[PATCH 0/1] c-user: Generate I/O Manager documentation
Wed Sep 30 08:04:40 UTC 2020
On 29/09/2020 16:59, Sebastian Huber wrote:
> This is the first generated documentation of a manager. For the PDF
> output please have a look at:
> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
> Please review the layout.  I changed the layout to use definition lists
> instead of tables.  The benefit of definition lists is that the layout
> of longer text paragraphs is much nicer compared to tables (at least for
> the PDF output).
> Sebastian Huber (1):
>   c-user/io/directives.rst   | 550 ++++++++++++++++++-------------------
>   c-user/io/introduction.rst |  37 ++-
>   2 files changed, 295 insertions(+), 292 deletions(-)
The vertical spacing of the definition lists was a bit odd. In the Latex
enumitem package documentation there is a note that nested definition
lists with the "nextline" style are not supported.
I changed the formatting to use the .. rubric directive. Please have a
look at this PDF:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user-2.pdf
Only the IO Manager and Event Manager chapters use the new formatting.
