[PATCH rtems-docs v2 1/2] Added FAQ page
Ayushman Mishra ayushvidushi01 at gmail.com
Sun Apr 4 00:55:02 UTC 2021
And sir , if we can't use cross-link should I write a sentence like
for eg. " (Please refer section 6.1.12. "Creating a Patch" of RTEMS
Software Engineering manual in :r:url:`docs`) for question How do I
make a patch? "
On Sun, Apr 4, 2021 at 5:05 AM Chris Johns <chrisj at rtems.org> wrote:
> On 3/4/21 6:25 am, Gedare Bloom wrote:
> > On Fri, Apr 2, 2021 at 12:19 PM Ayushman Mishra
> > <ayushvidushi01 at gmail.com> wrote:
> >>  user/bld/index.rst               |   2 +
> >>  user/overview/index.rst          |   2 +
> >>  user/start/faq.rst               | 295 +++++++++++++++++++++++++++++++
> >>  user/start/index.rst             |   1 +
> >>  user/support/contrib.rst         |  96 +---------
> >>  user/support/support-project.rst |   2 +
> >>  6 files changed, 303 insertions(+), 95 deletions(-)
> >>  create mode 100644 user/start/faq.rst
> >> diff --git a/user/bld/index.rst b/user/bld/index.rst
> >> index ebedf5a..0cccde2 100644
> >> --- a/user/bld/index.rst
> >> +++ b/user/bld/index.rst
> >> @@ -284,6 +284,8 @@ example configuration file, building of the tests is enabled for the
> >>      [riscv/griscv]
> >> +.. _Migration_from_AutoconfAutomake:
> >>  Migration from Autoconf/Automake
> >> diff --git a/user/overview/index.rst b/user/overview/index.rst
> >> index 550724a..0703ede 100644
> >> --- a/user/overview/index.rst
> >> +++ b/user/overview/index.rst
> >> @@ -20,6 +20,8 @@ You are someone looking for a real-time operating system.  This document
> >>  - helps you to build an example application on top of RTEMS.
> >> +.. _Features:
> >>  Features
> >> diff --git a/user/start/faq.rst b/user/start/faq.rst
> >> new file mode 100644
> >> index 0000000..910ef8b
> >> --- /dev/null
> >> +++ b/user/start/faq.rst
> >> @@ -0,0 +1,295 @@
> >> +Frequently Asked Questions
> >> +What is RTEMS ?
> > No whitespace before punctuation. "What is RTEMS?"
> >> +RTEMS is an open source real-time executive which provides a high performance
> >> +environment for embedded real-time applications including many features.
> >> +The RTEMS Project is the umbrella term used to describe the collection of
> >> +individuals, companies, universities, and research institutions that collectively
> >> +maintain and enhance the RTEMS software base.
> >> +RTEMS is designed to support applications with the most stringent real-time
> >> +requirements while being compatible with open standards such as POSIX.
> >> +RTEMS includes optional functional features such as TCP/IP and various file
> >> +systems while still offering minimum executable sizes under 20 KB in useful
> >> +configurations.
> >> +:ref:`More Features<Features>`
> >> +Where can I get RTEMS ?
> >> +:ref:`Downloading RTEMS<QuickStartSources_Released>`
> > What happened to:
> > How can I pronounce RTEMS like Joel?
> >> +What does RTEMS stand for ?
> >> +RTEMS is an an acronym for the Real-Time Executive for Multiprocessor Systems.
> > "an an" (typo in original wiki page :)
> >> +Initially RTEMS stood for the Real-Time Executive for Missile Systems but as it
> >> +became clear that the application domains that could use RTEMS extended far
> >> +beyond missiles, the "M" changed to mean Military. When maintenance of RTEMS
> >> +transferred to OAR, the "M" was changed again to Multiprocessor.
> >> +At one point, there were both Ada and C implementations of RTEMS.
> >> +Version 3.2.1 was the last RTEMS version to have implementations in both
> >> +languages. Supporting the Classic API Ada implementation was painful and fraught
> >> +with compiler specific pitfalls. With version 3.5.x, the POSIX API was added as
> >> +the means to support the GNU Ada Translator (GNAT). This effectively eliminated
> >> +the need for an implementation in Ada as the C implementation could effectively
> >> +support both languages.
> >> +Are there restrictions on the RTEMS License ?
> >> +RTEMS RTEMS is licensed under a combination of permissive licenses and a
> >> +modified version of the GNU General Public License (GPL).
> >> +For source code "Two Clause BSD” (BSD-2-Clause) and
> >> +for documentation CC-BY-SA-4.0 license is preferred.
> >> +The modification places no restrictions on the applications which use RTEMS but
> >> +protects the interests of those who work on RTEMS.
> >> +`License in RTEMS
> >> +<https://docs.rtems.org/branches/master/eng/
> >> +license-requirements.html>`__
> > add the other questions even if their pages are missing, and maybe add
> > a "TBD" stub or something so someone can provide the answers.
> > Here would be "Are there Export Restrictions? on RTEMS?"
> >> +What standards are supported by RTEMS?
> >> +The original "Classic" RTEMS API is based on the Real-Time Executive Interface
> >> +Definition (RTEID) and the Open Real-Time Kernel Interface Definition (ORKID).
> >> +RTEMS also includes support for POSIX threads and real-time extensions.
> >> +With the addition of file system infrastructure, RTEMS supports approximately
> >> +80% of the POSIX 1003.1b-1996 standard. This standard defines the programming
> >> +interfaces of standard UNIX. This means that much source code that works on
> >> +UNIX, also works on RTEMS.RTEMS includes a port of the FreeBSD TCP/IP stack and
> >> +thus supports BSD sockets. It also includes support for numerous networking
> >> +clients (DHCP, TFTP, NFS, etc.) and servers (FTPD, HTTPD, etc.).
> >> +What processors is RTEMS available for ?
> >> +:ref:`Architectures in RTEMS<TargetArchitectures>`
> > Make this read as a complete sentence:
> > See :ref:`Architectures in RTEMS<TargetArchitectures>`.
> >> +Are there similar commercial products ?
> >> +`Some Real time operating system similar to RTEMS
> >> +<https://en.wikipedia.org/wiki/Comparison_of_real-time_operating_systems>`__
> >> +How can I obtain RTEMS support ?
> >> +:ref:`Support in RTEMS<RTEMS_Project_Support>`
> >> +What RTEMS Training Opportunities are available ?
> >> +`RTEMS Training Opportunities <https://www.rtems.org/TrainingOpportunities>`__
> > ditto
> >> +How can I contribute?
> >> +:ref:`Contributions in RTEMS<Contributing>`
> > ditto
> >> +How are floating point numbers handled ?
> >> +`Floating point support in RTEMS
> >> +<https://docs.rtems.org/branches/master/c-user/task/
> >> +background.html#floating-point-considerations>`__
> > ditto
> >> +How do I make a patch ?
> >> +`Creating and sending patch in RTEMS
> >> +<https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch>`__
> >> +Why is my executable so big?
> I am not sure if anyone has said but each question needs to be a section heading
> of some level.
> >> +There are two primary causes for this. The most common is that you are doing an
> >> +ls -l and looking at the actual file size – not the size of the code in the
> >> +target image. This file could be in an object format such as ELF or COFF and
> >> +contain debug information.
> Please only state ELF. We do not have any COFF targets any more.
> >> If this is the case, it could be an order of magnitude
> >> +larger than the required code space. Use the strip command in your cross
> >> +toolset to remove debugging information.
> >> +Another alternative is that the executable file is in an ASCII format such as
> >> +Motorola Srecords. In this case, there is no debug information in the file
> >> +but each byte in the target image requires two bytes to represent. On top of
> >> +that, there is some overhead required to specify the addresses where the image
> >> +is to be placed in target memory as well as checksum information. In this
> >> +case, it is not uncommon to see executable files that are between two and three
> >> +times larger than the actual space required in target memory.
> >> +Remember, the debugging information is required to do symbolic debugging with gdb.
> >> +Normally gdb obtains its symbolic information from the same file that it gets
> >> +the exe- cutable image from. However, gdb does not require that the executable
> >> +image and symbolic information be obtained from the same file. So you might want
> >> +to create a hello_with_ symbols.exe, copy that file to hello_without_symbols.exe,
> >> +and strip hello_without_ symbols.exe. Then gdb would have to be told to read
> >> +symbol information from hello_ with_symbols.exe. The gdb command line option
> >> +-symbols or command symbol-file may be used to specify the file read for
> >> +symbolic information
> >> +What MinGW Tools for Windows are available ?
> Please make sure this is MSYS2 MinGW and not MinGW. MSYS2 MinGW is different to
> MinGW. I have not looked at the original MinGW project in years.
> >> +Windows users can use MinGW based RTEMS tools. These tools will generate the
> >> +same application code for RTEMS as the tools on Linux or Cygwin. MinGW tools
> >> +use the native Windows runtime rather than access Windows via the POSIX interfac
> >> +Cygwin provides. MinGW tools are faster than the Cygwin equivalent and are not
> >> +confused by Cygwin mount points. Compiler errors will show a Windows path rather
> >> +than a Cygwin path and so do not confuse native Windows editors.
> >> +:ref:`Cygwin in windows<Cygwin>`
> >> +The RTEMS MinGW Tools are not currently packaged in installers.
> There should be a section on binary tools which could be referenced ....
> Does the RTEMS Project provide binary packages of tools?
> The RTEMS Project does not provide binary packages of the tools. The project did
> at one point but it found more and more resources being devoted to providing an
> ever growing number of packages for more and more operating systems and their
> variants or distributions.
> The RTEMS Project is focused on open source and providing an efficient means to
> build from source means a wide range of host system can be supported. Tools
> built on a specific host are correctly matched to that system. The act of
> building from source means the user has all the source code used to create an
> RTEMS tools and application present on their development system ready to be
> archived for long term maintenance.
> Long term maintenance can require building of the tools years later and the RSB
> provides a portable means to build old tools on new systems.
> RTEMS Tools can be provided as binary packages externally to the project and
> there are some available. The RTEMS project encourages this but those tools and
> the support for them needs to be handled by the tools provider.
> The installers
> >> +stopped around RTEMS 4.9 when the MinGW tools started to be built as part of
> >> +the binary tool package. This means you need to manually step through the
> >> +process. It is not difficult, how-ever it is not an easy installer.
> >> +What is Multilib RTEMS ?
> >> +The multilib process supports building a set of related libraries for a given
> >> +target where the individual libraries in the set use different specific
> >> +compiler flags (such as flags for code generation options, pre-processor
> >> +defines, etc) for the individual libraries. The reason this is needed can be
> >> +seen by examining the M68K GCC compiler. That compiler generates code for a
> >> +number of processor variants in the M68K family, for example, it can generate
> >> +code for the original 68000, the 68040 or a 528x Coldfire. These processors all
> >> +use a closely related instruction set, but processor differences mean code
> >> +compiled for one may not run on another. GCC provides a special library called
> >> +libgcc.a that holds intrinsic functions needed by the compiler. These
> >> +intrinsic functions provide "software instructions" (such as non-basic math
> >> +support routines) that the processor may not support. However, which functions
> >> +GCC considers to be intrinsic should be able to vary within a processor family.
> >> +One processor variant will have hardware floating point and another processor
> >> +variant will not, and GCC (and RTEMS) should be able to generate efficient code
> >> +for each processor variant. When we wish to have different code for a range of
> >> +related yet potentially incompatible processors in a family by providing
> >> +multiple related libraries we use the multilib process.
> >> +The multilib process extends beyond libgcc.a to libc.a, libm.a, and libstd++.a.
> >> +An RTEMS tool set will provide each of these libraries for each of the processor
> >> +variants that GCC supports. You can see the multilib information by invoking gcc
> >> +with the option '-print-multi-lib'. The output for the M68K tool chain is -
> >> +.. code-block:: none
> >> +    $ m68k-rtems-gcc -print-multi-lib .; m68000;@m68000 m5200;@m5200
> >> +    m5206e;@m5206e m528x;@m528x m5307;@m5307 m5407;@m5407 mcpu32;@mcpu32
> >> +    m68040;@m68040 m68060;@m68060 msoft-float;@msoft-float
> >> +This output is not easy to read as it is designed for other tools or packages.
> >> +RTEMS core under the cpukit source tree does not reference any BSP specific
> >> +details. This allows it to be built as a set of multiple libraries named
> >> +librtemscpu.a. A configure command line option will build a multilib RTEMS as
> >> +shown in Building a CPU Kit.
> >> +BSP and CPU model specific portions of RTEMS (libcpu and libbsp) are
> >> +built into the separate library librtemsbsp.a.
> >> +What is the difference between the workspace and heap ?
> >> +The RTEMS Workspace is used to allocate space for objects created by RTEMS
> >> +such as tasks, semaphores, message queues, etc.. It is primarily used during
> >> +system initialization although task stacks and message buffer areas are also
> >> +allocated from here.
> >> +Why should we work with the RTEMS developers ?
> >> +Our engineers understand our target environment better than anyone else, and
> >> +we have a tight schedule. Why should we work with the RTEMS developers, when
> >> +we can get the code out faster by whacking it out on our own?
> >> +You understand your target environment better than anyone else.
> >> +However, the RTEMS developers understand RTEMS better than anyone
> >> +else; furthermore, the RTEMS developers tend to have a wide breadth
> >> +of experience across a large number of processors, boards, peripherals,
> >> +and application domains. It has been our experience that few problems
> >> +encountered in embedded systems development are unique to a particular
> >> +processor or application. The vast majority of the time an issue that
> >> +arises in one project has also shown up in other projects.
> >> +The intimate knowledge of RTEMS internals as well as a wide breadth of
> >> +embedded systems knowledge means that there is a good chance that at
> >> +least one RTEMS developer has already addressed issues you are likely
> >> +to face when doing your port, BSP, or application. The developers can
> >> +help guide you towards a workable long term solution, possibly saving
> >> +you significant time in your development cycle.
> >> +If getting the sources into the official RTEMS distributions is one of
> >> +your goals, then engaging other RTEMS developers early will also likely
> >> +shorten your development time. By interacting as early as possible you
> >> +are more likely to write code which can be easily accepted into the official
> >> +sources when you are finished. If you wait until you think you are done
> >> +to begin interacting with the RTEMS team, you might find that you did
> >> +some things wrong and you may have to rewrite parts of your RTEMS port,
> >> +which is a waste of your valuable time.
> >> +Why should we integrate our port into the official RTEMS sources?
> >> +Why should we care if our port is integrated into the official RTEMS sources?
> >> +We can distribute it ourselves to whoever is interested.
> >> +Yes, the RTEMS licenses allows you to do that. But by doing so, you end up
> >> +having to maintain that code yourself; this can be a significant
> >> +effort over time as the RTEMS sources change rapidly.
> >> +You also lose the advantage of wider exposure by including your port
> >> +in the official RTEMS sources maintained by the RTEMS Project.
> >> +The wider exposure in the RTEMS developer and tester community will
> >> +help keep your work up to date with the current sources. You may even
> >> +find that volunteers will run the ever-growing test suite on your port
> >> +and fix problems during the development cycle -- sometimes without your
> >> +intervention.
> >> +It has been our experience that integrated ports tend to ultimately
> >> +be of better quality and stay up to date from release to release.
> >> +Aspects of my target environment that my application exploits are still under NDA
> >> +Nevertheless, if the target hardware is built of any commercial parts
> >> +that are generally available including, but not limited to, the CPU
> >> +or peripherals, then that portion of your work is still of general use.
> >> +Similarly, if you have written software that adheres to existing API or
> >> +interface standards, then that portion is also of general use.
> >> +Our experience is that most embedded applications do utilize a custom
> >> +mix of hardware and application, but they are built upon layers of hardware
> >> +and software components that are in no way unique to the project.
> >> +If you are porting to an unreleased CPU family or model, then just
> >> +announcing it is important because other RTEMS users may be planning
> >> +to use it and some of them may already be trying to port RTEMS on
> >> +their own. Your customers might be happier to know that your port
> >> +will eventually be available. Also, there is no requirement that RTEMS
> >> +include all features or ports at any particular time, so you are encouraged
> >> +to submit discrete pieces of functionality in stages.
> >> +Assume that your processor has some new functionality or peripherals.
> >> +However that functionality is still covered by NDA, but the basic core
> >> +architecture is not. It is still to your advantage to go ahead and work
> >> +with the developers early to provide a "base port" for the CPU family.
> >> +That base port would only use the publicly available specifications
> >> +until such time as the NDA is lifted. Once the NDA is lifted you can
> >> +work with the developers to provide the code necessary to take
> >> +advantage of the new functionality.
> >> +What is the difference between autoconf and waf build system ?
> >> +Waf is a build automation tool written in Python which is designed to assist
> >> +in the automatic compilation and installation of computer software.
> >> +:ref:`Converting from Autoconf/Automake to waf build system
> >> +<Migration_from_AutoconfAutomake>`
> >> diff --git a/user/start/index.rst b/user/start/index.rst
> >> index 17c34e1..e178209 100644
> >> --- a/user/start/index.rst
> >> +++ b/user/start/index.rst
> >> @@ -23,3 +23,4 @@ applications on top of RTEMS.
> >>      app
> >>      rsb-packages
> >>      gsoc
> >> +    faq
> >> diff --git a/user/support/contrib.rst b/user/support/contrib.rst
> >> index c42d41b..758f0f6 100644
> >> --- a/user/support/contrib.rst
> >> +++ b/user/support/contrib.rst
> >> @@ -168,98 +168,4 @@ time, or have proven very hard to integrate. So, what we are asking
> >>  is that, to the maximum extent possible, you communicate with us
> >>  as early on and as much as possible.
> >> -Common Questions and Answers
> >> -Here are some questions RTEMS porters may have with our answers to
> >> -them. While the focus here is on new ports and BSPs, we believe that
> >> -the issues are similar for other RTEMS development efforts including
> >> -student efforts to implement new algorithmic optimizations.
> >> -    Our engineers understand our target environment better than anyone else, and
> >> -    we have a tight schedule. Why should we work with the RTEMS developers, when
> >> -    we can get the code out faster by whacking it out on our own?
> >> -You understand your target environment better than anyone else.
> >> -However, the RTEMS developers understand RTEMS better than anyone
> >> -else; furthermore, the RTEMS developers tend to have a wide breadth
> >> -of experience across a large number of processors, boards, peripherals,
> >> -and application domains. It has been our experience that few problems
> >> -encountered in embedded systems development are unique to a particular
> >> -processor or application. The vast majority of the time an issue that
> >> -arises in one project has also shown up in other projects.
> >> -The intimate knowledge of RTEMS internals as well as a wide breadth of
> >> -embedded systems knowledge means that there is a good chance that at
> >> -least one RTEMS developer has already addressed issues you are likely
> >> -to face when doing your port, BSP, or application. The developers can
> >> -help guide you towards a workable long term solution, possibly saving
> >> -you significant time in your development cycle.
> >> -If getting the sources into the official RTEMS distributions is one of
> >> -your goals, then engaging other RTEMS developers early will also likely
> >> -shorten your development time. By interacting as early as possible you
> >> -are more likely to write code which can be easily accepted into the official
> >> -sources when you are finished. If you wait until you think you are done
> >> -to begin interacting with the RTEMS team, you might find that you did
> >> -some things wrong and you may have to rewrite parts of your RTEMS port,
> >> -which is a waste of your valuable time.
> >> -    Why should we care if our port is integrated into the official RTEMS
> >> -    sources? We can distribute it ourselves to whoever is interested.
> >> -Yes, the RTEMS licenses allows you to do that. But by doing so, you end up
> >> -having to maintain that code yourself; this can be a significant
> >> -effort over time as the RTEMS sources change rapidly.
> >> -You also lose the advantage of wider exposure by including your port
> >> -in the official RTEMS sources maintained by the RTEMS Project.
> >> -The wider exposure in the RTEMS developer and tester community will
> >> -help keep your work up to date with the current sources. You may even
> >> -find that volunteers will run the ever-growing test suite on your port
> >> -and fix problems during the development cycle -- sometimes without your
> >> -intervention.
> >> -It has been our experience that integrated ports tend to ultimately
> >> -be of better quality and stay up to date from release to release.
> >> -    Why should we communicate up front? We are happy to let the RTEMS developers
> >> -    integrate our stuff later.
> >> -See above. It will save work for you over both the short and the
> >> -long term, and it is the right thing to do.
> >> -    Aspects of my target environment that my application exploits are still
> >> -    under NDA.
> >> -Nevertheless, if the target hardware is built of any commercial parts
> >> -that are generally available including, but not limited to, the CPU
> >> -or peripherals, then that portion of your work is still of general use.
> >> -Similarly, if you have written software that adheres to existing API or
> >> -interface standards, then that portion is also of general use.
> >> -Our experience is that most embedded applications do utilize a custom
> >> -mix of hardware and application, but they are built upon layers of hardware
> >> -and software components that are in no way unique to the project.
> >> -If you are porting to an unreleased CPU family or model, then just
> >> -announcing it is important because other RTEMS users may be planning
> >> -to use it and some of them may already be trying to port RTEMS on
> >> -their own. Your customers might be happier to know that your port
> >> -will eventually be available. Also, there is no requirement that RTEMS
> >> -include all features or ports at any particular time, so you are encouraged
> >> -to submit discrete pieces of functionality in stages.
> >> -Assume that your processor has some new functionality or peripherals.
> >> -However that functionality is still covered by NDA, but the basic core
> >> -architecture is not. It is still to your advantage to go ahead and work
> >> -with the developers early to provide a "base port" for the CPU family.
> >> -That base port would only use the publicly available specifications
> >> -until such time as the NDA is lifted. Once the NDA is lifted you can
> >> -work with the developers to provide the code necessary to take
> >> -advantage of the new functionality.
> >> -Ultimately, cooperating with the free software community as early as
> >> -possible helps you by decreasing your development cycle, decreasing
> >> -your long term maintenance costs and may help raise interest in your
> >> -processor by having a free compiler implementation available to
> >> -anyone who wants to take a look.
> > don't add extra spaces randomly
> >> diff --git a/user/support/support-project.rst b/user/support/support-project.rst
> >> index b782029..73d5851 100644
> >> --- a/user/support/support-project.rst
> >> +++ b/user/support/support-project.rst
> >> @@ -6,6 +6,8 @@
> >>  .. index:: support; RTEMS Project
> >> +.. _RTEMS_Project_Support:
> >>  RTEMS Project Support
> >> 2.25.1
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
