[libbsd] How to install machine header files?
    Chris Johns
    chrisj at rtems.org
    Thu Apr  1 04:24:30 UTC 2021
On 1/4/21 6:37 am, Jan.Sommer at dlr.de wrote:
> Hello,
> I stumbled upon some include path problems in libbsd while looking at Chris' ptpd port and I am not sure what is the recommended way to solve it.
> It starts with "freebsd/sys/sys/bus.h" including "machine/_bus.h".
> Currently, this will be the one from within "rtemsbd" which will redirect to "rtemsbsd/include/machine/bus.h" which is amd64 specific.
> For the pc686 BSP this will create a compile error for applications which include "<sys/bus.h>".
OK.
> I tried to solve it by removing the "_bus.h" in rtemsbsd and installing the correct one from "freebsd/sys/i386/include/machine/_bus.h", but I am not sure how to tell waf to install the file.
> Is there a way to add a single architecture specific header to the install headers?
Yes ....
https://git.rtems.org/rtems-libbsd/tree/libbsd.py#n111
https://git.rtems.org/rtems-libbsd/tree/libbsd.py#n2903
> I could add a corresponding path and wildcard to the "header-paths" in libbsd.py, but I am not sure if this is the right place.
I think the PCI module is the place to handle this. I am sorry but I cannot see
the issue clear at the moment and I cannot invest time performing a build.
The addCPUDependentFreeBSDHeaderFiles() on line 2931 of libbsd.py in the PCI
module looks a little suspect because there is no list of archs provided. Could
the issue be as simple as the list of archs is not there and the list is empty?
