Purpose of rtems_device_driver?
Peter Dufault
dufault at hda.com
Tue Sep 29 18:01:18 UTC 2020
> On Sep 29, 2020, at 10:13 , Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Sep 29, 2020 at 8:54 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 29/09/2020 15:47, Sebastian Huber wrote:
> > On 29/09/2020 15:42, Joel Sherrill wrote:
> >> On Tue, Sep 29, 2020 at 8:37 AM Sebastian Huber
> >> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >> Hello,
> >> I work currently on the documentation of the IO Manager. What is the
> >> purpose of
> >> typedef rtems_status_code rtems_device_driver;
> >> For me this looks a bit like camouflage.
> >> No. It is a use of typedef to make the purpose of the method clear.
> >> You have nibbled at these for years. There were at least types for
> >> Classic Tasks, ASRs, and TSRs at one point.
> > Yes, the typedefs to void.
> >> If this is the last one, I'm not going to fight it. This isn't the
> >> hill I am
> >> going to die on.
> > I am not suggesting to remove them although I find these typedefs
> > pretty odd. I just look for some documentation text.
> What about this:
> * @ingroup RTEMSAPIClassicIO
> * @brief This type shall be used in device driver entry declarations and
> * definitions.
> * Device driver entries return an #rtems_status_code status code. This
> type
> * definition helps to document device driver entries in the source code.
> That's more than sufficient.
> Thanks.
This typedef is odd. Unless I'm missing a fine-point.
If the typedef is, and always will remain, "rtems_status_code" I would not use a typedef.
The RTEMS API documentation is moving to Doxygen (and more formally than that given Sebastian's ESA work). Using a typedef to indicate a function is part of a device driver as "documentation" is not a good idea.
When I've thought I needed a special return code in the past I've made the return code a "struct" so that it can't be used interchangeably with other return codes, even with casting, and so that you need to be *sure* you really want such a special return type. This probably pre-dates enabling aggressive warnings.
I haven't done this recently. Recently I've assumed that:
- Status codes are an integral type;
- Status codes of 0 always mean success.
Trying to pretend you need to compare a return to a special "success" #define that is 0 is pointless and error prone now-a-days IMHO.
If I really wanted a return code that was special I'd do something like:
typedef struct {
rtems_status_code status; /* Error return. */
int unused; /* Unused */
} rtems_device_driver;
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200929/2e9b7f69/attachment.bin>
