[PATCH v2 6/8] score: Add AArch64 port
Chris Johns
chrisj at rtems.org
Wed Sep 30 05:43:10 UTC 2020
On 29/9/20 9:37 pm, Sebastian Huber wrote:
> On 28/09/2020 17:24, Kinsey Moore wrote:
>> +/* TODO(kmoore) The current implementation here assumes that SP is not
>> misaligned */
> Maybe add a ticket for this TODO and reference it in the comment.
>> + .macro JUMP_HANDLER
>> + mov x0, #0x7f /* mask to use in BIC, lower 7 bits */
>> + bic x0, lr, x0 /* lr contains PC, mask off to the base of
>> the current vector */
>> + ldr x0, [x0, #0x78] /* load address from the last word in
>> the vector */
>> + blr x0 /* branch and link to address in x0, no reason to
>> save current LR since it has already been saved and current contents are junk */
>> + ldp x0, lr, [sp], #16 /* pop x0,lr from stack */
>> + eret /* return from exception */
> Some lines are longer than 79 characters. I spotted also // comments. I have
> nothing against // comments in general, but before we introduce them, it would
> be good to update the coding style.
It seems Kinsey wrote the code with C comments so lets say use just C comments ...
https://developer.arm.com/documentation/100933/0100/AArch64-exception-vector-table
