New Build Sweeps
Joel Sherrill
joel at rtems.org
Tue Sep 29 17:19:13 UTC 2020
Hi
I am starting to do a sweep of all BSPs with various configure options and
build them back to back with autoconf and waf with the same options. I am
just doing a basic sweep now of SMP on/off and Debug on/off and reporting
issues as I spot them.
Overnight a build sweep completed which had test runs which were based on
similar combinations. Others should double check the build@ archives to see
that the duplicate test runs (autoconf followed by waf) did in fact pass
the same.
My intention is to vary more configure options through both build systems
and every BSP but will be building all tests on every variation. Obviously
the build time iwill be high but I hope this will help us build confidence.
Hopefully this will help us move forward.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200929/003aa9f0/attachment-0001.html>
