[PATCH] rtems: Canonicalize name and id check
Sebastian Huber
Wed Sep 30 14:27:10 UTC 2020
Check the name followed by the id check in all create directives.
Compare pointers against NULL. Fix formatting.
cpukit/rtems/src/msgqconstruct.c | 8 +-
cpukit/rtems/src/partcreate.c | 9 +-
cpukit/rtems/src/regioncreate.c | 9 +-
cpukit/rtems/src/taskconstruct.c | 10 +-
.../validation/tc-message-construct-errors.c | 144 ++++++-------
.../validation/tc-task-construct-errors.c | 192 +++++++++---------
6 files changed, 190 insertions(+), 182 deletions(-)
diff --git a/cpukit/rtems/src/msgqconstruct.c b/cpukit/rtems/src/msgqconstruct.c
index 61d0472e7c..82f6d2dfad 100644
--- a/cpukit/rtems/src/msgqconstruct.c
+++ b/cpukit/rtems/src/msgqconstruct.c
@@ -63,14 +63,14 @@ rtems_status_code _Message_queue_Create(
bool is_global;
#endif
- if ( id == NULL ) {
- return RTEMS_INVALID_ADDRESS;
if ( !rtems_is_name_valid( config->name ) ) {
return RTEMS_INVALID_NAME;
+ if ( id == NULL ) {
+ return RTEMS_INVALID_ADDRESS;
if ( config->maximum_pending_messages == 0 ) {
return RTEMS_INVALID_NUMBER;
diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
index 9aa5e80bf1..4f43743f98 100644
--- a/cpukit/rtems/src/partcreate.c
+++ b/cpukit/rtems/src/partcreate.c
@@ -38,14 +38,17 @@ rtems_status_code rtems_partition_create(
Partition_Control *the_partition;
- if ( !rtems_is_name_valid( name ) )
+ if ( !rtems_is_name_valid( name ) ) {
- if ( !starting_address )
- if ( !id )
+ if ( starting_address == NULL ) {
if ( length == 0 )
return RTEMS_INVALID_SIZE;
diff --git a/cpukit/rtems/src/regioncreate.c b/cpukit/rtems/src/regioncreate.c
index de8f165fe7..99752193ce 100644
--- a/cpukit/rtems/src/regioncreate.c
+++ b/cpukit/rtems/src/regioncreate.c
@@ -38,14 +38,17 @@ rtems_status_code rtems_region_create(
rtems_status_code return_status;
Region_Control *the_region;
- if ( !id )
the_region = _Region_Allocate();
diff --git a/cpukit/rtems/src/taskconstruct.c b/cpukit/rtems/src/taskconstruct.c
index 76ef8ce5d6..9b1fdec3ae 100644
--- a/cpukit/rtems/src/taskconstruct.c
+++ b/cpukit/rtems/src/taskconstruct.c
@@ -96,11 +96,13 @@ rtems_status_code _RTEMS_tasks_Create(
RTEMS_API_Control *api;
ASR_Information *asr;
- if ( !id )
- if ( !rtems_is_name_valid( config->name ) )
+ if ( !rtems_is_name_valid( config->name ) ) {
* Core Thread Initialize insures we get the minimum amount of
diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
index 2dad91dae4..69378e27c7 100644
--- a/testsuites/validation/tc-message-construct-errors.c
+++ b/testsuites/validation/tc-message-construct-errors.c
@@ -943,149 +943,149 @@ static const uint8_t RtemsMessageReqConstructErrors_TransitionMap[][ 1 ] = {
RtemsMessageReqConstructErrors_Post_Status_InvAddress
- RtemsMessageReqConstructErrors_Post_Status_InvAddress
+ RtemsMessageReqConstructErrors_Post_Status_InvName
diff --git a/testsuites/validation/tc-task-construct-errors.c b/testsuites/validation/tc-task-construct-errors.c
index 615186e092..981bacb07b 100644
--- a/testsuites/validation/tc-task-construct-errors.c
+++ b/testsuites/validation/tc-task-construct-errors.c
@@ -1171,197 +1171,197 @@ static const uint8_t RtemsTaskReqConstructErrors_TransitionMap[][ 1 ] = {
RtemsTaskReqConstructErrors_Post_Status_InvAddress
- RtemsTaskReqConstructErrors_Post_Status_InvAddress
+ RtemsTaskReqConstructErrors_Post_Status_InvName
2.26.2
