[PATCH v2 2/3] main_cp.c: Ignore return value from stat()
Ryan Long
ryan.long at oarcorp.com
Mon Apr 5 13:29:13 UTC 2021
CID 26051: Unchecked return value from library in main_cp().
Closes #4365
cpukit/libmisc/shell/main_cp.c | 6 ++++++
1 file changed, 6 insertions(+)
diff --git a/cpukit/libmisc/shell/main_cp.c b/cpukit/libmisc/shell/main_cp.c
index cddbc95..c2ffc10 100644
--- a/cpukit/libmisc/shell/main_cp.c
+++ b/cpukit/libmisc/shell/main_cp.c
@@ -255,8 +255,14 @@ main_cp(rtems_shell_cp_globals* cp_globals, int argc, char *argv[])
if (r == -1) {
if (Rflag && (Lflag || Hflag))
+ #ifdef __rtems__
+ (void)
+ #endif
stat(*argv, &tmp_stat);
else
+ #ifdef __rtems__
+ (void)
+ #endif
lstat(*argv, &tmp_stat);
if (S_ISDIR(tmp_stat.st_mode) && Rflag)
1.8.3.1
