[PATCH] tests: Add and use <rtems/testopts.h>
Sebastian Huber
Wed Sep 30 05:55:23 UTC 2020
On 30/09/2020 07:52, Chris Johns wrote:
> On 29/9/20 11:31 pm, Sebastian Huber wrote:
>> Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of
>> test suites using the RTEMS test framework.
> Does this create another build variant?
Each build option creates variants.
> Why would I play with this option?
For normal tests runs you can use a verbosity of normal. If you need a
more detailed output, then you can set it to verbose. For example, in
case a regression ocurred.
