[PATCH] Entangle the C Program Heap initialization
Wed Sep 30 11:03:26 UTC 2020
Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
_Workspace_Area.  Introduce _Workspace_Malloc_initializer to have this
dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
application configuration.
 cpukit/Makefile.am                          |  3 +
 cpukit/include/rtems/confdefs/wkspace.h     |  3 +
 cpukit/include/rtems/malloc.h               |  2 +-
 cpukit/include/rtems/score/wkspacedata.h    | 26 +++++++
 cpukit/libcsupport/src/malloc_initialize.c  | 78 +++++++++------------
 cpukit/libcsupport/src/mallocheap.c         | 56 +++++++++++++++
 cpukit/score/src/wkspacemallocinitdefault.c | 44 ++++++++++++
 cpukit/score/src/wkspacemallocinitunified.c | 47 +++++++++++++
 spec/build/cpukit/librtemscpu.yml           |  3 +
 9 files changed, 217 insertions(+), 45 deletions(-)
 create mode 100644 cpukit/libcsupport/src/mallocheap.c
 create mode 100644 cpukit/score/src/wkspacemallocinitdefault.c
 create mode 100644 cpukit/score/src/wkspacemallocinitunified.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 2c35354e66..1f9124e175 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -176,6 +176,7 @@ librtemscpu_a_SOURCES += libcsupport/src/mallocdirtydefault.c
 librtemscpu_a_SOURCES += libcsupport/src/mallocextenddefault.c
 librtemscpu_a_SOURCES += libcsupport/src/mallocfreespace.c
 librtemscpu_a_SOURCES += libcsupport/src/mallocgetheapptr.c
+librtemscpu_a_SOURCES += libcsupport/src/mallocheap.c
 librtemscpu_a_SOURCES += libcsupport/src/mallocinfo.c
 librtemscpu_a_SOURCES += libcsupport/src/malloc_initialize.c
 librtemscpu_a_SOURCES += libcsupport/src/_malloc_r.c
@@ -1025,6 +1026,8 @@ librtemscpu_a_SOURCES += score/src/interr.c
 librtemscpu_a_SOURCES += score/src/isr.c
 librtemscpu_a_SOURCES += score/src/wkspace.c
 librtemscpu_a_SOURCES += score/src/wkspaceisunifieddefault.c
+librtemscpu_a_SOURCES += score/src/wkspacemallocinitdefault.c
+librtemscpu_a_SOURCES += score/src/wkspacemallocinitunified.c
 librtemscpu_a_SOURCES += score/src/wkstringduplicate.c
 librtemscpu_a_SOURCES += score/src/iobase64.c
 librtemscpu_a_SOURCES += score/src/ioprintf.c
diff --git a/cpukit/include/rtems/confdefs/wkspace.h b/cpukit/include/rtems/confdefs/wkspace.h
index 89d7c21b2a..d40194cbec 100644
--- a/cpukit/include/rtems/confdefs/wkspace.h
+++ b/cpukit/include/rtems/confdefs/wkspace.h
@@ -126,6 +126,9 @@ const uintptr_t _Workspace_Size = CONFIGURE_EXECUTIVE_RAM_SIZE;
 #ifdef CONFIGURE_UNIFIED_WORK_AREAS
   const bool _Workspace_Is_unified = true;
+  struct Heap_Control *( * const _Workspace_Malloc_initializer )( void ) =
+    _Workspace_Malloc_initialize_unified;
 #endif
 uint32_t rtems_minimum_stack_size = CONFIGURE_MINIMUM_TASK_STACK_SIZE;
diff --git a/cpukit/include/rtems/malloc.h b/cpukit/include/rtems/malloc.h
index 34bdbcb91e..13e94ac38a 100644
--- a/cpukit/include/rtems/malloc.h
+++ b/cpukit/include/rtems/malloc.h
@@ -43,7 +43,7 @@ extern "C" {
 extern Heap_Control *RTEMS_Malloc_Heap;
-void RTEMS_Malloc_Initialize(
+Heap_Control *RTEMS_Malloc_Initialize(
   const Memory_Information              *mem,
   Heap_Initialization_or_extend_handler  extend
diff --git a/cpukit/include/rtems/score/wkspacedata.h b/cpukit/include/rtems/score/wkspacedata.h
index 613a320dfe..fd6fd1c1cb 100644
--- a/cpukit/include/rtems/score/wkspacedata.h
+++ b/cpukit/include/rtems/score/wkspacedata.h
@@ -43,6 +43,8 @@
 extern "C" {
 #endif
+struct Heap_Control;
  * @addtogroup RTEMSScoreWorkspace
@@ -65,6 +67,30 @@ extern const uintptr_t _Workspace_Size;
 extern const bool _Workspace_Is_unified;
+ * @brief Initializes the C Program Heap separated from the RTEMS Workspace.
+ * @return Returns the heap control used for the C Program Heap.
+struct Heap_Control *_Workspace_Malloc_initialize_separate( void );
+ * @brief Initializes the C Program Heap so that it is unified with the RTEMS
+ * Workspace.
+struct Heap_Control *_Workspace_Malloc_initialize_unified( void );
+ * @brief This constant provides the C Program Heap initialization handler.
+ * This constant is defined by the application configuration option
+ * #CONFIGURE_UNIFIED_WORK_AREAS via <rtems/confdefs.h> or a default
+ * configuration.
+extern struct Heap_Control *( * const _Workspace_Malloc_initializer )( void );
 #ifdef __cplusplus
diff --git a/cpukit/libcsupport/src/malloc_initialize.c b/cpukit/libcsupport/src/malloc_initialize.c
index 0203e22411..fb0999df01 100644
--- a/cpukit/libcsupport/src/malloc_initialize.c
+++ b/cpukit/libcsupport/src/malloc_initialize.c
@@ -19,73 +19,63 @@
 #include <rtems/malloc.h>
-#include <rtems/sysinit.h>
 #include "malloc_p.h"
-Heap_Control *RTEMS_Malloc_Heap;
-static void _Malloc_Initialize( void )
-  RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
-RTEMS_SYSINIT_ITEM(
-  _Malloc_Initialize,
-  RTEMS_SYSINIT_MALLOC,
-  RTEMS_SYSINIT_ORDER_MIDDLE
 #ifdef RTEMS_NEWLIB
 static Heap_Control _Malloc_Heap;
-  if ( rtems_configuration_get_unified_work_area() ) {
-    RTEMS_Malloc_Heap = &_Workspace_Area;
-  } else {
-    Heap_Control                          *heap;
-    Heap_Initialization_or_extend_handler  init_or_extend;
-    uintptr_t                              page_size;
-    size_t                                 i;
+  Heap_Control                          *heap;
+  Heap_Initialization_or_extend_handler  init_or_extend;
+  uintptr_t                              page_size;
+  size_t                                 i;
-    heap = &_Malloc_Heap;
-    RTEMS_Malloc_Heap = heap;
-    init_or_extend = _Heap_Initialize;
-    page_size = CPU_HEAP_ALIGNMENT;
+  heap = &_Malloc_Heap;
+  RTEMS_Malloc_Heap = heap;
+  init_or_extend = _Heap_Initialize;
+  page_size = CPU_HEAP_ALIGNMENT;
-    for (i = 0; i < _Memory_Get_count( mem ); ++i) {
-      Memory_Area *area;
-      uintptr_t    space_available;
+  for (i = 0; i < _Memory_Get_count( mem ); ++i) {
+    Memory_Area *area;
+    uintptr_t    space_available;
-      area = _Memory_Get_area( mem, i );
-      space_available = ( *init_or_extend )(
-        heap,
-        _Memory_Get_free_begin( area ),
-        _Memory_Get_free_size( area ),
-        page_size
+    area = _Memory_Get_area( mem, i );
+    space_available = ( *init_or_extend )(
+      heap,
+      _Memory_Get_free_begin( area ),
+      _Memory_Get_free_size( area ),
+      page_size
-      if ( space_available > 0 ) {
-        _Memory_Consume( area, _Memory_Get_free_size( area ) );
-        init_or_extend = extend;
+    if ( space_available > 0 ) {
+      _Memory_Consume( area, _Memory_Get_free_size( area ) );
+      init_or_extend = extend;
-    if ( init_or_extend == _Heap_Initialize ) {
-      _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
+  if ( init_or_extend == _Heap_Initialize ) {
+    _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
+  return heap;
 #else
   /* FIXME: Dummy function */
+  return NULL;
 #endif
+Heap_Control *_Workspace_Malloc_initialize_separate( void )
+  return RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
diff --git a/cpukit/libcsupport/src/mallocheap.c b/cpukit/libcsupport/src/mallocheap.c
new file mode 100644
index 0000000000..006362f209
--- /dev/null
+++ b/cpukit/libcsupport/src/mallocheap.c
@@ -0,0 +1,56 @@
+ * @file
+ * @ingroup MallocSupport
+ * @brief This source file provides the C Program Heap control along with the
+ *   system initialization handler.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/malloc.h>
+#include <rtems/sysinit.h>
+#include <rtems/score/wkspacedata.h>
+Heap_Control *RTEMS_Malloc_Heap;
+static void _Malloc_Initialize( void )
+  RTEMS_Malloc_Heap = ( *_Workspace_Malloc_initializer )();
+RTEMS_SYSINIT_ITEM(
+  _Malloc_Initialize,
+  RTEMS_SYSINIT_MALLOC,
+  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/score/src/wkspacemallocinitdefault.c b/cpukit/score/src/wkspacemallocinitdefault.c
index 0000000000..586c3eef7c
--- /dev/null
+++ b/cpukit/score/src/wkspacemallocinitdefault.c
@@ -0,0 +1,44 @@
+ * @file
+ * @ingroup RTEMSScoreWorkspace
+ * @brief This source file provides the default definition of
+ * _Workspace_Malloc_initializer.
+ * are met:
+#endif
+struct Heap_Control *( * const _Workspace_Malloc_initializer )( void ) =
+  _Workspace_Malloc_initialize_separate;
diff --git a/cpukit/score/src/wkspacemallocinitunified.c b/cpukit/score/src/wkspacemallocinitunified.c
index 0000000000..d90956c051
--- /dev/null
+++ b/cpukit/score/src/wkspacemallocinitunified.c
@@ -0,0 +1,47 @@
+ * @file
+ * @brief This source file provides the implementation of
+ *   _Workspace_Malloc_initialize_unified().
+ * are met:
+#endif
+#include <rtems/score/wkspace.h>
+  return &_Workspace_Area;
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 21dc239b1b..2322e33996 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -669,6 +669,7 @@ source:
 - cpukit/libcsupport/src/mallocextenddefault.c
 - cpukit/libcsupport/src/mallocfreespace.c
 - cpukit/libcsupport/src/mallocgetheapptr.c
+- cpukit/libcsupport/src/mallocheap.c
 - cpukit/libcsupport/src/mallocinfo.c
 - cpukit/libcsupport/src/malloc_initialize.c
 - cpukit/libcsupport/src/_malloc_r.c
@@ -1575,6 +1576,8 @@ source:
 - cpukit/score/src/watchdogtimeslicedefault.c
 - cpukit/score/src/wkspace.c
 - cpukit/score/src/wkspaceisunifieddefault.c
+- cpukit/score/src/wkspacemallocinitdefault.c
+- cpukit/score/src/wkspacemallocinitunified.c
 - cpukit/score/src/wkstringduplicate.c
 target: rtemscpu
 type: build
2.26.2
