Error while using the trace linker
Utkarsh Rai utkarsh.rai60 at gmail.com
Mon Sep 28 16:57:10 UTC 2020
Hello,
I am following the tracing example as mentioned in the docs
<https://docs.rtems.org/branches/master/user/tracing/examples.html> for
sparc/erc32 BSP.  When I run the "rtems-tld" command, I get the following
error - "error: /home/utkarsh/sandbox/bsps/sparc: Invalid RTEMS path"
My directory structure is -
|-$HOME- | - sandbox -|- bsps -  |-sparc
                                     | - rtems
                                     | - rsb
I have used the exact command as mentioned in the example with changes made
according to my installation from the top of the BSP installation
directory. The rtems-path in the fileio-trace.ini file is set to
"$HOME/sandbox/bsps/sparc".
I know I am making a very simple mistake but  just can't seem to put my
finger on it. Can someone point what is it that I am doing wrong?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200928/f3c6008f/attachment.html>
