[PATCH rtems-docs v2 1/2] Added FAQ page
Gedare Bloom
gedare at rtems.org
Fri Apr 2 19:25:45 UTC 2021
On Fri, Apr 2, 2021 at 12:19 PM Ayushman Mishra
<ayushvidushi01 at gmail.com> wrote:
> user/bld/index.rst | 2 +
> user/overview/index.rst | 2 +
> user/start/faq.rst | 295 +++++++++++++++++++++++++++++++
> user/start/index.rst | 1 +
> user/support/contrib.rst | 96 +---------
> user/support/support-project.rst | 2 +
> 6 files changed, 303 insertions(+), 95 deletions(-)
> create mode 100644 user/start/faq.rst
> diff --git a/user/bld/index.rst b/user/bld/index.rst
> index ebedf5a..0cccde2 100644
> --- a/user/bld/index.rst
> +++ b/user/bld/index.rst
> @@ -284,6 +284,8 @@ example configuration file, building of the tests is enabled for the
> [riscv/griscv]
> +.. _Migration_from_AutoconfAutomake:
> Migration from Autoconf/Automake
> diff --git a/user/overview/index.rst b/user/overview/index.rst
> index 550724a..0703ede 100644
> --- a/user/overview/index.rst
> +++ b/user/overview/index.rst
> @@ -20,6 +20,8 @@ You are someone looking for a real-time operating system. This document
> - helps you to build an example application on top of RTEMS.
> +.. _Features:
> Features
> diff --git a/user/start/faq.rst b/user/start/faq.rst
> new file mode 100644
> index 0000000..910ef8b
> --- /dev/null
> +++ b/user/start/faq.rst
> @@ -0,0 +1,295 @@
> +Frequently Asked Questions
> +What is RTEMS ?
No whitespace before punctuation. "What is RTEMS?"
> +RTEMS is an open source real-time executive which provides a high performance
> +environment for embedded real-time applications including many features.
> +The RTEMS Project is the umbrella term used to describe the collection of
> +individuals, companies, universities, and research institutions that collectively
> +maintain and enhance the RTEMS software base.
> +RTEMS is designed to support applications with the most stringent real-time
> +requirements while being compatible with open standards such as POSIX.
> +RTEMS includes optional functional features such as TCP/IP and various file
> +systems while still offering minimum executable sizes under 20 KB in useful
> +configurations.
> +:ref:`More Features<Features>`
> +Where can I get RTEMS ?
> +:ref:`Downloading RTEMS<QuickStartSources_Released>`
What happened to:
How can I pronounce RTEMS like Joel?
> +What does RTEMS stand for ?
> +RTEMS is an an acronym for the Real-Time Executive for Multiprocessor Systems.
"an an" (typo in original wiki page :)
> +Initially RTEMS stood for the Real-Time Executive for Missile Systems but as it
> +became clear that the application domains that could use RTEMS extended far
> +beyond missiles, the "M" changed to mean Military. When maintenance of RTEMS
> +transferred to OAR, the "M" was changed again to Multiprocessor.
> +At one point, there were both Ada and C implementations of RTEMS.
> +Version 3.2.1 was the last RTEMS version to have implementations in both
> +languages. Supporting the Classic API Ada implementation was painful and fraught
> +with compiler specific pitfalls. With version 3.5.x, the POSIX API was added as
> +the means to support the GNU Ada Translator (GNAT). This effectively eliminated
> +the need for an implementation in Ada as the C implementation could effectively
> +support both languages.
> +Are there restrictions on the RTEMS License ?
> +RTEMS RTEMS is licensed under a combination of permissive licenses and a
> +modified version of the GNU General Public License (GPL).
> +For source code "Two Clause BSD” (BSD-2-Clause) and
> +for documentation CC-BY-SA-4.0 license is preferred.
> +The modification places no restrictions on the applications which use RTEMS but
> +protects the interests of those who work on RTEMS.
> +`License in RTEMS
> +<https://docs.rtems.org/branches/master/eng/
> +license-requirements.html>`__
add the other questions even if their pages are missing, and maybe add
a "TBD" stub or something so someone can provide the answers.
Here would be "Are there Export Restrictions? on RTEMS?"
> +What standards are supported by RTEMS?
> +The original "Classic" RTEMS API is based on the Real-Time Executive Interface
> +Definition (RTEID) and the Open Real-Time Kernel Interface Definition (ORKID).
> +RTEMS also includes support for POSIX threads and real-time extensions.
> +With the addition of file system infrastructure, RTEMS supports approximately
> +80% of the POSIX 1003.1b-1996 standard. This standard defines the programming
> +interfaces of standard UNIX. This means that much source code that works on
> +UNIX, also works on RTEMS.RTEMS includes a port of the FreeBSD TCP/IP stack and
> +thus supports BSD sockets. It also includes support for numerous networking
> +clients (DHCP, TFTP, NFS, etc.) and servers (FTPD, HTTPD, etc.).
> +What processors is RTEMS available for ?
> +:ref:`Architectures in RTEMS<TargetArchitectures>`
Make this read as a complete sentence:
See :ref:`Architectures in RTEMS<TargetArchitectures>`.
> +Are there similar commercial products ?
> +`Some Real time operating system similar to RTEMS
> +<https://en.wikipedia.org/wiki/Comparison_of_real-time_operating_systems>`__
> +How can I obtain RTEMS support ?
> +:ref:`Support in RTEMS<RTEMS_Project_Support>`
> +What RTEMS Training Opportunities are available ?
> +`RTEMS Training Opportunities <https://www.rtems.org/TrainingOpportunities>`__
ditto
> +How can I contribute?
> +:ref:`Contributions in RTEMS<Contributing>`
ditto
> +How are floating point numbers handled ?
> +`Floating point support in RTEMS
> +<https://docs.rtems.org/branches/master/c-user/task/
> +background.html#floating-point-considerations>`__
ditto
> +How do I make a patch ?
> +`Creating and sending patch in RTEMS
> +<https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch>`__
> +Why is my executable so big?
> +There are two primary causes for this. The most common is that you are doing an
> +ls -l and looking at the actual file size – not the size of the code in the
> +target image. This file could be in an object format such as ELF or COFF and
> +contain debug information. If this is the case, it could be an order of magnitude
> +larger than the required code space. Use the strip command in your cross
> +toolset to remove debugging information.
> +Another alternative is that the executable file is in an ASCII format such as
> +Motorola Srecords. In this case, there is no debug information in the file
> +but each byte in the target image requires two bytes to represent. On top of
> +that, there is some overhead required to specify the addresses where the image
> +is to be placed in target memory as well as checksum information. In this
> +case, it is not uncommon to see executable files that are between two and three
> +times larger than the actual space required in target memory.
> +Remember, the debugging information is required to do symbolic debugging with gdb.
> +Normally gdb obtains its symbolic information from the same file that it gets
> +the exe- cutable image from. However, gdb does not require that the executable
> +image and symbolic information be obtained from the same file. So you might want
> +to create a hello_with_ symbols.exe, copy that file to hello_without_symbols.exe,
> +and strip hello_without_ symbols.exe. Then gdb would have to be told to read
> +symbol information from hello_ with_symbols.exe. The gdb command line option
> +-symbols or command symbol-file may be used to specify the file read for
> +symbolic information
> +What MinGW Tools for Windows are available ?
> +Windows users can use MinGW based RTEMS tools. These tools will generate the
> +same application code for RTEMS as the tools on Linux or Cygwin. MinGW tools
> +use the native Windows runtime rather than access Windows via the POSIX interfac
> +Cygwin provides. MinGW tools are faster than the Cygwin equivalent and are not
> +confused by Cygwin mount points. Compiler errors will show a Windows path rather
> +than a Cygwin path and so do not confuse native Windows editors.
> +:ref:`Cygwin in windows<Cygwin>`
> +The RTEMS MinGW Tools are not currently packaged in installers. The installers
> +stopped around RTEMS 4.9 when the MinGW tools started to be built as part of
> +the binary tool package. This means you need to manually step through the
> +process. It is not difficult, how-ever it is not an easy installer.
> +What is Multilib RTEMS ?
> +The multilib process supports building a set of related libraries for a given
> +target where the individual libraries in the set use different specific
> +compiler flags (such as flags for code generation options, pre-processor
> +defines, etc) for the individual libraries. The reason this is needed can be
> +seen by examining the M68K GCC compiler. That compiler generates code for a
> +number of processor variants in the M68K family, for example, it can generate
> +code for the original 68000, the 68040 or a 528x Coldfire. These processors all
> +use a closely related instruction set, but processor differences mean code
> +compiled for one may not run on another. GCC provides a special library called
> +libgcc.a that holds intrinsic functions needed by the compiler. These
> +intrinsic functions provide "software instructions" (such as non-basic math
> +support routines) that the processor may not support. However, which functions
> +GCC considers to be intrinsic should be able to vary within a processor family.
> +One processor variant will have hardware floating point and another processor
> +variant will not, and GCC (and RTEMS) should be able to generate efficient code
> +for each processor variant. When we wish to have different code for a range of
> +related yet potentially incompatible processors in a family by providing
> +multiple related libraries we use the multilib process.
> +The multilib process extends beyond libgcc.a to libc.a, libm.a, and libstd++.a.
> +An RTEMS tool set will provide each of these libraries for each of the processor
> +variants that GCC supports. You can see the multilib information by invoking gcc
> +with the option '-print-multi-lib'. The output for the M68K tool chain is -
> +.. code-block:: none
> + $ m68k-rtems-gcc -print-multi-lib .; m68000;@m68000 m5200;@m5200
> + m5206e;@m5206e m528x;@m528x m5307;@m5307 m5407;@m5407 mcpu32;@mcpu32
> + m68040;@m68040 m68060;@m68060 msoft-float;@msoft-float
> +This output is not easy to read as it is designed for other tools or packages.
> +RTEMS core under the cpukit source tree does not reference any BSP specific
> +details. This allows it to be built as a set of multiple libraries named
> +librtemscpu.a. A configure command line option will build a multilib RTEMS as
> +shown in Building a CPU Kit.
> +BSP and CPU model specific portions of RTEMS (libcpu and libbsp) are
> +built into the separate library librtemsbsp.a.
> +What is the difference between the workspace and heap ?
> +The RTEMS Workspace is used to allocate space for objects created by RTEMS
> +such as tasks, semaphores, message queues, etc.. It is primarily used during
> +system initialization although task stacks and message buffer areas are also
> +allocated from here.
> +Why should we work with the RTEMS developers ?
> +Our engineers understand our target environment better than anyone else, and
> +we have a tight schedule. Why should we work with the RTEMS developers, when
> +we can get the code out faster by whacking it out on our own?
> +You understand your target environment better than anyone else.
> +However, the RTEMS developers understand RTEMS better than anyone
> +else; furthermore, the RTEMS developers tend to have a wide breadth
> +of experience across a large number of processors, boards, peripherals,
> +and application domains. It has been our experience that few problems
> +encountered in embedded systems development are unique to a particular
> +processor or application. The vast majority of the time an issue that
> +arises in one project has also shown up in other projects.
> +The intimate knowledge of RTEMS internals as well as a wide breadth of
> +embedded systems knowledge means that there is a good chance that at
> +least one RTEMS developer has already addressed issues you are likely
> +to face when doing your port, BSP, or application. The developers can
> +help guide you towards a workable long term solution, possibly saving
> +you significant time in your development cycle.
> +If getting the sources into the official RTEMS distributions is one of
> +your goals, then engaging other RTEMS developers early will also likely
> +shorten your development time. By interacting as early as possible you
> +are more likely to write code which can be easily accepted into the official
> +sources when you are finished. If you wait until you think you are done
> +to begin interacting with the RTEMS team, you might find that you did
> +some things wrong and you may have to rewrite parts of your RTEMS port,
> +which is a waste of your valuable time.
> +Why should we integrate our port into the official RTEMS sources?
> +Why should we care if our port is integrated into the official RTEMS sources?
> +We can distribute it ourselves to whoever is interested.
> +Yes, the RTEMS licenses allows you to do that. But by doing so, you end up
> +having to maintain that code yourself; this can be a significant
> +effort over time as the RTEMS sources change rapidly.
> +You also lose the advantage of wider exposure by including your port
> +in the official RTEMS sources maintained by the RTEMS Project.
> +The wider exposure in the RTEMS developer and tester community will
> +help keep your work up to date with the current sources. You may even
> +find that volunteers will run the ever-growing test suite on your port
> +and fix problems during the development cycle -- sometimes without your
> +intervention.
> +It has been our experience that integrated ports tend to ultimately
> +be of better quality and stay up to date from release to release.
> +Aspects of my target environment that my application exploits are still under NDA
> +Nevertheless, if the target hardware is built of any commercial parts
> +that are generally available including, but not limited to, the CPU
> +or peripherals, then that portion of your work is still of general use.
> +Similarly, if you have written software that adheres to existing API or
> +interface standards, then that portion is also of general use.
> +Our experience is that most embedded applications do utilize a custom
> +mix of hardware and application, but they are built upon layers of hardware
> +and software components that are in no way unique to the project.
> +If you are porting to an unreleased CPU family or model, then just
> +announcing it is important because other RTEMS users may be planning
> +to use it and some of them may already be trying to port RTEMS on
> +their own. Your customers might be happier to know that your port
> +will eventually be available. Also, there is no requirement that RTEMS
> +include all features or ports at any particular time, so you are encouraged
> +to submit discrete pieces of functionality in stages.
> +Assume that your processor has some new functionality or peripherals.
> +However that functionality is still covered by NDA, but the basic core
> +architecture is not. It is still to your advantage to go ahead and work
> +with the developers early to provide a "base port" for the CPU family.
> +That base port would only use the publicly available specifications
> +until such time as the NDA is lifted. Once the NDA is lifted you can
> +work with the developers to provide the code necessary to take
> +advantage of the new functionality.
> +What is the difference between autoconf and waf build system ?
> +Waf is a build automation tool written in Python which is designed to assist
> +in the automatic compilation and installation of computer software.
> +:ref:`Converting from Autoconf/Automake to waf build system
> +<Migration_from_AutoconfAutomake>`
> diff --git a/user/start/index.rst b/user/start/index.rst
> index 17c34e1..e178209 100644
> --- a/user/start/index.rst
> +++ b/user/start/index.rst
> @@ -23,3 +23,4 @@ applications on top of RTEMS.
> app
> rsb-packages
> gsoc
> + faq
> diff --git a/user/support/contrib.rst b/user/support/contrib.rst
> index c42d41b..758f0f6 100644
> --- a/user/support/contrib.rst
> +++ b/user/support/contrib.rst
> @@ -168,98 +168,4 @@ time, or have proven very hard to integrate. So, what we are asking
> is that, to the maximum extent possible, you communicate with us
> as early on and as much as possible.
> -Common Questions and Answers
> -Here are some questions RTEMS porters may have with our answers to
> -them. While the focus here is on new ports and BSPs, we believe that
> -the issues are similar for other RTEMS development efforts including
> -student efforts to implement new algorithmic optimizations.
> - Our engineers understand our target environment better than anyone else, and
> - we have a tight schedule. Why should we work with the RTEMS developers, when
> - we can get the code out faster by whacking it out on our own?
> -You understand your target environment better than anyone else.
> -However, the RTEMS developers understand RTEMS better than anyone
> -else; furthermore, the RTEMS developers tend to have a wide breadth
> -of experience across a large number of processors, boards, peripherals,
> -and application domains. It has been our experience that few problems
> -encountered in embedded systems development are unique to a particular
> -processor or application. The vast majority of the time an issue that
> -arises in one project has also shown up in other projects.
> -The intimate knowledge of RTEMS internals as well as a wide breadth of
> -embedded systems knowledge means that there is a good chance that at
> -least one RTEMS developer has already addressed issues you are likely
> -to face when doing your port, BSP, or application. The developers can
> -help guide you towards a workable long term solution, possibly saving
> -you significant time in your development cycle.
> -If getting the sources into the official RTEMS distributions is one of
> -your goals, then engaging other RTEMS developers early will also likely
> -shorten your development time. By interacting as early as possible you
> -are more likely to write code which can be easily accepted into the official
> -sources when you are finished. If you wait until you think you are done
> -to begin interacting with the RTEMS team, you might find that you did
> -some things wrong and you may have to rewrite parts of your RTEMS port,
> -which is a waste of your valuable time.
> - Why should we care if our port is integrated into the official RTEMS
> - sources? We can distribute it ourselves to whoever is interested.
> -Yes, the RTEMS licenses allows you to do that. But by doing so, you end up
> -having to maintain that code yourself; this can be a significant
> -effort over time as the RTEMS sources change rapidly.
> -You also lose the advantage of wider exposure by including your port
> -in the official RTEMS sources maintained by the RTEMS Project.
> -The wider exposure in the RTEMS developer and tester community will
> -help keep your work up to date with the current sources. You may even
> -find that volunteers will run the ever-growing test suite on your port
> -and fix problems during the development cycle -- sometimes without your
> -intervention.
> -It has been our experience that integrated ports tend to ultimately
> -be of better quality and stay up to date from release to release.
> - Why should we communicate up front? We are happy to let the RTEMS developers
> - integrate our stuff later.
> -See above. It will save work for you over both the short and the
> -long term, and it is the right thing to do.
> - Aspects of my target environment that my application exploits are still
> - under NDA.
> -Nevertheless, if the target hardware is built of any commercial parts
> -that are generally available including, but not limited to, the CPU
> -or peripherals, then that portion of your work is still of general use.
> -Similarly, if you have written software that adheres to existing API or
> -interface standards, then that portion is also of general use.
> -Our experience is that most embedded applications do utilize a custom
> -mix of hardware and application, but they are built upon layers of hardware
> -and software components that are in no way unique to the project.
> -If you are porting to an unreleased CPU family or model, then just
> -announcing it is important because other RTEMS users may be planning
> -to use it and some of them may already be trying to port RTEMS on
> -their own. Your customers might be happier to know that your port
> -will eventually be available. Also, there is no requirement that RTEMS
> -include all features or ports at any particular time, so you are encouraged
> -to submit discrete pieces of functionality in stages.
> -Assume that your processor has some new functionality or peripherals.
> -However that functionality is still covered by NDA, but the basic core
> -architecture is not. It is still to your advantage to go ahead and work
> -with the developers early to provide a "base port" for the CPU family.
> -That base port would only use the publicly available specifications
> -until such time as the NDA is lifted. Once the NDA is lifted you can
> -work with the developers to provide the code necessary to take
> -advantage of the new functionality.
> -Ultimately, cooperating with the free software community as early as
> -possible helps you by decreasing your development cycle, decreasing
> -your long term maintenance costs and may help raise interest in your
> -processor by having a free compiler implementation available to
> -anyone who wants to take a look.
don't add extra spaces randomly
> diff --git a/user/support/support-project.rst b/user/support/support-project.rst
> index b782029..73d5851 100644
> --- a/user/support/support-project.rst
> +++ b/user/support/support-project.rst
> @@ -6,6 +6,8 @@
> .. index:: support; RTEMS Project
> +.. _RTEMS_Project_Support:
> RTEMS Project Support
> 2.25.1
> devel mailing list
> devel at rtems.org
