used,
+ * x0 and lr expected to be already saved on the stack */
+.macro	push_interrupt_context
+/* push x1-x21 on to the stack, need 19-21 because they're modified without obeying PCS */
+	stp lr,		x1,	[sp, #-16]!
+	stp x2,		x3,	[sp, #-16]!
+	stp x4,		x5,	[sp, #-16]!
+	stp x6,		x7,	[sp, #-16]!
+	stp x8,		x9,	[sp, #-16]!
+	stp x10,	x11,	[sp, #-16]!
+	stp x12,	x13,	[sp, #-16]!
+	stp x14,	x15,	[sp, #-16]!
+	stp x16,	x17,	[sp, #-16]!
+	stp x18,	x19,	[sp, #-16]!
+	stp x20,	x21,	[sp, #-16]!
+/* push q0-q31 on to the stack, need everything because parts of every register are volatile/corruptible */
+	stp q0,		q1,	[sp, #-32]!
+	stp q2,		q3,	[sp, #-32]!
+	stp q4,		q5,	[sp, #-32]!
+	stp q6,		q7,	[sp, #-32]!
+	stp q8,		q9,	[sp, #-32]!
+	stp q10,	q11,	[sp, #-32]!
+	stp q12,	q13,	[sp, #-32]!
+	stp q14,	q15,	[sp, #-32]!
+	stp q16,	q17,	[sp, #-32]!
+	stp q18,	q19,	[sp, #-32]!
+	stp q20,	q21,	[sp, #-32]!
+	stp q22,	q23,	[sp, #-32]!
+	stp q24,	q25,	[sp, #-32]!
+	stp q26,	q27,	[sp, #-32]!
+	stp q28,	q29,	[sp, #-32]!
+	stp q30,	q31,	[sp, #-32]!
+/* get exception LR for PC and spsr */
+	mrs x0, ELR_EL1
+	mrs x1, SPSR_EL1
+/* push pc and spsr */
+	stp x0,		x1,	[sp, #-16]!
+	mrs x0, FPSR
+	mrs x1, FPCR
+.endm
+/* Must match inverse order of .push_interrupt_context */
+.macro pop_interrupt_context
+	ldp x0,		x1,	[sp], #16
+	msr FPCR, x1
+	msr FPSR, x0
+/* pop pc and spsr */
+/* restore exception LR for PC and spsr */
+	msr SPSR_EL1, x1
+	msr ELR_EL1, x0
+/* pop q0-q31 */
+	ldp q30,	q31,	[sp], #32
+	ldp q28,	q29,	[sp], #32
+	ldp q26,	q27,	[sp], #32
+	ldp q24,	q25,	[sp], #32
+	ldp q22,	q23,	[sp], #32
+	ldp q20,	q21,	[sp], #32
+	ldp q18,	q19,	[sp], #32
+	ldp q16,	q17,	[sp], #32
+	ldp q14,	q15,	[sp], #32
+	ldp q12,	q13,	[sp], #32
+	ldp q10,	q11,	[sp], #32
+	ldp q8,		q9,	[sp], #32
+	ldp q6,		q7,	[sp], #32
+	ldp q4,		q5,	[sp], #32
+	ldp q2,		q3,	[sp], #32
+	ldp q0,		q1,	[sp], #32
+/* pop x1-x21 */
+	ldp x20,	x21,	[sp], #16
+	ldp x18,	x19,	[sp], #16
+	ldp x16,	x17,	[sp], #16
+	ldp x14,	x15,	[sp], #16
+	ldp x12,	x13,	[sp], #16
+	ldp x10,	x11,	[sp], #16
+	ldp x8,		x9,	[sp], #16
+	ldp x6,		x7,	[sp], #16
+	ldp x4,		x5,	[sp], #16
+	ldp x2,		x3,	[sp], #16
+	ldp lr,		x1,	[sp], #16
+	/* Must clear reservations here to ensure consistency with atomic operations */
+	clrex
+.endm
+_AArch64_Exception_interrupt_nest:
+/* basic execution template:
+save volatile regs on interrupt stack
+execute irq handler
+restore volatile regs from interrupt stack
+eret
+/* push interrupt context */
+	push_interrupt_context
+/* jump into the handler, ignore return value */
+	bl .AArch64_Interrupt_Handler
+/* sp should be where it was pre-handler (pointing at the exception frame)
+ * or something has leaked stack space */
+/* pop interrupt context */
+	pop_interrupt_context
+/* return to vector for final cleanup */
+	ret
+_AArch64_Exception_interrupt_no_nest:
+/* RTEMS ARM impl does this:
+save volatile registers on thread stack(some x, all q, ELR, etc.)
+switch to interrupt stack
+execute interrupt handler
+switch to thread stack
+call thread dispatch
+restore volatile registers from thread stack
+eret
+AArch64 implementation does:
+exception handler dispatch saves x0, lr on stack
+exception handler dispatch calls actual handler
+exception handler dispatch pops x0, lr from stack
+eret
+actual handler:
+ret to dispatch
+	/* Switch to interrupt stack, interrupt dispatch may enable interrupts causing nesting */
+	msr	spsel, #0
+	/* Switch back to thread stack, interrupt dispatch should disable interrupts before returning */
+	msr	spsel, #1
+	 * Check thread dispatch necessary, ISR dispatch disable and thread
+	 * dispatch disable level.
+	cmp	x0, #0
+	bne	.Lno_need_thread_dispatch
+	bl .AArch64_Perform_Thread_Dispatch
+.Lno_need_thread_dispatch:
+	ret
diff --git a/cpukit/score/cpu/aarch64/aarch64-thread-idle.c b/cpukit/score/cpu/aarch64/aarch64-thread-idle.c
index 0000000000..2044cde94d
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/aarch64-thread-idle.c
@@ -0,0 +1,48 @@
+ *  @file
+ *  @brief CPU Thread Idle Body
+ * are met:
+#endif
+void *_CPU_Thread_Idle_body( uintptr_t ignored )
+  while ( true ) {
+    __asm__ volatile ("wfi");
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index 0000000000..1ef1847d70
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -0,0 +1,196 @@
+ * @file
+ * @brief AArch64 architecture support implementation.
+ * are met:
+#endif
+#include <rtems/score/assert.h>
+#include <rtems/score/thread.h>
+#include <rtems/score/tls.h>
+  RTEMS_STATIC_ASSERT(
+    offsetof( Context_Control, register_d8 ) == AARCH64_CONTEXT_CONTROL_D8_OFFSET,
+    AARCH64_CONTEXT_CONTROL_D8_OFFSET
+#endif
+    offsetof( Context_Control, thread_id )
+      == AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET,
+    AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET
+    offsetof( Context_Control, isr_dispatch_disable )
+      == AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE,
+    AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE
+#ifdef RTEMS_SMP
+    offsetof( Context_Control, is_executing )
+      == AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET,
+    AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET
+#endif
+RTEMS_STATIC_ASSERT(
+  sizeof( CPU_Exception_frame ) == AARCH64_EXCEPTION_FRAME_SIZE,
+  AARCH64_EXCEPTION_FRAME_SIZE
+  sizeof( CPU_Exception_frame ) % CPU_STACK_ALIGNMENT == 0,
+  CPU_Exception_frame_alignment
+  offsetof( CPU_Exception_frame, register_sp )
+    == AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET,
+  AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET
+  offsetof( CPU_Exception_frame, register_lr )
+    == AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET,
+  AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET
+  offsetof( CPU_Exception_frame, register_daif )
+    == AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET,
+  AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET
+  offsetof( CPU_Exception_frame, register_syndrome )
+    == AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET,
+  AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET
+  offsetof( CPU_Exception_frame, vector )
+    == AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET,
+  AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET
+  offsetof( CPU_Exception_frame, register_fpsr )
+    == AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET,
+  AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET
+  offsetof( CPU_Exception_frame, register_q0 )
+    == AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET,
+  AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET
+void _CPU_Context_Initialize(
+  Context_Control *the_context,
+  void *stack_area_begin,
+  size_t stack_area_size,
+  uint64_t new_level,
+  void (*entry_point)( void ),
+  bool is_fp,
+  void *tls_area
+  (void) new_level;
+  the_context->register_sp = (uintptr_t) stack_area_begin + stack_area_size;
+  the_context->register_lr = (uintptr_t) entry_point;
+  the_context->isr_dispatch_disable = 0;
+  the_context->thread_id = (uintptr_t) tls_area;
+  if ( tls_area != NULL ) {
+    _TLS_TCB_at_area_begin_initialize( tls_area );
+void _CPU_ISR_Set_level( uint64_t level )
+  /* Set the mask bit if interrupts are disabled */
+  level = level ? AARCH64_PSTATE_I : 0;
+    "msr DAIF, %[level]\n"
+    : : [level] "r" (level)
+uint64_t _CPU_ISR_Get_level( void )
+  uint64_t level;
+    "mrs %[level], DAIF\n"
+    : [level] "=&r" (level)
+  return level & AARCH64_PSTATE_I;
+void _CPU_ISR_install_vector(
+  uint32_t         vector,
+  CPU_ISR_handler  new_handler,
+  CPU_ISR_handler *old_handler
+  /* Redirection table starts at the end of the vector table */
+  CPU_ISR_handler *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
+  CPU_ISR_handler current_handler = table [vector];
+  /* The current handler is now the old one */
+  if (old_handler != NULL) {
+    *old_handler = current_handler;
+  /* Write only if necessary to avoid writes to a maybe read-only memory */
+  if (current_handler != new_handler) {
+    table [vector] = new_handler;
+void _CPU_Initialize( void )
+  /* Do nothing */
diff --git a/cpukit/score/cpu/aarch64/cpu_asm.S b/cpukit/score/cpu/aarch64/cpu_asm.S
index 0000000000..0e1b803610
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/cpu_asm.S
@@ -0,0 +1,134 @@
+ * @file
+ * @brief AArch64 architecture context switch implementation.
+ * are met:
+#endif
+        .text
+ *  void _CPU_Context_switch( run_context, heir_context )
+ *  void _CPU_Context_restore( run_context, heir_context )
+ *  This routine performs a normal non-FP context.
+ *  X0 = run_context    X1 = heir_context
+ *  This function copies the current registers to where x0 points, then
+ *  restores the ones from where x1 points.
+#define reg_2 w2
+#else
+#define reg_2 x2
+#endif
+DEFINE_FUNCTION_AARCH64(_CPU_Context_switch)
+/* Start saving context */
+	GET_SELF_CPU_CONTROL	reg_2
+	ldr	x3, [x2, #PER_CPU_ISR_DISPATCH_DISABLE]
+	stp x19, x20, [x0]
+	stp x21, x22, [x0, #0x10]
+	stp x23, x24, [x0, #0x20]
+	stp x25, x26, [x0, #0x30]
+	stp x27, x28, [x0, #0x40]
+	stp fp,  lr,  [x0, #0x50]
+	mov x4,  sp
+	str x4,  [x0, #0x60]
+	add	x5, x0, #AARCH64_CONTEXT_CONTROL_D8_OFFSET
+	stp d8,  d9,  [x5]
+	stp d10, d11, [x5, #16]
+	stp d12, d13, [x5, #32]
+	stp d14, d15, [x5, #48]
+#endif
+	str	x3, [x0, #AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
+#ifdef RTEMS_SMP
+#error SMP not yet supported
+#endif
+/* Start restoring context */
+.L_restore:
+#if !defined(RTEMS_SMP) && defined(AARCH64_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE)
+	clrex
+#endif
+	ldr	x3, [x1, #AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET]
+	ldr	x4, [x1, #AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
+	add	x5, x1, #AARCH64_CONTEXT_CONTROL_D8_OFFSET
+	ldp d8,  d9,  [x5]
+	ldp d10, d11, [x5, #16]
+	ldp d12, d13, [x5, #32]
+	ldp d14, d15, [x5, #48]
+#endif
+	msr	TPIDR_EL0, x3
+	str	x4, [x2, #PER_CPU_ISR_DISPATCH_DISABLE]
+	ldp x19, x20, [x1]
+	ldp x21, x22, [x1, #0x10]
+	ldp x23, x24, [x1, #0x20]
+	ldp x25, x26, [x1, #0x30]
+	ldp x27, x28, [x1, #0x40]
+	ldp fp,  lr,  [x1, #0x50]
+	ldr x4,  [x1, #0x60]
+	mov sp,  x4
+	ret
+ *  void _CPU_Context_restore( new_context )
+ *  This function restores the registers from where x0 points.
+ *  It must match _CPU_Context_switch()
+DEFINE_FUNCTION_AARCH64(_CPU_Context_restore)
+        mov     x1, x0
+        b       .L_restore
diff --git a/cpukit/score/cpu/aarch64/include/libcpu/vectors.h b/cpukit/score/cpu/aarch64/include/libcpu/vectors.h
index 0000000000..81b1b910f2
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/include/libcpu/vectors.h
@@ -0,0 +1,100 @@
+ * @file
+ * @brief ARM AArch64 Exception API.
+ * are met:
+#ifndef LIBCPU_AARCH64_VECTORS_H
+#define LIBCPU_AARCH64_VECTORS_H
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/* VBAR, Vector Base Address Register, Security Extensions */
+static inline void
+*AArch64_get_vector_base_address(void)
+  void *base;
+    "mrs %[base], VBAR_EL1\n"
+    : [base] "=&r" (base)
+  return base;
+static inline void
+AArch64_set_vector_base_address(void *base)
+    "msr VBAR_EL1, %[base]\n"
+    : : [base] "r" (base)
+static inline void
+*AArch64_get_hyp_vector_base_address(void)
+  void *base;
+    "mrs %[base], VBAR_EL2\n"
+  return base;
+static inline void
+AArch64_set_hyp_vector_base_address(void *base)
+    "msr VBAR_EL2, %[base]\n"
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBCPU_AARCH64_VECTORS_H */
diff --git a/cpukit/score/cpu/aarch64/include/rtems/asm.h b/cpukit/score/cpu/aarch64/include/rtems/asm.h
index 0000000000..35bf533c8a
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/include/rtems/asm.h
@@ -0,0 +1,89 @@
+ * @file
+ * @brief AArch64 Assembler Support API
+ * This include file attempts to address the problems
+ * caused by incompatible flavors of assemblers and
+ * toolsets.  It primarily addresses variations in the
+ * use of leading underscores on symbols and the requirement
+ * that register names be preceded by a %.
+ * NOTE: The spacing in the use of these macros
+ *       is critical to them working as advertised.
+ * are met:
+#ifndef _RTEMS_ASM_H
+#define _RTEMS_ASM_H
+ *  Indicate we are in an assembly file and get the basic CPU definitions.
+#ifndef ASM
+#define ASM
+#endif
+#include <rtems/score/percpu.h>
+ * @defgroup RTEMSScoreCPUAArch64ASM AArch64 Assembler Support
+ *  Following must be tailor for a particular flavor of the C compiler.
+ *  They may need to put underscores in front of the symbols.
+#define FUNCTION_ENTRY(name) \
+  .align 8; \
+  .globl name; \
+  .type name, %function; \
+  name:
+#define FUNCTION_END(name) \
+  .size name, . - name
+#define DEFINE_FUNCTION_AARCH64(name) \
+  .align 8 ; .globl name ; name: ; .globl name ## _aarch64 ; name ## _aarch64:
+.macro GET_SELF_CPU_CONTROL REG
+	ldr	\REG, =_Per_CPU_Information
+.endm
+#endif /* _RTEMS_ASM_H */
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/aarch64.h b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64.h
index 0000000000..76bbd813c1
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64.h
@@ -0,0 +1,83 @@
+ * @file
+ * @brief ARM AArch64 Assembler Support API
+ * are met:
+#ifndef _RTEMS_SCORE_AARCH64_H
+#define _RTEMS_SCORE_AARCH64_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSScoreCPUAArch64
+#if defined(__LP64__)
+  #define CPU_MODEL_NAME "AArch64-LP64"
+  #define AARCH64_MULTILIB_ARCH_V8
+#elif defined(__ILP32__)
+  #define CPU_MODEL_NAME "AArch64-ILP32"
+  #define AARCH64_MULTILIB_ARCH_V8_ILP32
+#endif
+#define AARCH64_MULTILIB_HAS_WFI
+#define AARCH64_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE
+#define AARCH64_MULTILIB_HAS_BARRIER_INSTRUCTIONS
+#define AARCH64_MULTILIB_HAS_CPACR
+#define AARCH64_MULTILIB_CACHE_LINE_MAX_64
+#if defined(__ARM_NEON)
+  #define AARCH64_MULTILIB_VFP
+#else
+  #error "FPU support not implemented"
+#endif
+ *  Define the name of the CPU family.
+#define CPU_NAME "AArch64"
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_AARCH64_H */
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index 0000000000..7a381f7300
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -0,0 +1,549 @@
+ * @file
+ * @brief AArch64 Architecture Support API
+ * are met:
+#ifndef _RTEMS_SCORE_CPU_H
+#define _RTEMS_SCORE_CPU_H
+#include <rtems/score/basedefs.h>
+#if defined(RTEMS_PARAVIRT)
+#include <rtems/score/paravirt.h>
+#endif
+#include <rtems/score/aarch64.h>
+#include <libcpu/vectors.h>
+ * @name Program State Registers
+#define AARCH64_PSTATE_N (1LL << 31)
+#define AARCH64_PSTATE_Z (1LL << 30)
+#define AARCH64_PSTATE_C (1LL << 29)
+#define AARCH64_PSTATE_V (1LL << 28)
+#define AARCH64_PSTATE_D (1LL << 9)
+#define AARCH64_PSTATE_A (1LL << 8)
+#define AARCH64_PSTATE_I (1LL << 7)
+#define AARCH64_PSTATE_F (1LL << 6)
+ *  AArch64 uses the PIC interrupt model.
+#define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
+#define CPU_ISR_PASSES_FRAME_POINTER FALSE
+#define CPU_HARDWARE_FP FALSE
+#define CPU_SOFTWARE_FP FALSE
+#define CPU_ALL_TASKS_ARE_FP FALSE
+#define CPU_IDLE_TASK_IS_FP FALSE
+#define CPU_USE_DEFERRED_FP_SWITCH FALSE
+#define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
+#define CPU_STACK_GROWS_UP FALSE
+#if defined(AARCH64_MULTILIB_CACHE_LINE_MAX_64)
+  #define CPU_CACHE_LINE_BYTES 64
+#else
+  #define CPU_CACHE_LINE_BYTES 32
+#endif
+#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
+#define CPU_MODES_INTERRUPT_MASK 0x1
+#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
+#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
+#define CPU_STACK_MINIMUM_SIZE (1024 * 10)
+/* This could be either 4 or 8, depending on the ABI in use.
+ * Could also use __LP64__ or __ILP32__ */
+/* AAPCS64, section 5.1, Fundamental Data Types */
+#define CPU_SIZEOF_POINTER __SIZEOF_POINTER__
+#define CPU_ALIGNMENT 16
+#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
+/* AAPCS64, section 6.2.2, Stack constraints at a public interface */
+#define CPU_STACK_ALIGNMENT 16
+#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
+#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
+#define CPU_USE_LIBC_INIT_FINI_ARRAY TRUE
+#define CPU_MAXIMUM_PROCESSORS 32
+#define AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET 112
+  #define AARCH64_CONTEXT_CONTROL_D8_OFFSET 120
+#endif
+#define AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 104
+#ifdef RTEMS_SMP
+  #if defined(AARCH64_MULTILIB_VFP)
+    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
+  #else
+    #define AARCH64_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
+  #endif
+#endif
+#define AARCH64_EXCEPTION_FRAME_SIZE 848
+#define AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET 248
+#define AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET 240
+#define AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET 264
+#define AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET 280
+#define AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET 296
+#define AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET 312
+#define AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET 336
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif
+typedef unsigned __int128 uint128_t;
+typedef struct {
+  uint64_t register_x19;
+  uint64_t register_x20;
+  uint64_t register_x21;
+  uint64_t register_x22;
+  uint64_t register_x23;
+  uint64_t register_x24;
+  uint64_t register_x25;
+  uint64_t register_x26;
+  uint64_t register_x27;
+  uint64_t register_x28;
+  uint64_t register_fp;
+  uint64_t register_lr;
+  uint64_t register_sp;
+  uint64_t isr_dispatch_disable;
+  uint64_t thread_id;
+  uint64_t register_d8;
+  uint64_t register_d9;
+  uint64_t register_d10;
+  uint64_t register_d11;
+  uint64_t register_d12;
+  uint64_t register_d13;
+  uint64_t register_d14;
+  uint64_t register_d15;
+#endif
+#ifdef RTEMS_SMP
+  volatile bool is_executing;
+#endif
+} Context_Control;
+static inline void _AARCH64_Data_memory_barrier( void )
+  __asm__ volatile ( "dmb LD" : : : "memory" );
+static inline void _AARCH64_Data_synchronization_barrier( void )
+  __asm__ volatile ( "dsb LD" : : : "memory" );
+static inline void _AARCH64_Instruction_synchronization_barrier( void )
+  __asm__ volatile ( "isb" : : : "memory" );
+void _CPU_ISR_Set_level( uint64_t level );
+uint64_t _CPU_ISR_Get_level( void );
+#if defined(AARCH64_DISABLE_INLINE_ISR_DISABLE_ENABLE)
+uint64_t AArch64_interrupt_disable( void );
+void AArch64_interrupt_enable( uint64_t level );
+void AArch64_interrupt_flash( uint64_t level );
+#else
+static inline uint64_t AArch64_interrupt_disable( void )
+  uint64_t level = _CPU_ISR_Get_level();
+    "msr DAIFSet, #0x2\n"
+  return level;
+static inline void AArch64_interrupt_enable( uint64_t level )
+static inline void AArch64_interrupt_flash( uint64_t level )
+  AArch64_interrupt_enable(level);
+  AArch64_interrupt_disable();
+#endif  /* !AARCH64_DISABLE_INLINE_ISR_DISABLE_ENABLE */
+#define _CPU_ISR_Disable( _isr_cookie ) \
+  do { \
+    _isr_cookie = AArch64_interrupt_disable(); \
+  } while (0)
+#define _CPU_ISR_Enable( _isr_cookie )  \
+  AArch64_interrupt_enable( _isr_cookie )
+#define _CPU_ISR_Flash( _isr_cookie ) \
+  AArch64_interrupt_flash( _isr_cookie )
+RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint64_t level )
+  return ( level & AARCH64_PSTATE_I ) == 0;
+  bool is_fp,
+  void *tls_area
+#define _CPU_Context_Get_SP( _context ) \
+  (_context)->register_sp
+#ifdef RTEMS_SMP
+  static inline bool _CPU_Context_Get_is_executing(
+    const Context_Control *context
+    return context->is_executing;
+  static inline void _CPU_Context_Set_is_executing(
+    Context_Control *context,
+    bool is_executing
+    context->is_executing = is_executing;
+#endif
+#define _CPU_Context_Restart_self( _the_context ) \
+   _CPU_Context_restore( (_the_context) );
+#define _CPU_Context_Initialize_fp( _destination ) \
+  do { \
+    *(*(_destination)) = _CPU_Null_fp_context; \
+  } while (0)
+#define _CPU_Fatal_halt( _source, _err )    \
+   do {                                     \
+     uint64_t _level;                       \
+     uint32_t _error = _err;                \
+     _CPU_ISR_Disable( _level );            \
+     (void) _level;                         \
+     __asm__ volatile ("mov x0, %0\n"       \
+                   : "=r" (_error)          \
+                   : "0" (_error)           \
+                   : "x0" );                \
+     while (1);                             \
+   } while (0);
+ * @brief CPU initialization.
+void _CPU_Initialize( void );
+typedef void ( *CPU_ISR_handler )( void );
+  uint32_t         vector,
+ * @brief CPU switch context.
+void _CPU_Context_switch( Context_Control *run, Context_Control *heir );
+void _CPU_Context_restore( Context_Control *new_context )
+  RTEMS_NO_RETURN;
+#ifdef RTEMS_SMP
+  uint32_t _CPU_SMP_Initialize( void );
+  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
+  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
+  void _CPU_SMP_Prepare_start_multitasking( void );
+  static inline uint32_t _CPU_SMP_Get_current_processor( void )
+    uint32_t mpidr;
+      "mrs %[mpidr], mpidr_el1\n"
+      : [mpidr] "=&r" (mpidr)
+    return mpidr & 0xffU;
+  void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
+  static inline void _AARCH64_Send_event( void )
+    __asm__ volatile ( "sev" : : : "memory" );
+  static inline void _AARCH64_Wait_for_event( void )
+    __asm__ volatile ( "wfe" : : : "memory" );
+  static inline void _CPU_SMP_Processor_event_broadcast( void )
+    _AARCH64_Data_synchronization_barrier();
+    _AARCH64_Send_event();
+  static inline void _CPU_SMP_Processor_event_receive( void )
+    _AARCH64_Wait_for_event();
+    _AARCH64_Data_memory_barrier();
+#endif
+static inline uint32_t CPU_swap_u32( uint32_t value )
+  uint32_t tmp = value; /* make compiler warnings go away */
+  __asm__ volatile ("EOR %1, %0, %0, ROR #16\n"
+                "BIC %1, %1, #0xff0000\n"
+                "MOV %0, %0, ROR #8\n"
+                "EOR %0, %0, %1, LSR #8\n"
+                : "=r" (value), "=r" (tmp)
+                : "0" (value), "1" (tmp));
+  return value;
+static inline uint16_t CPU_swap_u16( uint16_t value )
+  return (uint16_t) (((value & 0xffU) << 8) | ((value >> 8) & 0xffU));
+typedef uint32_t CPU_Counter_ticks;
+uint32_t _CPU_Counter_frequency( void );
+CPU_Counter_ticks _CPU_Counter_read( void );
+static inline CPU_Counter_ticks _CPU_Counter_difference(
+  CPU_Counter_ticks second,
+  CPU_Counter_ticks first
+  return second - first;
+void *_CPU_Thread_Idle_body( uintptr_t ignored );
+typedef enum {
+  AARCH64_EXCEPTION_SP0_SYNCHRONOUS = 0,
+  AARCH64_EXCEPTION_SP0_IRQ = 1,
+  AARCH64_EXCEPTION_SP0_FIQ = 2,
+  AARCH64_EXCEPTION_SP0_SERROR = 3,
+  AARCH64_EXCEPTION_SPx_SYNCHRONOUS = 4,
+  AARCH64_EXCEPTION_SPx_IRQ = 5,
+  AARCH64_EXCEPTION_SPx_FIQ = 6,
+  AARCH64_EXCEPTION_SPx_SERROR = 7,
+  AARCH64_EXCEPTION_LEL64_SYNCHRONOUS = 8,
+  AARCH64_EXCEPTION_LEL64_IRQ = 9,
+  AARCH64_EXCEPTION_LEL64_FIQ = 10,
+  AARCH64_EXCEPTION_LEL64_SERROR = 11,
+  AARCH64_EXCEPTION_LEL32_SYNCHRONOUS = 12,
+  AARCH64_EXCEPTION_LEL32_IRQ = 13,
+  AARCH64_EXCEPTION_LEL32_FIQ = 14,
+  AARCH64_EXCEPTION_LEL32_SERROR = 15,
+  MAX_EXCEPTIONS = 16,
+  AARCH64_EXCEPTION_MAKE_ENUM_64_BIT = 0xffffffffffffffff
+} AArch64_symbolic_exception_name;
+#define VECTOR_POINTER_OFFSET 0x78
+#define VECTOR_ENTRY_SIZE 0x80
+void _AArch64_Exception_interrupt_no_nest( void );
+void _AArch64_Exception_interrupt_nest( void );
+static inline void* AArch64_set_exception_handler(
+  AArch64_symbolic_exception_name exception,
+  void (*handler)(void)
+  // get current table address
+  char *vbar = (char*)AArch64_get_vector_base_address();
+  // calculate address of vector to be replaced
+  char *cvector_address = vbar + VECTOR_ENTRY_SIZE * exception + VECTOR_POINTER_OFFSET;
+  // get current vector pointer
+  void (**vector_address)(void) = (void(**)(void))cvector_address;
+  void (*current_vector_pointer)(void);
+  current_vector_pointer = *vector_address;
+  // replace vector pointer
+  *vector_address = handler;
+  // return now-previous vector pointer
+  return (void*)current_vector_pointer;
+typedef struct {
+  uint64_t register_x0;
+  uint64_t register_x1;
+  uint64_t register_x2;
+  uint64_t register_x3;
+  uint64_t register_x4;
+  uint64_t register_x5;
+  uint64_t register_x6;
+  uint64_t register_x7;
+  uint64_t register_x8;
+  uint64_t register_x9;
+  uint64_t register_x10;
+  uint64_t register_x11;
+  uint64_t register_x12;
+  uint64_t register_x13;
+  uint64_t register_x14;
+  uint64_t register_x15;
+  uint64_t register_x16;
+  uint64_t register_x17;
+  uint64_t register_x18;
+  void *register_lr;
+  uint32_t _register_lr_top;
+#endif
+  void *register_pc;
+  uint32_t _register_pc_top;
+#endif
+  uint64_t register_daif;
+  uint64_t register_cpsr;
+  uint64_t register_syndrome;
+  uint64_t register_fault_address;
+  AArch64_symbolic_exception_name vector;
+  uint64_t reserved_for_stack_alignment;
+  uint64_t register_fpsr;
+  uint64_t register_fpcr;
+  uint128_t register_q0;
+  uint128_t register_q1;
+  uint128_t register_q2;
+  uint128_t register_q3;
+  uint128_t register_q4;
+  uint128_t register_q5;
+  uint128_t register_q6;
+  uint128_t register_q7;
+  uint128_t register_q8;
+  uint128_t register_q9;
+  uint128_t register_q10;
+  uint128_t register_q11;
+  uint128_t register_q12;
+  uint128_t register_q13;
+  uint128_t register_q14;
+  uint128_t register_q15;
+  uint128_t register_q16;
+  uint128_t register_q17;
+  uint128_t register_q18;
+  uint128_t register_q19;
+  uint128_t register_q20;
+  uint128_t register_q21;
+  uint128_t register_q22;
+  uint128_t register_q23;
+  uint128_t register_q24;
+  uint128_t register_q25;
+  uint128_t register_q26;
+  uint128_t register_q27;
+  uint128_t register_q28;
+  uint128_t register_q29;
+  uint128_t register_q30;
+  uint128_t register_q31;
+} CPU_Exception_frame;
+void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
+void _AArch64_Exception_default( CPU_Exception_frame *frame );
+/** Type that can store a 32-bit integer or a pointer. */
+typedef uintptr_t CPU_Uint32ptr;
+#ifdef __cplusplus
+#endif
+#endif /* ASM */
+#endif /* _RTEMS_SCORE_CPU_H */
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
index 0000000000..ed8091d73c
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
@@ -0,0 +1,42 @@
+ * @file
+ * @brief AArch64 Atomics support
+ * are met:
+#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
+#define _RTEMS_SCORE_ATOMIC_CPU_H
+#include <rtems/score/cpustdatomic.h>
+#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
index 0000000000..4c3da6794a
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
@@ -0,0 +1,83 @@
+ * @file
+ * @brief CPU Port Implementation API
+ * are met:
+#ifndef _RTEMS_SCORE_CPUIMPL_H
+#define _RTEMS_SCORE_CPUIMPL_H
+ * @defgroup RTEMSScoreCPUAArch64 AArch64
+ * @brief ARM AArch64 Architecture Support
+#define CPU_PER_CPU_CONTROL_SIZE 0
+#define CPU_INTERRUPT_FRAME_SIZE 240
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif
+void _CPU_Context_volatile_clobber( uintptr_t pattern );
+void _CPU_Context_validate( uintptr_t pattern );
+RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal( void )
+  __asm__ volatile ( ".inst 0x0" );
+RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
+  __asm__ volatile ( "nop" );
+#ifdef __cplusplus
+#endif
+#endif /* ASM */
+#endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/spec/build/cpukit/cpuaarch64.yml b/spec/build/cpukit/cpuaarch64.yml
index 0000000000..4b1d0bf82d
--- /dev/null
+++ b/spec/build/cpukit/cpuaarch64.yml
@@ -0,0 +1,35 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2020 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by:
+- aarch64
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/libcpu
+  source:
+  - cpukit/score/cpu/arm/include/libcpu/vectors.h
+- destination: ${BSP_INCLUDEDIR}/rtems
+  source:
+  - cpukit/score/cpu/aarch64/include/rtems/asm.h
+- destination: ${BSP_INCLUDEDIR}/rtems/score
+  source:
+  - cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+  - cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
+  - cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
+  - cpukit/score/cpu/aarch64/include/rtems/score/aarch64.h
+links: []
+source:
+- cpukit/score/cpu/aarch64/cpu.c
+- cpukit/score/cpu/aarch64/cpu_asm.S
+- cpukit/score/cpu/aarch64/aarch64-context-validate.S
+- cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S
+- cpukit/score/cpu/aarch64/aarch64-thread-idle.c
+- cpukit/score/cpu/aarch64/aarch64-exception-default.c
+- cpukit/score/cpu/aarch64/aarch64-exception-default.S
+- cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
+- cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
+type: build
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index e3606dbdc8..f835cecb45 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -456,6 +456,8 @@ install:
   - cpukit/include/uuid/uuid.h
 install-path: ${BSP_LIBDIR}
 links:
+- role: build-dependency
+  uid: cpuaarch64
   uid: cpuarm
2.20.1
